Room thermostate rdj10rf not responding - Heating & Cooling
  • Ken Bledsoe May 11, 2010
    Can you turn the fan switch to on from auto and the fan comes on?
Check out this URL for a solution.  http://www.fixed4free.com/answers.php?id=90092
However, it is possible that your controller unit has failed - from my internet research, I see that lots of people are complaining about the controller unit failing or not ever working, not even straight out of the box. We ourselves had our first controller (or as you call it, thermostat) in Dec 07, it had to be replaced in June 08 because it no longer transmitted, and now, during this very cold spell over Christmas, it has failed again!
Posted on Dec 27, 2008
Why my portable af8000e av stop blowing cool air
You mean it stops cool air but still it is blowing,
1. Check your thermostate settings.
2. Check room sensor in fixed in correct position.
3. May be faulty room sensor(air sensor). Replace it.
Sep 02, 2015 | Heating & Cooling
Need a fault finder for a Siemens thermostat
is that line or low voltage? 240/120 or 24/12v
Jan 23, 2013 | Electrical Supplies
Stuck on 75 degrees. Won't respond to buttons or remote
The thermostat sounds like it's bad. If it was good, you could change the temperature settings. The thermostat has to send a signal to the control board, and if it's bad, that just won't happen, and no cooling can occur.
If this unit is a room air conditioner, here is how to check the thermostate on it:
http://home.howstuffworks.com/home-improvement/heating-and-cooling/how-to-repair-room-air-conditioners.htm
Good luck, and hope this helps.
Jun 02, 2011 | Maytag MEY18F7G Air Conditioner
Fridge freezer is not workink,light is on freezer but no sound,freezer is in a cold room is it possible the room is to cold and problem with thermostate?
It could be a compressor problem, or the cold control. If your room is above freezing, the freezer should still run.
Jan 07, 2010 | Freezers
Manual for Thermostat Siemens RDJ10RF
THE BOILER READS ROOM STAT OFF, BUT IN ACTUAL FACT IT IS ON, PLS ADVISE WHAT TO DO
Nov 08, 2009 | AT&T Siemens S46 GSM Cellular Phone
I have two ptac units, both want to run 5 or 6 mins. and cut off
Make sure there is nothing in front of the units, Chair, Couch ect, if you take the cover off the Units, you will see a little black Thermoster attached to the coil.
If the air bounces back off of something then it will cool that Thermoster and shut the unit down before the desired room temp is acualy reached.
Also make sure your Thermastat control knob is turned far enough to the right so that its asking for more cooling, Or desired temp.
Hope this helps.
Good Luck!
Oct 26, 2009 | GE Zoneline Deluxe Series Cooling &...
The buttons on my duo therm thermostata not responding
there is a one somal swicth in thermostate you put there (WD40)and trun back and farwead then bring same place
Jul 18, 2009 | Dometic Rooftop RV Air Conditioner
PROGRAMMABLE ROOM THERMOSTAT
I found this on a search:
"I have the full set of instructions, contact me at gjb@eggconnect.net
Not a very reliable system, transmitter keeps resetting to 17:25; locks up. Whole system then requires setting up from scratch. Had a replacement transmitter, no change, and same faults.
GJB"
Perhaps this can help.
Mar 15, 2008 | Computers & Internet
Heating & Cooling Logo
649 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
