Question about Kenmore 50522 / 50524 Side by Side Refrigerator
How to remove front cover for ice and water dispenser
How do you remove the front plastic cover in order to work on Ice dispencer
  • is that because you not getting ice? i ask because that's not where you at to be working.
fridgetech
  • 473 Answers
SOURCE: Ice Maker not making Ice
That plastic piece it part of the ice maker module. It's broken. Will need to replace that module and ice maker thermostat (bimetal) for best repair. If you do this repair you will also need food grade silicone grease (glob) to make a good contact between the thermostat and mold. It this sounds to complicated then just replace the whole icemaker and that will fix your problem.
Posted on Oct 08, 2007
ghappliances
  • 126 Answers
SOURCE: Front Cover to Ice/water dispenser
YOU WILL FIND TWO PHILLIPS SCREWS UNDER THE FRONT PANEL AT THE BOTTOM YOU NEED TO BEND DOWN TO SEE THEM.IT THEY ARE NOT THERE THEN YOU WILL NEED TO REMOVE THE ENTIRE DOOR LINER ITS BEST YOU GET THE HELP OF A TECH.LET ME NO IF YOU NEED FURTHER ASSISTANCE.GOODLUCK.MOHAMED
Posted on Sep 16, 2008
SOURCE: Ice door for ice dispenser not shutting.
How do I remove the ice/water dispenser front cover assembly
Posted on Sep 23, 2008
philbran
  • 242 Answers
SOURCE: how to remove water dispencer cover
you must start at the bottom prying the plastic off carfully with a flat head screw driver.
Phil
Posted on Jun 11, 2009
  • 153 Answers
SOURCE: How to remove front cover for ice and water dispenser
carefully look inside and in center.
Posted on Jul 23, 2009
Last night, I connected an active water line to the back of my Kenmore side by side. The ice maker is making ice but water water and ice is not coming out of the dispencer. There is another water jug...
You have a dual water inlet valve where your water supply connects. One goes to the ice maker and the other goes to the water dispenser by way of the water reservoir you mentioned in the fridge.
Open the door and hold the door switch down and try the ice dispenser. Do you hear any thing.You should hear the ice door open and the augur motor turning to turn the augur which pushes the ice out the door. If the augur doesn't turn Take all the ice out of the bin and try. perhaps the motor is too weak or the augur is locked up. Take the bin out and try to see if the motor will turn with no load. The motor is behind the back cover where the bin sits. See if you get power to it using a voltmeter when you try the dispenser. If you are, probably bad motor. If not ,dispenser switch or solenoid is not working.
Apr 20, 2011 | Kenmore Side by Side Refrigerator
How do i access the ice dispencer door in the door? The door is stuck open and freezes up the dispencer.
1. Disconnect the unit from the electrical
supply and wait for 3 to 4 hrs to get ice melted.
2. Pull out and unclip the drip tray on the ice
and water dispenser compartment.
3. Remove the screws from the ice and water
dispenser compartment front panel and
turn it over. The selector switch pack and
dispenser switches are now accessible for
testing.
Jan 29, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
GC3SHEx300 ice dispencer does not dispense cube or crush ice. Water comes out, lights work. it is not deactivated.
Sep 06, 2010 | Whirlpool 21.8 cu. ft. Side-By-Side...
Ice Maker Works, Water Dispenser Doesn't
I have a whirlpool side by side. water and ice in front. ice working and water not. the hose is not frozen and it is not humming when you push the water dispenser. It would give us water and quit but now we have nothing.
Jun 25, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
How to remove water dispencer cover
Phil
Jun 11, 2009 | Refrigerators
Why doesn't my ice maker work?
You do not list model number, so this will be very generic. If you have cubes in the ice bin, and when you try to dispense them the duct door opens and the auger motor runs, check the auger in the ice bin itself. Check where the spiral auger meets the plastic part on front of the auger. Drive part likely seperated.
Nov 21, 2008 | Refrigerators
Sid by side ice dsspencer and water dispencer(all the indicator light suddently are shut off) not working
you could have a problem with your dispenser module. a burnt pcb that could lead to all of your problems. switches not working, lights not working, dispenser not working, etc.
check your dispenser module and if you find a burnt part or a burnt PCB, then replace it.
tnx 4 using fixya,
drcool
Oct 14, 2008 | Frigidaire FRS3R5EMB Side by Side...
May 22, 2008 | Kenmore 53542 / 53544 Side by Side...
Water dispencer not working
check inside the bottom of the refrigerator for water, the water line goes thru the back of the refrigerator and it may have cracked and leaking inside instead of going to the dispenser.
if not then water is most likely frozen in the line going thru the back of the refrigerator. look behind the pans in the refrigerator and there should be a coil of clear plastic water line, this is the reservoir that chills the water for the dispenser. sometimes it will freeze up if the refrigerator is very cold.
May 07, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Oct 08, 2007 | Refrigerators
Kenmore 50522 / 50524 Side by Side Refrigerator Logo
445 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
