Question about Garmin Nuvi 360 Bilingual GPS Navigator and Personal Travel Assistant GPS Receiver
Damaged screen garmin nuvi
I placed my garmin nuvi face down against my garage door opener and covered it with the arm rest in the car. I have black spotches on the screen now, and not able to view the screen. Can this be repaired, and at what cost, or should I just get another one?
  • Garmin Master
  • 2,130 Answers
Please see this link:
http://www.sharc.net/gps_LCD_repair.htm
- Jim
Posted on Apr 19, 2010
Reset
I would suggest you reset the unit,if that doesn't solve the problem, then you will have to update your garmin nuvi, I think its out of date and needs to be updated. Follow the procedures below on how to update your garmin nuvi:
1. Plug one end of the USB cable into your GPS and the other end into your desktop or laptop computer. The GPS device will load the appropriate driver automatically, and a message on your GPS tells you that it is connected to your computer via USB.
2. Open your Internet browser of choice and type in the following web addres: "http://www8.garmin.com/support/collection.jsp?product=999-99999-27 "
3. Download the appropriate version of the software for your computer (Windows or Apple) and Install the WebUpdater by following the wizard (accept defaults).
4. Click "Start," "Programs," "Garmin" and " WebUpdater" to update your firmware and your maps. Periodically check and make sure your software is current.
Also, in case you don't know how to reset your garmin nuvi, you can follow the steps below: There are two types of reset;
Performing a Standard Reset
1. Slide the power switch all the way to the left (with the Nuvi's screen facing you).
2. Hold the switch in the position for at least eight seconds.
3. Push the switch to the right to power the Nuvi back on.
Performing a Factory Reset
1. Turn your Nuvi off by sliding the power switch to the left.
2. Press your finger against the bottom right corner of the touchscreen. Hold your finger in this position.
3. Slide the power switch to the right to turn the Nuvi back on. Continue to hold you finger against the screen until you see the factory reset prompt. Tap "Yes" to perform the factory reset.
Good luck
Dec 06, 2011 | Garmin Nuvi 1490T 5.1 in. Car GPS Receiver
Hard reset
Good luck...
2 months old noticing touchscreen won't respond all of the time. Is there a screen sensativity adjustment? Also sometimes it locks up on power up at loading maps. Thanks, Rick Jackson
unfortunately, there is no screen adjustment on your Gps. I would suggest you reset the unit,if that doesn't solve the problem, then you will have to update your garmin nuvi, I think its out of date and needs to be updated. Follow the procedures below on how to update your garmin nuvi:
Good luck
Sep 25, 2010 | Garmin nuvi 1300 Car GPS Receiver
Garmin nuvi freezes up. Only way I've found to solve the prob is to unplug it and let the battery run down.
Take care.
Sep 16, 2010 | Garmin Nuvi 660 GPS Receiver
The screen freezes on my Garvin nuvi 1300
Best regards
Jul 20, 2010 | Garmin nuvi 1300 Car GPS Receiver
My garmin nuvi 250 is now only in spanish - I want english
Hello, you should be able to achieve this by resetting the GPS since its default is English.
Good luck
Jul 19, 2010 | Garmin nuvi 250W GPS Receiver
My Garmin Nuvi 1390 has frozen on the 'loading maps' page I turned the unit on holding down the bottom right hand corner clicked yes when asked do I really want to erase all user data. What if the device...
Take care.
Jul 04, 2010 | Garmin nuvi 1390T Car GPS Receiver
Cracked LCD screen for Garmin Nuvi 255w
Hello
Try here www.satnavrepairservice.com
Mar 04, 2010 | Garmin nuvi 255W GPS Receiver
Door will not open with or without motor
It sounds like that missing pin is your problem, the trolley attached to the arm with the pin. Its hard to diagnose, but call in a Door Opener guy and he can probably fix it in a few seconds for free. Otherwise, try and find the pin or something like it to fix the arm in place and see if you can MANUALLY operate the door that way. BTW, Disconnect from power before you try and experiment.
Feb 19, 2009 | Sears Craftsman LiftMaster Chamberlain...
Motor is driving only one direction counter clockwise that closes
TRY UNPLUGGING FOR ABOUT 5 MIN.
THIS RESETS THE CIRCUIT BOARD.
IF THIS DOESN'T HELP TAKE OFF THE COVER AND LOOK AT THE LIMIT SWITCHES IT MAY BE RESTING AGAINST THE UP LIMIT - THIS WOULD TELL THE DOOR TO CLOSE - THE CHAIN MAY NEED TO BE SHIFTED - WITH THE DOOR FULLY CLOSED AND THE OPENER RESTING AGAINST THE CLOSED LIMIT REINSTALL THE CHAIN. & THEN RECHECK ALL ADJUSTMENTS
HOPE THIS HELPS
Dec 22, 2008 | Sears Craftsman LiftMaster Chamberlain...
GPS Logo
44 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
