Question about Maytag MAH6700AWW Neptune Front-Load Washer
Washer continues to fill with water
I have a Maytag model # MAH6700AWW and it still fills with water (slowly) when it shuts off.
  • 96 Answers
Replace mixing valve
Posted on Apr 03, 2013
  • 71 Answers
Replace the water valve
Posted on Dec 12, 2008
I have may tag wash model nu mav5920eww i just hooked it up tried reg wash it filled with water then would not continue to wash went to pause mode
Maytag & Whirlpool washer diagnostic - Fills with water then ...
? 3:03
https://www.youtube.com/watch?v=71zySSScDPE
Jul 11, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot your trusty Maytag Washer that has some of the ...washer diagnostic - Fills with water then cycle stops - LAT8014AAE .... Not agitating Maytag 2 belts top load washers - Duration: 26:55. by theapplianceman 23,820 views. 26:55.Washing Machine Keeps Filling With Water and Will Not Agitate ...
Maytag top loading washing machine stopped working & filled with
Dec 02, 2015 | Maytag MAV5920E Top Load Washer
Hello, On Neptune washer serial # 34098916EF, Washer tub fills with about 2 inches of water within hours after doing a wash. When I spin the tub by hand, I hear water sloshing inside. Machine drains fine....
You have a bad water fill valve. Until you get it fixed shut water valves off at the wall so that you don't have a flood if the fill valve on the machine fails completely. Let me know if there is anything else I can Help you with.
Ken
Mar 17, 2010 | Maytag MAH6700AWW Neptune Front-Load...
Maytag neptune washer wont fill water
It is very possible for it to be a valve failur as these machines have a temperature control incommon, It recieves voltatge through the temp control.
Jan 10, 2010 | Maytag MAH6700AWW Neptune Front-Load...
My washer won't stop filling with water i changed out the water valve and still have the same problem. even when the washer goes in to a drain cycle it still fills with water.... thanks for your help
have you tried looking at the pressure switch? sometimes you can blow through the house that's attached to it and it will clearn things up. give it a try. good luck :)
Jul 15, 2009 | Maytag MAH6700AWW Neptune Front-Load...
Maytag MAH6700AWW Humming Sound
Can you see water in the drum ?,No water = no action Check water supply
If there is water in the drum does it drain out at some point.
Sequence = Fill, Agitate, Heat, Wash, Drain, Spin etc.
If it fills then it may be a belt has snapped and the drum cannot turn , need to take the covers off to look.
Remove power before taking covers off !!!!
If the belt is OK then it may be the heater which has gone open circuit, try a cold wash or a rinse cycle to test that.
May 23, 2009 | Maytag MAH6700AWW Neptune Front-Load...
My Maytag Neptune leaks water from the bottom (immediately) as it fills with water
usually this is from the front door seal going bad remove the front panel and door to replace it
Apr 30, 2009 | Maytag MAH6700AWW Neptune Front-Load...
Water will not shut off, continues to fill
does the water run when you unplug the machine? if so then you have a bad fill valve,
Nov 02, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washing machine it shuts down water filling cycle
First thing to check is the filter,
DISCONNECT power
open the bottom pane (3 screws on bottom front lip)
in the cent is a large removable filter ,
set a pan or rags under it ,there will be water.
clean out any debris an be sure the pump impellers move freely.
let me know if that fixes it.
Jan 29, 2008 | Maytag MAH6700AWW Neptune Front-Load...
Washer fills with water , then shuts off , doesn't move to another cycle
Since you know about the lid and check switches, they are located under the splash (control)panel. unplug the machine and remove the screws holding the panel on. Using a meter check the switches for continuity and replace if they've gone bad.
Jun 06, 2007 | Maytag Neptune MAH5500B Front Load Washer
Water fill
Try unplugging the unit. If it stops filling you have a control board problem. If it continues to fill, you have a bad fill valve that is not closing properly, usually because of dirt or scale buildup thats gotten past the inlet screen on the valve. Good Luck!
Oct 05, 2006 | Maytag Neptune MAH5500B Front Load Washer
Maytag MAH6700AWW Neptune Front-Load Washer Logo
199 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
