Question about Whirlpool RBS305PD Electric Single Oven
Oven will not heat after self cleaning
Self cleaning was done know it will not heat up elements good
We used the self cleaning feature on our RBS305 Built In Electric oven and afterwards it would not heat. replaced the Fuse-Thermal part Nr 9759243 (which is the new part number. (Shown as Nr 37 on the Parts list for the oven parts). Cut all Power to the oven off and it was very easy to pull oven out with help of my wife. Removed back, bought a new part for 49.55 plus tax. Put in new part, replaced back and oven works like new. I am a 73 year old senior so when I say it is fairly easy to replace you know it is. Hope this helps someone
Posted on Feb 19, 2009
After self cleaning now won't heat up
Self cleaning superheats the oven to burn off the dirt to ash. Unfortunately it can also burn out elements and the wires that are attached to the elements.
Disconnect again and check the timed oven settings. If no go, you need a service engineer.
Apr 16, 2016 | GE Profile JT952 Electric Double Oven
Why doesn't oven work after using the self- cleaning mode?
Check for incoming power; you may need to change the heater element.
Sep 11, 2015 | Whirlpool GBS307PD Electric Single Oven
Oven won't heat
You may have a blown thermal fuse in series with the heating elements. If the oven exceeded the maximum allowable temperature during self-clean, the fuse will open. See this discussion:
Oven Failure After Self Clean and F1 Errors
Aug 22, 2014 | KitchenAid Ovens
My oven will not heat up to temperature
It may be the bake element that has gone out. The self clean usually uses the broil element to heat the oven. And most oven will either put 120 volts to the broil element while baking or pulse the broil element while baking. This will cause the oven to get warm but not hot. Check the oven bake element it cound be bad or a wire may have burned off.
Feb 14, 2014 | Ovens
Ran self clean now oven will not heat up
Turn the breaker off for 5 minutes then turn it back on see if this helps if not let me know.
Sep 27, 2011 | Whirlpool RBS305PRS Stainless Steel Oven
We purchased our Frigidare Double Oven, Model Number FPET3085KFA, October 2009 (15 months ago). We ran the self-clean process for the first time yesterday on the top oven using the 4 hr option and it...
try turning your breaker off for 20 minutes, then try it again,, if this does not help it could have burnt out a element or the main board has went out,,, also make for sere you are getting the full 220 volts to the unit,, this will involve taking the unit out
Jan 19, 2011 | Frigidaire 30 in. Electric Gallery Series...
Upper oven elements don't heat
Hello- 'Successfully' sounds like you were forewarned....  During the 'self-clean' cycle a circuit or connection to the upper elements burned out while attempting to turn stuff inside the oven to ash. Since this is a wall oven my recommendation is for service from a good tech in your area. You may have lucked out with a fried connector, but many times control board is damaged beyond repair and must be replaced. Only on-site diagnostics will confirm, and this is a very heavy unit for most owners to safely service.  - Remember- Don't use 'self clean'!! Scrape and clean with soapy water and cloth. Turn on oven to 450deg. for 30 min. Much safer. Less costly.       Please acknowledge this post if the info is helpful- Have more if needed.  Thanks-  Ed
Mar 23, 2010 | Jenn-Air JJW8230D Electric Double Oven
Heat elements in oven/broiler do not heat up
I would say to go and reset your curciut breaker first if this is a electric oven. needs 220 volts for both element to work
Jan 03, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Thermador SM272 - Oven not heating after self clean cycle
Your repairman might be right but I would have checked the main heating element first for this reason: The self-clean cycle uses that same element as you need for the oven but is allowed to rise to a much higher temperature (~ 900-950 degrees) during the cleaning cycle and it may have self-destructed. Since your problem started after the cleaning cycle, I would have checked the element for continuity first.
Sep 23, 2008 | Thermador Professional Series PO301...
My Dacor wont heat, broil or convection after self cleaning. No heat but everything else works The bake, broil, and convection elements on my Dacor CPS130 electric wall oven will not heat.  The oven has...
like another person stated-from the front behind the door, take off the 6 screws and the cover by the latch. there is an "oven hi temp limit switch" It is crome with 2 heavy black wires connected to it. On the back side of this is a small red button which will reset the limit switch. I had the same issue (everything worked except the any of the heating elements) and quickly resolved.
Jan 07, 2008 | Ovens
Whirlpool RBS305PD Electric Single Oven Logo
456 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal DeAngelo
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
