I want to turn the wireless function off in my Belkin NWireless Router F5D8233-4 so that I can use it just as a router because I have run cable to all my devices to overcome security issues. I have logged in to the control software using http://192.168.2.1 but cannot see where to turn the wireless function off. Can you please advise how I can do this.
  • 4,338 Answers
I have the same router, this is good to know.
Read page 43 in this manual (or 46 on the bottom of the reader window). The is a Wireless Mode Switch, but it states that you may need a firmware update to access it;
http://cache-www.belkin.com/support/dl/f5d8233-4_v1_manual.pdf
copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Dec 12, 2008
    Novelist:
    Scholar:
  • 85 Answers
Ok on the left menu under the word "Wireless" click on "Channel and SSID"
Then go to "wireless mode" and select "off"
see pic bellow
Posted on Dec 11, 2008
Can i setup the belkin f7d4302 as a wireless bridge
belkin does not support this. The only way you can do it is by running a cable to the router to extend your wireless signal around the house. I did a similar setup with a powerline network adapter if running a cat5 cable is not a option. just make sure you change the main ip address for the 2nd router to like 192.168.2.2 and disable dhcp since the main router will handle dhcp. also make sure the wireless settings are the same and channel is different if 1st router is channel 1 then use channel 6 or 11 for the 2nd router.
Feb 26, 2012 | Belkin Wireless Play Router (F7D4302)
I'm try to connect my pc through a belkin wireless router, but haven't been successful. I have loaded the belkin software and we are on the talk talk network but it will not connect. Please help
You can configure it with below method.Need to configure it .
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. Then click on WAN settings set it as your internet service provider settings enable DHCP Then click on wireless and enable it. . Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
Sep 09, 2011 | Belkin Basic Wireless Router
Cant get connected with my belkin router...all i can get is "connected with limited access
HI
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} How to quickly install and use your Belkin wireless G router
1. Step 1 Position your Belkin wireless G router.
Place your wireless G router in a wide open and central location. Don't connect the power plug into the router, yet. Make sure your computer is turned off.
2. Step 2 Connect all the devices.
Find the Ethernet cable that connects your PC to the modem. Unplug the Ethernet cable from your PC and insert it into the wireless G router's WAN port. You should have an additional Ethernet cable that came with your router. Take this cable and plug one end into one of the LAN ports on the router. Then connect the other end to your PC's Ethernet port.
3. Step 3 Turn on your modem, router, and PC.
Plug the power plug adapter into the modem. Turn on the modem. It'll take approximately 30 seconds for the modem to boot up. Connect the power plug adapter to the router and the other end into a power strip or outlet. Like the modem, it'll take about 30 seconds for the router to boot. Turn on your PC.
4. Step 4 Verify lights are on for your devices.
Make sure the following lights are on for your router: power, WAN, and LAN light. If you don't see any of them lit, confirm these devices are turned on. Make sure the Ethernet cable connections are installed correctly.
Step 5 Install and configure software.
Use the setup wizard application to configure your Belkin wireless G router. Set up features, such as creating your password and setting up your time zone. Continue to follow the setup wizard so you can configure ?other settings
Oct 18, 2010 | Belkin N1 Wireless-N Wireless Router
I bought belkin g wireless modem ruter but they didn't give me CD . How can i install this and how can i use my wireless ruter please. Thank you.
Power-off your cable-modem (or DSL-modem).
Use an Ethernet cable to connect from the modem to the WAN port on your router.
Use another Ethernet cable to connect from one LAN port on your router to the network-port on your computer (desktop/laptop).
Turn the modem on.
Turn the router on.
Turn the computer on.
Click Start
Click Run
Type CMD
Press Enter
Type IPCONFIG
Press Enter
Look for output like:
Default Gateway . . . . . . . . . : 1234.678.0.1
Start Internet Explorer
Type http://1234.678.0.1
to access the web-server "inside" the router.
Run the Network Setup Wizard.
Run the Wireless Networking Setup Wizard,
to pick an SSID, an encryption-level (use 'WPA')
and to pick a network-password.
Now, you can disconnect the Ethernet cable from the computer, and try using the wireless-adapter inside your computer.
Sep 20, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
My computer no longer recognizes my belkin router as a wifi access point. It's as if it stopped working. Any ideas?
Belkin products are all built from Refurbished materials. It is entirely possible that your wireless access point has simply stopped working. Try going in and restarting the wireless function on your router, you'll need to be plugged directly into the router via an Ethernet cable to do this though, if the wireless is not working.
May 17, 2010 | Belkin (F5D7230-4) Router (587009)
I have a Belkin router and i don't know hoe to cennect my laptop to my main broadband at home ,what do i do with the yelow cable do i connect the router to my laptop ? I have no clue and it;s really...
Here's how to connect the router.
From your broadban modem, connect the ethernet cable to the Internet/WAN port of the router. Then using another ethernet cable, connect your laptop to port 1 on the back of the router. Now run the setup CD that came with your router. After setting it up, it will tell you to disconnect the ethernet cable from your laptop to try the wireless function. Good Luck!
Oct 06, 2009 | Belkin (F5D8231-4) Wireless Router...
PLAYSTATION WONT SIGN IN KEEPS SAYIN DNS ERROR
You must change the wireless channel of your router and do a power cycle. Just turn off your router for 30 seconds then turn it back on.
Jun 09, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Belkin Wireless N router/Embarq 660 modem/No internet
Make sure your physical connection is correct. From the modem, the ethernet cable should plugged in to the Internet/WAN port of the router. And your computer to port 1. Access the setup page of the router again and Enable the MAC Address Clone setting. Clone the MAC Address of your PC there then power cycle the router and modem. You should be all set.
Apr 15, 2009 | Belkin (F5D8231-4) Wireless Router...
Computers & Internet Logo
65 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
