Question about Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense...
EF error code on frigidaire refrigerator, help!!! PHSC39EJSS i have error code e f in my refrigerator
  • Frigidaire Master
  • 19,396 Answers
Start unplugging the power cord for ten minutes , ans see if this clears the code.
Posted on Dec 11, 2008
My Frigidaire refrigerator that is in our cold garage has an error code of 5Y on the freezer side and EF on the frige side. What does this mean?
5Y ef means evaporator fan issue. Could be wiring to the evap fan as well.
From the site: "I had a 5y ef error and it ended up being the control board."
Here's a link to a really good video:
https://www.youtube.com/watch?v=gCRKLkk9HmA
Hope this helps:)
Jan 01, 2018 | Frigidaire Refrigerators
How to fix error code H1
Frigidaire Refrigerator Error Code = SY CE
Condition = Communications error at power up
Repair or Check = Check wiring between control board and user interface
Parts Needed = Control board or User interface
Frigidaire Refrigerator Error Code = 4
Condition = Fridge and the control board goes through cycles but does not detect a damper connection
Repair or Check = Check air damper
Parts Needed = Air damper
Frigidaire Refrigerator Error Code = 5Y EF
Condition = Evaporator fan circuit failure
Repair or Check = Check wiring between evaporator fan and control board
Parts Needed = Evaporator fan or control board
Frigidaire Refrigerator Error Code = EF
Frigidaire Refrigerator Error Code = dF
Condition = No defrost circuit
Repair or Check = Check wiring between defrost circuit and control board
Parts Needed = Main control board or Wiring harness
Frigidaire Refrigerator Error Code = H1
Condition = Freezer sensor shorted in freezer display
Repair or Check = Check wiring between thermistor and board. If correct, replace thermistor
Parts Needed = Thermistor (temp sensor)
Frigidaire Refrigerator Error Code = 5y CF
Condition = Communications failure at power up
Parts Needed = Control board or user interface
Sep 28, 2016 | Refrigerators
What do the error codes 5Y and EF mean
Hello Friend, thank you for allowing me to assist you!
If you are getting error code SY EF, it typically indicates that your refrigerator has detected a failure with the evaporator fan circuit. Let's try resetting your refrigerator by either unplugging it or flipping the household circuit breaker to the off position. It is good wait approximately ten minutes and then turn on your refrigerator. If the error code does not clear, at this point it is best to reach out to professional to check the wiring between the main control board and evaporator fan. Hope this helps! - Z
Jul 19, 2014 | Frigidaire Professional 27.8 Cu. Ft....
What does the error code 5y EF mean on my Frigidaire refrigerator
Good Morning Friend,
I understand you are receiving an "SY EF" code on your Frigidaire refrigerator, model# FRS3R5EMB. The "SY EF" code stands for system error with the evaporator fan. This possibly means that there is something going on with your evaporator fan or it could possibly be a false error code. . I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully.
-Best Regards-
WP
Jun 21, 2014 | Frigidaire FRS3R5EMB Side by Side...
What does ef code mean on frigidare refrigerator fsc23f7tdb
Good Afternoon Friend,
I understand you are receiving an "EF" code on your Frigidaire refrigerator, model# FSC23F7TDB, and are wondering what it means. The "EF" code means evaporator fan. This means that there could be a possible issue with your evaporator fan or it could be a false error code. I suggest resetting your refrigerator, by either unplugging it or shutting the power of at your home's circuit breaker, for 3-5 minutes. Restore power. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 16, 2014 | Electrolux Washing Machines
What does error code sy ef mean ?
I understand you are receiving an SY EF code on your Frigidaire refrigerator, model# FGUN2642LF. This code states there is a system error code that deals with the evaporator fan. This could also be a possible false error code. I suggest you reset your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Once power is restored, you will need to press the "Mute Sounds" button to stop the power failure alert. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your refrigerator status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 13, 2014 | Frigidaire FGUN2642 Stainless Steel Bottom...
What does "Sy EF" mean on dispenser led?
Error Code SY EF is the System Evaporator Fault.
This usually means there is NOT enough air flow over the sensor, this can mean a faulty sensor, or fan.
Above is the latest service sheet to do with your machine, you need to check this.
Hope this helps (remember to rate and commnent this)..
Jun 03, 2011 | Frigidaire 26.0 Cu. Ft. Side-by-Side...
I have a Frigidaire refrigerator "Phsc39ejss" and
replace the main control as it has failed . the new one is improved .. mm feed back pls replace the sw membrain and the electronic control .. mm hope this helps .. feed back please
Jan 01, 2011 | Frigidaire Refrigerators
Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense... Logo
762 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
