Question about GE Optical 98802 Mouse
Can't open GE Optical Mouse to replace battery
I've pulled on both ends, pressed on the front to release the back, etc. Nothing works.  Please help
  • JimsBabe Jan 09, 2009
    Exactly what the previous poster said. I'm afraid if I force it, I might break it. Where's the magic button?
    President:
  • 8,637 Answers
Normal 0 If the mouse doesn't have a little door to open on the bottom, then try this. Just behind the Left and Right keys where your hand rests, apply firm pressure down on the cover and slide to the rear. Some mouse manufactures have used this type of access to replace the batteries.
Hope this helps. Bud
Posted on Jan 17, 2009
PC recognize wireless mouse GE 98808. Install driver succesfully. Mouse not working
Check the batteries and the receiver,
You can remove the batteries for 2 mins. and put it back in, also you can try to restart the wireless receiver.
Feb 21, 2010 | GE Wireless Optical Mini Mouse 3087897985
How do you replace the battery
Battery Installation
Battery Compartment Cover
1) Grip the front of the mouse (the end with the buttons) with your left hand.
2) With your right hand hold the back of the mouse (end opposite the buttons) with your thumb on the bottom, and your index finger and middle finger resting on top.
3) Grip the mouse firmly, pressing down slightly on the GE logo on top of the mouse with the index and middle finger of your right hand, then pull back to release the battery cover.
4) Set the battery compartment cover aside. Insert 2 AAA batteries, being sure to match the polarity of the batteries with the polarity markings inside the battery compartment.
5) Replace the battery compartment cover.
6) Re-link your mouse. See Section 5.
Dec 10, 2009 | GE Wireless Optical Mini Mouse 3087897985
How do you change batteries in the wireless optical minnie mouse?
you will need two new AAA batteries, then:
e264c6a4ce3d69934c8bb459d43674dc.png e264c6a4ce3d69934c8bb459d43674dc.png 3c999630ea1690918771a6d53ee37f35.png4. Battery Installation Battery Compartment Cover 1) Grip the front of the mouse (the end with the buttons) with your left hand. 2) With your right hand hold the back of the mouse (end opposite the buttons) with your thumb on the bottom, and your index finger and middle finger resting on top. 3) Grip the mouse firmly, pressing down slightly on the GE logo on top of the mouse with the index and middle finger of your right hand, then pull back to release the battery cover. 4) Set the battery compartment cover aside. Insert 2 AAA batteries, being sure to match the polarity of the batteries with the polarity markings inside the battery compartment. 5) Replace the battery compartment cover. 6) Re-link your mouse.
Aug 18, 2009 | GE Wireless Optical Mini Mouse 3087897985
Brand New Wireless GE Mini Mouse 98807 - trying to set up with brand new Acer Netbook. Light comes on mouse but will not sync with receiver.
I would suggest trying new batteries as well as making sure the receiver is about 8in to 12in from the mouse and at least 6in from the monitor. If you are still not able to connect, uninstall any drivers you have install for this mouse, reboot your pc and reinstall the software 1st, then connect the hardware and reboot your pc.
Good Luck
C2Solutions
Aug 07, 2009 | GE Wireless Optical Mini Mouse 3087897985
My GE mouse doesn't work anymore
First thing to do is check the device manager. If it shows up there, make sure that there are no icons saying there is a problem.
Jul 29, 2017 | GE JASHO97985 Mouse
97990 Rev. 4
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it to Reset/Connect the mouse to the receiver and work properly.
If not, try pressing the receiver button and then press the mouse. This should be done whenever you change batteries or glitch.
Hope this helps you. Bud
Jan 30, 2009 | GE Wireless Optical Mouse
Where is the link button?
make sure the batteries are in correct
PUSH LINK ON TRANSMITTER
then on the bottom of the mouse there will be a button IF NOT on the USB THERE IS A BUTTON PUSH THAT
if mouse still does'nt work restart then again follow instructions above
Let me know if that was helpful
Jan 24, 2009 | GE Wireless Optical Mini Mouse 3087897985
Change batteries
This is a deceptive little beastie. As you look at the mouse, you will see that the front approximately 1/3 consists of the left and right mouse buttons and the scroll wheel. The rest appears to be a one piece cover with the black area with the GE logo in the middle. There's the tricky part. The black part with the Logo is the housing for the USB plug in part (so you can keep it with the mouse when transporting it). The rest of that (silver on my mouse) is the battery cover. You open it up by gripping the little raised line on each side of the cover and pull backwards while holding the front by the black area under the mouse buttons. The cover (only the silver part, the black is attached to the rest of the mouse) will slide backwards and Voila! There are your batteries.
Jan 12, 2009 | GE Optical Mini Mouse ho98094
My USB plug in for my GE wireless optical mini mouse
There should be a button on the usb itself.You can try removing it plugging it back in then push that button if still red then you can try changing the batteries.
Dec 29, 2008 | GE Optical Mini Mouse ho98094
Ge mouse 98763 working yesterday now today nothing changed batteries still nothiing
Are the batteries good. To replace the batteries fo this.
Dec 07, 2008 | GE Wireless Optical Mouse
GE Optical 98802 Mouse Logo
201 people viewed this question
Top GE Computers & Internet Experts
micky dee
mukhtar21 shaikh
mukhtar21 shaikh
Ricky Ostrom
Ricky Ostrom
Are you a GE Computer and Internet Expert? Answer questions, earn points and help others
