Back to:
Tags:
Nikon D70s Digital Camera with 18-70mm Lens
I'm having trouble downloading photos to my... (by 40 users)
By kcw573 - usenet poster
I'm having trouble downloading photos to my computer with the software that came with my camera. What can I do?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
39 Other Users Have The Same Problem
Comment by claudia_29, posted on Sep 22, 2008
the lil thingy wont come up to import my photos
Comment by streaderjstr, posted on Sep 02, 2008
My iPhoto program is saying unrecognizable file format.  I have successfully used this camera on my Apple 2 dozen times.  The file format shows jpg, which is the format of all the other programs.
Any help is appreciated.
Jeff
Comment by briandurrant, posted on Aug 31, 2008
I could very easily get the photos from my vivitar camera dvr-210 on to my old laptop which was windows XP . I've now got a new lap top which is Windows Vista and can no longer get the photos from my camera to my lap top.. I have installed the disc that came with the camera and worked ok with Window XP. can you help??
Brian
Comment by dbrenes, posted on Aug 25, 2008
I'm having trouble downloading photos to my computer with the software that came with my camera. .... problem, and notify you when a new solution is offered.
Comment by LinsK, posted on Aug 22, 2008
I have a HP Photosmart M537 and while all the photos are downloading to my computer just fine, I can't get any of the videos off the camera. I can't even go to My Computer bc it isn't popping upo there either!!
Best Solution
posted on Aug 08, 2005
Helpful (85)
paulrmc
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Four words: buy a card reader. Then, when you insert the memory card, it will mount to your desktop just like another disc, and you can copy the photos directly to your hard disk. You can then use your favorite photo editing software to retouch your photos.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on I'm having trouble downloading photos to my computer with the software that came with my camera. ....:
I don't want to Accept this solution
Solution #2
posted on Aug 01, 2008
Not Rated (0)
dummie7549
Rating: 0%, 0 votes
i am havig trouble downloading photos to computer. its like it can't locate my digital camera
Thank You!
Solution #3
posted on Jul 04, 2008
Not Rated (0)
kawoue
Rating: 0%, 0 votes
comment télécharge le pilote de zoom dualcam 300 pour avoiye par mon imail kawoue@yahoo.fr
Thank You!
Solution #4
posted on Jan 15, 2008
Not Rated (0)
fishinnor
Rating: 100%, 1 votes
It needs not driver if your OS is windows xp or 2000. Just plug the USB to your PC and switch the camera to LINK mode . Then you can see it recognized by window.
Thank You!
Solution #5
posted on Dec 20, 2007
Not Rated (0)
t6omtoiler
Rating: 0%, 0 votes
I need software for JD-C4215. No disk was in package. Won't run without it
Thank You!
Solution #6
posted on Dec 02, 2007
Not Rated (0)
creeperz
Rank:Wiz Wiz
Rating: 84%, 54 votes
First of all, Make sure that the camera is on after the cable is connected to the camera and the PC.
Comment by creeperz, posted on Mar 19, 2008
Usually when you connect your camera to the PC via the USB, the camera shows up as a drive in My Computer. From there you can open the device(drive) and browse through the files, copy or delete them.
Connecting the Camera via the USB and copying the files this way will be slower, but you can still get the work done. If you want fast transfers,4-5 time faster, a card reader would be a good option.
Thank You!
Solution #7
posted on Apr 17, 2007
Not Rated (0)
Guest
Rating: 0%, 0 votes
try looking for it on driver.com but the best solution is a cheap card reader and less hassle
Thank You!
Can you Help with these Digital Cameras problems?
I just got a Nikon D70 and it was working fine. Then i...
Everytime i snyc my phone and tell iPhoto to delete all...
I had this camera for almost 3 year already, and all of...
I was taking pictures for my kids school program, Every...
recently i came across a prob with my d70 s digital,its...
39 Other Users Have The Same Problem - Continued
Comment by nreagan11, posted on Aug 18, 2008
Using the disc that came with my Kadak C713 Camera, I Installed it and nothing happened, I uninstalled it, and nothing happened, so I reinstalled it, still nothing so far. thanks.
Comment by Guest, posted on Aug 10, 2008
I can´t download any photo. I have install and uninstall the software many times. I have windows vista.
Comment by iandrummond, posted on Jul 20, 2008
Tried moving on windows directly.
Tried uploading onto Epson File Manager.
Tried uploading onto Photosuite 4.0 that came with camera.
Comment by teresahoodrn, posted on Jun 22, 2008
I am trying to transfer the pic's from my photo area to another area on my computer and am having problems. Now I want to email them to someone. Not sure how to do this. Any suggestions, please email me at teresahoodrn@gmail.com
Comment by Guest, posted on Jun 06, 2008
Comment by babekitty21, posted on May 26, 2008
i just need the web site for it
Comment by brechin, posted on May 22, 2008
I attached the usb cable with my Nikon D70s and the drive does not appear on My Computer. The drive does appear for my flash drive. I downloaded files that should install a program on xp for this, the one I used was PTPdriver. That did not work
Comment by Guest, posted on May 22, 2008
I have D70s. When I connect the usb cable (attached to camera) to my computer (XP) the drive does not appear in My Computer. When I attach a flash drive that does appear in My Computer. Tried to make some changes in regedit but the advice did not match my regedit options.
When I attach the usb cable to my computer, XP, the drive does not appear in My Computer. When I attach a flash drive, it does appear.
Nikon D70s
Comment by JPAres1, posted on May 19, 2008
Telling us to get a card is great but does not solve the issue at hand. Please advise, how does one transfer pics currently on the camera to the computer?
Comment by kcl2008, posted on May 16, 2008
Jazz JDC5 Digital Camera download software
i cant download pics from my cam to my computer nor can i find downloadable software
Comment by skeeter123, posted on May 01, 2008
How do I download a pic from Camera to puter
Comment by Guest, posted on Apr 21, 2008
i have sony cyber sgoy DSC-S650 cam , i cant down load my pics from my cyber shot cam to my laptoppl suggest me wat to do
Comment by Suzie Derkin, posted on Apr 19, 2008
When i connect the USB to the cam, it does notify me that the Digital cam is plugged.. but im unable to open it to upload the pics to the PC.. i do have the software.. DSC 1.3 M TFT .but it doesnt install to the system... however i could upload the pics a week back..
Plz help me..
Comment by BBB16, posted on Mar 30, 2008
I started to upload my photos, and for some reason the memory card deleted all but two photos BEFORE getting them copied. Is there a way to retrieve them once they are gone from the memory card?
Comment by msfields, posted on Mar 28, 2008
i seem to have missed placed my software and i really need to download my pictures to my pc what should i do.
Comment by Guest, posted on Mar 22, 2008
I bought the camera before coming to ireland and I must admit I cannot remember getting to CD Rom software for downloading photos to my computer I cannot seem to find it via the net. Can you help with a site that I can download the software for Canon Powershot A720 IS. Please.
Comment by lylekast, posted on Mar 18, 2008
I can not seem to download video clips to my hard drive on my puter.
I have only a cd drive not a dvd drive, but i just want to put them on hard drive for now.
There seems to be no instruction to do this ...at least i can t find it.
I have managed to download the photos without too much problem, but just cant get the video to work. help appreciated thanks
Comment by sh4rron, posted on Mar 12, 2008
i hvae one disc for my camera but even after numerous attempts i still cant get to download pics or vids from my camera to pc it keeps loading as a scanner
Comment by Guest, posted on Mar 02, 2008
need a softwar
Comment by mikha, posted on Jan 22, 2008
having problems with the soft ware downloading to my computer
Comment by Guest, posted on Jan 08, 2008
Sure, buying a card reader would work-but why would I want to pay MORE money for something? Where are the drivers for these cameras? Sanyo's site sucks for support.
Comment by Guest, posted on Jan 07, 2008
I no longer am in posession of the CD with the necessary software for down loading pictures.
Comment by bumblez, posted on Jan 05, 2008
I am having problems downloading my pictures from my digital camera to my PC because i don't have the software. What do i do?
Comment by Guest, posted on Jan 01, 2008
I have a FinePix A303, never had a problem with downloading using computers with Xp, but my home computer is ME. The FinePix viewr software loads on the ME computer fine, when I connect the camera via usb Windows does it's little hardware update but nothing else happens. The little green arrow for a usb item shows in the bottom rhs, but the camera does not appear as FinePix F: in Explorer nor in the FinePix. Wh? This means of course I can't get the pictures off the camera on the computer
Comment by Guest, posted on Dec 28, 2007
The computer does not locate the camera.
The program does not locate the camera.
Comment by momma7, posted on Dec 25, 2007
My son bought this camera on a field trip and lost the installation CD. Can I download from the internet somewhere? I've been searching the net for about an hour! Please help!
Comment by Guest, posted on Dec 13, 2007
i cannot download the driver to my computer
Comment by MickT, posted on Dec 02, 2007
my camera is not connetcing - says it is not connected but it is. I've reloaded the software, reconnected the cable, etc. but it still doesn't work
Comment by PICTURENUTS, posted on Dec 01, 2007
The autoplay wizard for the fuji finepix s800 isnt working with windows 2000. I disabled my antivirus, and deleted other photo software and still NOTHING!! this is very frustrating! any help is appreciated.
Comment by Guest, posted on Nov 27, 2007
computer cannot locate the camera
Comment by Guest, posted on Nov 24, 2007
i need a driver for it. can you help me get it?
Loading problems.
Repair Service
Find Digital Camera Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
