Question about Toshiba 53H71 53 in. Rear Projection Television
Samsung SP42W4HPX I Have a Samsung rear projection tv,Picture is gone all green. we had a engineer out and he advise that the power Convergence board needs replacing and this item is no longer available.Can anyone advise where i can get this item or fix it as the tv is only 3 years old and i dont want to dump it.
  • 2 more comments
  • aine reilly Mar 07, 2007
    i have had a technician out and he said it was the convergence board,The picture is outlined in green,do you think i can get this fixed.Technician said part is no longer available
  • aine reilly Mar 10, 2007
    the model of my tv is samsung sp42w4hpx/xeu 107cm pr.Thank you for your help
    President:
  • 1,284 Answers
The convergence wouldn't cause it to go all green. Green outlines yes but, not all green. Get a technician to look at it.
Posted on Mar 07, 2007
  • Don
    Don Mar 08, 2007
    Can you get me the full model number on the TV..Such as HLS42xxxx/XAA or whatever it reads and email it to tvtek@msn.com and I will do some research.
SOURCE:
The picture has a green outlined shadow
Please do us a favor and rate this solution after reading.
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 11, 2011 | Philips Magnavox 9P6034C 60" Rear...
LG Projection TV Model# RT-49NA11T Green color gun shows bent arc on top & bottom.Red & blue guns are ok.How to adjust the green gun to remove the bent arc. This is causing picture shows mix...
This problems ur tv have can't not be fix by adjustment.The tv have a problems known as convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to repair the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Jan 10, 2011 | Panasonic PT-53WX53 53" Rear Projection...
Picture is not showing correctly. Color seems like it is going out. For example the color green does not show up as green.
Tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors are dead too.These parts on the tv convergence board,must be change to solved the tv picture convergence problems.Try website like Tvrepairworld.com to buy a whole refurbish convergence board for the replacement.The Akai/Samsung DLP tv used the same convergence board.Or the shop,will cost u like $300-350 for parts and labors.
Nov 20, 2010 | Samsung PCL541R 54" Rear Projection...
THe picture is either yellowish green or yellowish orange. And has squiggly lines thru the picture. What needs replaced?
Tv have a problems known as a convergence problems,it dead.The tv convergence board have dead 2 STK convergence ICS and some or all it resistors are dead.Try website like Tvrepairworld.com to buy a whole rebuild convergence board for the replacement.The Samsung/Akai tvs using the same convergence board.
Nov 06, 2010 | Samsung HCN4226W 42" Rear Projection...
We own the PT51HX41 51 inch rear proj. We are getting a green and red glow around all pictures and wording. Are the bulbs gone or do they need to be adjusted...
The tv have a problems known as a convergence problems,it dead.The tv have colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors.These parts on the tv convergence board are dead,must be replaced on the tv convergence board to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 05, 2010 | Panasonic PT-51HX41 51" Rear Projection...
I have Samsung SP42W5HF rear projection tv and
You have either a bad convergence IC on the power supply/convergence board or the whole board is bad and needs to be replaced along with doing a Full Convergence Alignment by a very experienced tech.
Apr 09, 2010 | Samsung Televison & Video
Red green wavy color on top of picture with distorted faces and bottom of picture seems o.k.
Ur convergence is dead.The Convergence board must repair or replaced.Samsung/Akai use the same convergence board.Try website Tv repair world.com.Buy the whole board replaced it the best.
Jan 15, 2010 | Akai PT5598HD 55" Rear Projection...
Rear projection tv screen warped
HI, this is typical convergence chip failure. you will need to replace the convergence board in this set asap. this will fix this issue you are experiencing.
May 23, 2009 | Samsung Televison & Video
Samsung SP42W4HPX
convergence boards for a tv are kind of hard to come by after 3 years old where did u buy the tv? if from sears you can goto the site and look up the parts or contact the manufactuar directly on there site for a parts section. www.samsungparts.com i tried to look up your model number said it was invalid try that and good luck also convergence boards have a dcu on the board looks like a small motherboard and u might have to take the old one off and put it on the new one with solder GL hope it helps
Mar 21, 2007 | Toshiba 53H71 53 in. Rear Projection...
Toshiba 53H71 53 in. Rear Projection Television Logo
156 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
