Question about Kenmore 24 in. 15079 Built-in Dishwasher
Kenmore dishwasher Lock-On light flashing, will not start
I have a Kenmore Elite, Model # 665 stock # 15979. The Lock-On light flashes but the unable to Un-Lock it. When I press Canel both lights flash, unable to canel it unless I open the door. when I reclose it the Lock-On flashes. How do I reset it, tried disconnecting power still does the same. What can I do now other than call Services Pete
  • 14 more comments
  • Anonymous Nov 04, 2007
    Lock-on light is on and it wont start
  • Anonymous Jan 23, 2008
    Yes, the lock won't disengage. Even if I push the start bottom, the locked
    key turns on.
  • Anonymous Mar 28, 2008
    That is exactly how ours is doing, however pushing the dry button does not seem to help
  • reader2go May 26, 2008
    Hello, I own a Kenmore Ultra Wash Dishwasher model 665. The Lock On light continues to flash red. I reviewed the manual following the instructions of the NO HEAT DRY 'lock button' to hold for 4 seconds to Unlock but this has not worked. The Lock On Light continues to flash red and I'm unable to start a wash cycle. I checked the fuse and all is good. Has anyone found a solution to this issue?
  • pmm42 Jul 17, 2008
    I'm having the same issue, and it doesn't help when I try to disegage the child lock. We've also tried cycling the power, with no results.
  • spettersong Jul 22, 2008
    We own a Kenmore Ultra Wash dishwasher, model 665. The red locked button won't stop flashing. It says to hold the NO HEAT DRY button for 4 seconds but it does not do the trick. My dishes need to be washed that are stacked inside. Any other suggestions??
  • major285 Jul 23, 2008
    I am having the same problem with the same model as being described. I have held the no heat dry button for 4 seconds the lock on light quit flashing. It still would not let me push start to begin the wash cycle. Within a few seconds it automatically began flashing the lock on again. It just kept alternating the flashing back and forth on its own. Any suggestions? When I hit the cancel button it all cancels. The normal wash button will light up when pushed but will not work or even fill with water.
  • queenvee Sep 03, 2008
    this is the second time I've had this problem. we did not lock the panel in the first place, so it must be a problem with the touch panel itself. I was able to unlock it last time after many, MANY times holding the "no heat dry" button. now we're stuck after 24+ hours trying to unlock it...now calling a repair man. frustrating!
  • tbrat820 Oct 25, 2008
    same problem as the others the lock light came on by its self and wont unlock no matter we do ...how do you fix this ??
  • Anonymous Nov 30, 2008
    My lock on light flashes continuously. The last time it did this I was able to get it to work after several times pressing the no heat button. This time it does nothing.
  • getresults Jan 02, 2009
    Same problem - does anyone know what causes it to do this?
  • Anonymous Jan 20, 2009
    do i need to replace the control panel?
  • KiiraYueAki Feb 08, 2009
    The same happen to me does anyone know how to get rid of the lock and have the dish washer working again?
    Yue
  • DENNIS HOGAN Mar 24, 2009
    Now the pot n pan light keeps flashing
    when i push it then cancel the machine drains and goes back to flashing lights.
  • afrgr1 May 01, 2009
    KENMORE DISHWASHER LOCK-ON LIGHT WILL NOT CLEAR. RECOMMENDED ACTION (HOLD DOWN NO HEAT PAD) DOES NOT WORK. ANYONE GOT FIX ACTION?
  • Mike Nolan
    Mike Nolan Jun 15, 2014
    Press and hold TOP RACK ONLY button for about 6 seconds, until light goes out.
Push the heated/dry button on the dishwasher for 4 seconds and that will unlock the dishwasher. This is just a safety feature that allows you to lock the dishwasher to stop kids from pushing buttons.
If that doesn’t’ work they will send out a tech to fix it.
Posted on Nov 09, 2007
  • Mike Nolan
    Press and hold TOP RACK ONLY button until light goes out.
I had the same problem and searched the forums for an answer. The simple solution is to press the NO HEAT DRY button for up to 10 seconds - but this didn't work for me. So using a T15 torx wrench I removed the inside panel, and the panel cover to expose the control board. I pulled off, and sprayed WD40 on all 10 plastic fittings and replaced panel. Pressed the cancel button and then all the lights went off. Now I could press the wash cycle selection, dry selection, timer and start. It works!! I read that this is only a temporary fix and may need to be repeated. When this remedy quits working, the control panel can be replaced from searsparts direct for $107.
Posted on Jan 28, 2009
  • Jenny Ritter Aug 15, 2013
    Holding the heat dry button for 10 seconds worked for me! thank you SO much!
    New Friend:
The best solution I've found, is to unplug it, pull it away from the wall. Get someone to help you carry it out to the garage. Get the Sears Repair Kit ( 8 pound sledgehammer). Beat the **** out of it until you start feeling better. Then drag it out to the curb for the garbage man. This fix seems to work every time!
Posted on Dec 15, 2012
  • Jay Nichols Feb 18, 2013
    Very useful comment Tom. Must be expensive to be you.
I held down the lock button for 20 seconds or so. It turned off the child lock.
Posted on May 14, 2010
This is the biggest piece of **** i have ever wasted money on. supposed to be a child lock, guess what, have owned the dishwasher for three months. tried the child lock for the first time and does not lock the door, so child can open door while running and thereby getting a face full of scalding water, but only locks controls. turned it on and now will not unlock. stuck with a major load of thanksgiving dishes. Thanks ONCE AGAIN Sears. You ****
Posted on Apr 04, 2010
  • 1 more comment
  • Arnel
    Arnel Mar 21, 2012
    Read the instruction manual...child lock feature is for buttons and not to lock the door
  • Arnel
    Arnel Mar 21, 2012
    Once the door opened the machine will stop...
  • Mike Nolan
    Press and hold TOP RACK ONLY button for about 6 seconds.
Mine is doing this.. I found on the internet it could possibly be the thermostat.. it locks down when the water temp isn't properly regulated.
Posted on Oct 19, 2008
Others have tried this and I thought they were nuts but we were ready to buy a new one and ended up taking a hammer and nail and hitting it quite a few times to the Lock On button making a very small hole. It worked! Adding a picture of my hammer and nail. Dishwasher now doing a regular wash.
Posted on Sep 05, 2018
  • Kurt Fattic
    Kurt Fattic Sep 05, 2018
    Also want to add that I turned off the breaker before doing this.
  • Ron H
    Ron H Jan 24, 2019
    Tried everything suggested...the nail worked perfectly.NOT KIDDING! Just drive a nail into the lock on light and BINGO!
A small nail and a hammer fixed mine, I tapped the nail into the lock on light and it killed the light. Following the press and hold for 10 seconds and turning off the breaker didn't work. After trying all other recommend solutions, I was ready to toss the dishwasher, so I figured what have I got to lose. The dishwasher came with the fixer upper house we just bought so I have no idea how long since it was used. I have run it thru all cycles and it work"s great
Kenmore dishwasher Lock-On  light flashing, will n - 3_17_2018_1_20_48_pm.jpg
Posted on Mar 17, 2018
  • Kurt Fattic
    Worked for me. I posted above, too. That is just a crazy fix but it saved us a few hundred bucks for now!
    New Friend:
Sometimes it just that the child lock feature has gotten turned on. You have to turn it off. Nothing to troubleshoot, it's just a feature the user may not be familiar with. On our machine you press the 'Top Rack Only' button for 3 seconds to turn it on and off.
Posted on Mar 10, 2017
My quickrinse light flashes and answers
Posted on Oct 29, 2008
SOURCE:
Why is heated dry blinking?
FIXED Kenmore dishwasher lights flashing: "Hi Temp" & "Heat Dry ...
www.applianceblog.com/.../40588-Kenmore-dishwasher-lights-flashing-...
Aug 26, 2013 - 10 posts - ‎3 authors
Thread: Kenmore dishwasher lights flashing: "Hi Temp" & "Heat Dry" ... A few months ago, we had a brief power outage and the next morning, noticed the "Hi Temp" and "Heat Dry" lights were flashing. ... Well since then, the dishwasher intermittently stops mid-cycle and these same lights ... Thread: GE Eterna QuietPower 2 Normal and Heated Dry ...
Feb 24, 2012
Kenmore Elist 665 dishwasher Smart Wash red light ...
Dec 23, 2011
Heated dry blinking +17 times - ApplianceBlog
Nov 14, 2010
Heated Dry light blinking
Nov 7, 2010
More results from www.applianceblog.com
Why won't my dishwasher start and why does the "Heated Dry"
www.shopyourway.com > Manage My Life > Questions
Nov 16, 2009 - When I hold down the Heated Dry button to turn the control lock on it ...my dishwasher start and why does the "Heated Dry" light keep blinking ...
Dec 01, 2015 | Dishwashers
here are a couple methods to try....
hold whichever one of these buttons you have on your model for 3+ seconds....
Heat/dry
Air dry
there are a lot of other things that could be the problem but these are common
Jul 27, 2015 | Kenmore Dishwashers
I have a 3022 13929991 Ken Elite Dishwasher - I need to know where i can pull up a mannual got this at Sears Outlet Control lock is on and i can't get it off thanks for your help
Normally you should press the child lock for about 6 secs to turn it off. But if there is a fault in dishwasher then child lock light will be on or flashing.
This means some diagnostics is required to find the cause of the fault.
However, I don't think you have provided the correct model number of your kenmore elite dishwasher.
Normally it should be 665.xxxx Please check the model number carefully and post a comment.
Nov 26, 2010 | Kenmore Dishwashers
Kenmore 665 17033400 Elite dishwasher clean light flashes 7 times and it wont run. i used the reset combination, all lights lit and stayed lit until i pressed reset. Then it started a wash. now the wash...
That signals an issue with a faulty heater &/or heater drive circuit.
(that info comes from their troubleshooting guide)
I ran into it this weekend and discovered that the heater coil in the bottom of the washer was broken.
Jan 14, 2010 | Kenmore 24 in. 17032 Built-in Dishwasher
Kenmore Ultrawash dishwasher Model 665 15810000. Originally "water heating" light was flashing and no water in dishwasher. Replaced water inlet valve. Turned power back on, normal wash light goes on...
lock light is locking the panel push this child lock button for 3 sec and see if it un locks . then try it again .. may have a pannel out. mm
Dec 06, 2009 | Washing Machines
Dishwasher not responding
we have a 4 yr. old built in dishwasher,model #665-15812,the lock-on light is blinking,and the wash and rinse lights are on,but if we push start ,it won't,and if we push the clear button,it won't clear,it's like it's stuck ....we've tried un-plugging,etc....any ideas,on what to do??? donnie-sue79
May 13, 2009 | Kenmore 15939 Built-in Dishwasher
Kenmore dishwasher 665 Lock on light
You may have a stuck button as this will cause flashing of lights, try pushing button and see if it returns if not strike lightly above it with plastic spoon etc.
If this does not work u can buy the control panel from Sears for 190.00 but first go to searspartsdirect.com then type your model no. In required space click on shop parts on appropriate model, then go to troubleshooting then to won't start, then go down to how to replace control panel.
According to instructions you will only need torx screwdriver and less than 30 minutes to replace.
Jul 13, 2017 | Kenmore 16602 / 16604 / 16609 Built-in...
Diswasher will not do anything...
"AIR DRY" LITE IS ON. I CANNOT GET TO GO BACK SO I CAN START IT AGAIN
Apr 21, 2008 | Kenmore 15919 Built-in Dishwasher
Dishwasher doesn't drain fully
Some model 665 DW have a check valve that is attached between the sump and drain hose that may have a blockage..... Remove the drain hose from the long plastic valve then carefully unscrew the check valve from the sump. Inspect for debris.
Jan 03, 2008 | Kenmore 24 in. 15079 Built-in Dishwasher
Clean Light is flashing
If the clean light flashes 7 times, pauses, then repeats...
When the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Nov 27, 2006 | Kenmore 24 in. 16023 Built-in Dishwasher
Kenmore 24 in. 15079 Built-in Dishwasher Logo
20,450 people viewed this question
Top Kenmore Dishwashers Experts
Fred Sops
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
