Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
Colors are curved shadows on words/boxes - Philips 60PP9202 60" Rear Projection HDTV-Ready Television
  • 2 more comments
  • shanda305 Dec 12, 2008
    The green and red are out of sink and the words on the screen are double. What can i do to fix this? It was fine in the a.m. and like this the next time i turned it on.
  • Anonymous Dec 17, 2008
    the words are shadowed and the color is off
  • Anonymous Dec 20, 2008
    Repairman said it is the color convergence which is componenets on one of the pcb. the card must be removed and sent to factory for repair. 2 weeks without tv
  • carlsberg33 Jan 06, 2009
    how much is the part that we need?
    Scholar:
  • 87 Answers
You have bad convergence amps and a couple of bad resistors.This is a common problem with these unit and can be fixed for around $185.00-$250.00.The part # for these amps is STK392-120 at a cost of about $22.00 each.
Posted on Jan 12, 2009
How do i take out shadows in a photo
In Photoshop, choose the Select menu and click on Color Range... Then click on the offending shadow. You will see that area highlighted in the small window. By holding down the shift key and continuing to click on offending shadows, you can add to your selection. Also adjust the Fuzziness setting to suit your preference. Click on OK, and you will see your shadows selected in your image. Now go to the Image menu and select Adjustments/Levels... or Adjustments/Curves... Adjust the sliders, or the shape of the curve to suit your preference. Save your file with a new name in case you need to readjust.
Oct 07, 2014 | Cameras
I have a Phillips 60" rear projection TV. recently
Tv have a problems known as a convergence problems,it is dead.The tv convergence board it is dead,that why ur tv picture are R,G,B colors lines mis alignments,have colors shadows picture or 3D picture lood alike?The tv convergence board require changes 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence picture problems.The shop will cost u like $300-350 for parts and labors.
Jun 01, 2011 | Philips Televison & Video
I have a hitachi ultravision digital hi-def TV model number 53UDX10B from December 2001. The words in its own menu and from my cable box menu are distorted, as well as some words appearing in commercials,...
The tv problems known as a convergence problems,it dead.The colors lines R,G,B mis alignment,have shadows colors pictures or 3D pictures.The tv convergencce board require changing 2 STK convergence ICS and some or all it resistors are dead.The shop,will cost $300-350 for parts and labors.
Sep 11, 2010 | Hitachi 53UDX10B 53" Rear Projection...
No picture .words for the setup menu are shadowed in 3 colors they are also curved .no problem with sound
Thats a convergence failure. you can get the Sony Type 1 convergence repair kit fom www.tvrepairworld.com which should repair that issue. The repair kit also contains the CD with instructions.
Dec 21, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
SONY PROJECTION TV MODEL # KP-51WS510.
If the entire screen is curved, and it is not taking the whole screen, then you have a vertical deflection problem.
If the colors are double and do not match, with lines of different colors around pictures , then you have a convergence problem, often caused by a faulty convergence board.
The curving effect can be a side effect of bad convergence, or you may have both problems at once.
Unless you are a TV repairer yourself, better calling technical support. Usually you can ring the number listed on the owner manual.
Jul 21, 2009 | RCA P52920BL 52" Rear Projection...
Red, Green, Blue curve upwards and cast shadows
that sounds like a typical Convergence IC problem..
http://i.ehow.com/images/GlobalPhoto/Articles/4575598/ConvergenceICs_Full.jpg
this is a picture of what typical convergence ics look like
Mar 12, 2009 | Panasonic PT-53TW53 53" Rear Projection...
Picture is multi color, double shadows, curved
This is failure of convergence out ICs in TV. Qualified TV tech will replace convergence out ICs or board.
Feb 14, 2009 | Philips Televison & Video
RCA 56 inch hdwidescreen
Did you use the Automatica Convergence to try and straighten it out? If that does not help, you can manually adjust the convergence.
Jul 12, 2008 | RCA HD56W58 56" TV
Red shadows
you need to have a complete cnvergence done on it
Jun 12, 2008 | Sony KP-51WS500 51" Rear Projection...
Blue shadows
Sony Too green,red or blue
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Nov 25, 2007 | Sony KP-53HS10 TV
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
42 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
