Dell Latitude D630 Touchpad/Pointer
In the Dell Touchpad settings app, I've selected "Disable Touchpad/Pointing stick when external USB mouse is present" and this works fine. However, when the mouse is removed, the Touchpad/Pointing stick remain disabled. This happens even if I re-boot (the "touchpad driver notification" message even comes back up indicating it has been disabled because an external USB mouse is present...despite the fact that there is no mouse present). The pad/stick remain functional, as they work fine if I remove the check from the "Disable when mouse is present" box. Ideas on how to fix this?
  • 1 more comment
  • rgrigg Dec 12, 2008
    Well, I can't have the touchpad functional when I'm using a mouse, as I constantly brush up against the pad while typing...curser moves all over the place. I just need a way to get the Touchpad to correctly recognize when I do NOT have an external mouse connected.
  • Atom Biggs
    Atom Biggs Jan 02, 2009
    I used to be able to adjust the pressure sensitivity of the touchpad but there seems to no longer be a touchpad tab on my mouse properties.
  • Anonymous Feb 19, 2009
    Need ability to disable touchpad and stick while typing.
    Master:
  • 461 Answers
Do not check the check box as leaving the touchpad enabled while using an external mouse will not cause any harm.
Posted on Dec 12, 2008
Disable dell e6410 touchpad when mouse is connected
Hi, you can do this by going into the control panel> Mouse> Touchpad settings> disable touchpad when other external usb pointing device is connected.
Nov 13, 2017 | Dell Latitude E6410 Laptop
Cursor problem
Disabling the touchpad on a Dell Inspiron can be useful when typing for long periods of time, or using an external mouse. Bumping or tapping the touchpad while typing can cause cursor jumping and unwanted results. Use the touchpad software to enable or disable touchpad controls. Download the driver for your touchpad at the Dell Support website.
Click on the "Touchpad" icon in the task bar. If the icon doesn't appear, you can download and install the driver for the touchpad from the Dell website, or choose "Start" and "Control Panel." Choose "Device Select" on the touchpad menu, or choose "Mouse" in the "Control Panel" menu and "Device Select." Click "Disable" under "Touchpad" to turn off the touchpad, or click "Disable Touchpad/Pointing Stick When a USB Mouse is Connected."
h
Feb 28, 2013 | Computers & Internet
Touchpad/Pointer do not function when pressed/glided ...Dell Latitude D410 w/ Windows XP Facts / what i've done: 1. BIOS - is set to use both Touchpad and external USB mouse 2. Turn computer off &...
Hi! Welcome to www.fixya.com.
You can try to download the Alps driver in this Link; http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=19&l=en&s=dhs&ServiceTag=&SystemID=LAT_PNT_PM_D410&os=WW1&osl=en&catid=&impid=
If nothing happens after reboot: Its definitely a hardware issue. You have to call out fo warrant department your manufacturer so it will be fix.
Hope this resolution fix the problem on your computer. Thanks for contacting Fixya. Bye for now.
Jul 26, 2011 | Dell Latitude D410 Notebook
Want to disable the touchpad. When I type i accidenlty hit it and it makes the cursor move.
First, make sure the device drivers for the touchpad are installed.
Once the drivers are installed, open Control Panel --> Mouse --> Dell Touchpad.
Click on the large screen with an arrow, which will open the touchpad configuration window.
Click on 'Device Select', and right at the bottom is a box which you can tick to 'Disable Touchpad/Pointing Stick when a USB mouse is connected.
As soon as you tick that option, a message will pop up in the taskbar, confirming your selection.
You can make doubly sure however, by also choosing 'Disable' under the Touchpad' heading in the same window.
Be sure to click 'Apply' once you've made your selections.
Mar 06, 2011 | Dell Latitude E5400 Laptop
I can not disable touchpad of INSPIRON 1545 of DELL Computers There is no option for disabling touch pad in the MOUSE option of Control Panel
Go to the Control Panel. Under the 'Hardware and Sound' options, click 'Mouse'immortal4u.png
Since you have a Dell laptop, you'll have a special tab called 'Dell touchpad' in the window that pops up. Click on the touchpad picture in the window.
In the new window that appears, click 'Device Select'
Click on the 'Disable' radio button to disable the touchpad completely. If you want to disable the touchpad of your Dell laptop only when an external device like a mouse is attached, check the last option that says 'Disable Touchpad/Pointing Stick when external USB mouse is present'
That's it. You've disabled your laptop's touchpad for good. If you don't find an option to manage your touchpad in Mouse settings, you have to install Synaptics drivers from here. Similar options can be found in other laptops as well.
Good luck ! if your problem is solved don't forget to rate
Dec 30, 2010 | Computers & Internet
How do i disable the touch pad on my Dell Lattitude E5400 laptop? Thanks, Tom tc@tc-talent.com 917-733-5968
You can turn off the touch pad through the mouse settings in the Control Panel. I was a little frustrated by this too, but if you go to the Control Panel and click 'Mouse', the first tab of this new window is 'Dell Touchpad'. Simply click anywhere in that window and you'll be able to configure the touch pad settings. One great option for many people is 'Disable Touchpad/Pointing Stick when external USB mouse is present' as there is no easy one-button solution to disable it.
* Please rate this solution with Thumbs up and comment to help us improve providing support
Nov 30, 2010 | Dell Latitude E5400 Laptop
How do I disable the touch pad on my Latitude E5400? The curser jumps all over when I type. On my other laptops, there is a button clearly marked to disable the touch pad and this has solved the problem....
  1. Click Start.
    Go to Start, click Run, type main.cpl in the box next to Open, click OK.
  2. Click the Dell Touchpad tab.
  3. If you are not getting the Dell Touchpad tab, update your driver, you will get the Tab.
  4. Click on the picture of the touchpad.
    Click Device Select.
    Click to check the box to the left of Disable Touchpad / Pointing Stick when external USB mouse is present.
    Click Apply, then click OK.
  5. Click the X in the upper-right corner to close the Dell Touchpad Utility.
Aug 31, 2010 | Dell Latitude E5400 Laptop
Dell 1545...... How do you disable the touch pad.
If you double click on the touch pad icon in the task bar it will bring up the Dell Touchpad Settings. Then click "Device Select / Button Settings". There should be two tabs there. Make sure "Device Select" is selected, and at the bottom of this tab, there should be a check box that says "Disable Touchpad/Pointing Stick when external USB mouse is present".
If you cannot find those settings, they may also be in the BIOS. Try pressing F2 while booting and look around in the BIOS for a similar option.
Aug 15, 2010 | Dell F3534 Touchpad
How do I disable touchpad when mouse is used DELL 1525 vista home
Follow these steps to change the touchpad settings on your laptop:
1. From the Start menu, click Control Panel. With Control Panel in Category View, click Printers and Other Hardware.
2. In the Printers and Other Hardware window, click the Mouse icon.
3. In the Mouse Properties dialog box, click the Device Settings tab, and then click Settings.
4. There is a setting calleed "Disable Touch Pad when USB Pointing Device is present"
Jan 28, 2010 | Dell F3534 Touchpad
Dell Laptop Trackball Too sensitive!
Go to control panel. Select mouse. In the window that opens, select the dell touchpad tab. Click where it tells you.
Then, on the bottom left of the next window that opens, select "pointing stick settings." Uncheck the "tap to click" and the TouchCheck "Enable" boxes.
That seemed to work for me. you can also disable the touchcheck on the touchpad.
Aug 11, 2007 | Dell 0Y3740 Keyboard
Computers & Internet Logo
8,471 people viewed this question
David Payne
David Payne
