Question about Samsung SRP 350 Thermal Printer
Sharing srp350 network printer on win98 to winxp
We have a Samsung SRP350 Network printer installed locally on Win98. The printer is being shared out to a WinXP machine. The SRP350 will communicate to WinXP just fine and is able to print. The problem is that on the XP machine, the features such as Autocut paper and line feeds do not work on the XP machine and the printer prints a little slow. Although i can get the printer to share and print on the XP machine, I need to know how to get it to autocut and line feed through WinXP? Is there a conflict with Win98 sharing to WinXP with full printer supported features??? I have no problem going from an XP machine to Win98 sharing, but when reversed, it does not work. Thanks, Rob
  • Rob Perry Mar 07, 2007
    True, so what we have done next is started new, no drivers or software on the XP machine. we then installed the XP driver on the XP machine and went to Add New Printer and located our SRP350 on the Win98 machine. I then tried to do a test print, which did print, but the settings are still not carried through to the XP machine. I have tried to change settings both on the local printer driver on the XP machine as well as the shared driver on the Win98 machine to try different things but still the same results. Hmmmm...
I have a samsung printer model srp-350pg, anytime trying to print it is printing giberish cherachtors
Please help me on that
Posted on Jul 21, 2008
    President:
  • 2,961 Answers
You are correct with the conflict, although, it's a difference in drivers, i think what has happened is when you share a printer with xp, it installs the driver from the pc with the driver and printer attached, and as it is attached to a win98 pc, the full functions are probably unavailable,unlike an xp local driver.
Posted on Mar 07, 2007
  • andrew pester
    andrew pester Mar 07, 2007
    You will get the same response, as the driver used will still be the generic driver from the Win 98 pc as that is where the printer is connected, it will not make use of the xp installed driver because it's a network printer, so to get full utilities it has to be attached to a Win xp PC or connected direct to your XP pc for them to work in full, as file and printer sharing work slightly different on Win98 and XP.
Need for driver
Your printer sounds like it might be a bixolon srp-350 badged as a samsung. I dont know if there are android drivers for SRP350. There is an android sdk for SRP350ii. Anyway this is the site where you will find them if they exist - http://www.bixolon.com/html/en/download/download_product.xhtml?prod_id=3
May 30, 2013 | POS X BIXOLON Samsung Kps SRP350 Thermal...
I have a SRP350 thermal printer that prints faint, is there a setting that makes it print dark? Thank you
The printer has some dipswitches under the panel on the bottom of the printer. Dipswitch 2-5 needs to be OFF and dipswitch 2-6 needs to be ON for darkest print. Default is medium. This printer is 180dpi so recommend using double size characters for darkest printing.
Aug 24, 2011 | POS X BIXOLON Samsung Kps SRP350 Thermal...
I have bixolon srp 350 for my restarant when i give print command from register it always comes in queue with showing error. i done all softaware re installation and self test for printer everything works...
hello, im trying to send a print to my BIXOLON SRP350 Thermal printer by java codes. but java can't use the all the page width, what should i do to use all of the page width ?
Feb 20, 2011 | POS X BIXOLON Samsung Kps SRP350 Thermal...
Is it possible to connect my ASUS X58C laptop to a Win98SE pc
Connect the two computers using the Ethernet crossover cable.
On the computer running Windows Vista, from the Start menu, click Control Panel. Then, double-click Network and Sharing Center. Note: If this doesn't match what you see, switch yorur control panel to classic view..
At the top of the main portion of the Network and Sharing Center window, double-click the Unidentified Network icon.
If network discovery and file sharing are disabled, the following message will appear:
"Network discovery and file sharing are turned off. Network computers and devices are not visible. Click to change..."
Click the message to enable network discovery and file sharing; you may be prompted for an administrator username and/or password.
In the dialog box that opens, select No, make the network that I am connected to a private network. This allows you to initiate file sharing on the two computers without affecting the settings for any other networks.
Icons for both computers should now be visible in the Network window. Double-click a computer icon to share printers and other resources.
Mar 28, 2010 | Computers & Internet
How to install this printer on win 98 which is connected to Linex OS of other computer
In order for this to work, the Linux computer must be running SAMBA to share it so a Win98 computer can see it on the network. Setting this up differs per Linux distribution. Look through the list of installed packages for SAMBA, then you must go through the process of sharing it correctly. Update post with how the printer is connected to the Linux PC (usb or parallel), and which LInux Distribution.
Aug 17, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
I am trying to set up networking between 2 computers sharing an internet connection. The XP machine is up and running. The Windows 98 machine never had networking; I installed a CNet PRO200 PCI networking...
Have you seen this article? It may have to do with the cable setup. See #8.
Good luck...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Aug 10, 2009 | Cnet Pro200 Network Adapter
Sharing Printer on Network
hi dear
in your main computer
sharing your printer first
and in other computer
add printer
as network printer
nrowse your main computer find your printer sharing
yo needn't to install driver
oke
Mar 27, 2008 | Kyocera FS-3900DN Laser Printer
Not supports bi-directional printing on win98 + winxp network
this is compatability problem. You should install your printer on Windows XP system. Then make it share for all. I think it will print from both 98 and XP. try this.......good luck.
Thanks
Iqbal
Mar 26, 2008 | Canon LASER SHOT LBP-2900 Printer
Sharing with Samba/Cups
To my best knowledge, you cannot. The drivers and scanning software on your unit are not designed to support network protocols. Your unit does not come with an Ethernet adapter and it is not available as an option. When Samsung fits an equipment with a network card (such as the SCX-4521FN) the drivers and software are enabled for network use. By the way, your toner will only last for 3,000 pages. Are you sure it's a good idea to share such such a small unit over a 10 PC network?
Sep 25, 2007 | Samsung SCX 4200 All-In-One Laser Printer
Win 98 PC Not Have Domin Connetivety
Setup the Cabling properly. Enable file printer sharing under network settings. Both computers need to be on the same Work group.
Sep 18, 2007 | Microsoft Windows 98 for PC
Samsung SRP 350 Thermal Printer Logo
212 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Victorman
Victorman
jasbo
jasbo
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
