Eva-Dry EDV300 Dehumidifier
Problem for Eva-Dry EDV300 Dehumidifier
Is it normal for my unit to run continuously?
By Ryan - usenet poster
Solution #1
posted on Aug 08, 2005
Somewhat Helpful)
Perkins
Rank: Apprentice
Rating: 0%, 0 votes
Usually no. If your dehumidifier is running constantly and the water container is not filling up at least once a day, there may be something wrong with the dehumidifier. But if the unit runs constantly and the water container has to be emptied daily, there's just a lot of humidity in the room and the dehumidifier is doing what it's supposed to do.
Was this helpful?
Yes
No
Solution #2
posted on Apr 18, 2007
Somewhat Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Maybe a suggestion as to why or fix the problem of the dehumidifier running constantly and not filling the reservoir.
Solution #3
posted on May 28, 2008
Not Rated)
knowhair
Rank: Apprentice
Rating: 92%, 4 votes
The smaller the unit the more it will run if high humidity is present. Sometimes the unit cant play "catch up" to the moisture it is taking out of the air. A room that is 20' X 20' should have a 40 pint capacity. If the unit is in the basement and it's very damp the smaller unit will run forever and most likely freeze up. Like putting a small air conditioner in a large room,you overwork it and the unit will run all the time in most cases trying to cool down a room that the unit can't handle.
Was this helpful?
Yes
No
Popular Solutions for Eva-Dry EDV300 Dehumidifier
Questions and Unsolved Problems for Eva-Dry EDV300 Dehumidifier
Do you recommend Eva-Dry EDV300 Dehumidifier?
Answer
Answer
Humidity will not collect in bin, always dry when machine is left on for hours
Answer
Do you stock replacement 5Ltr tanks for an Amcor TC120 ?
Answer
I need a user manual for the following Dehumidifier: Model - Airforce BQWDH - 816EAH
Answer
water pours out onto the floor when unit is hooked to a gravity flow hose why
Answer
no problem just an inquiry...perhaps I should ask at what degree should I keep my lower level... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Eva-Dry EDV300 Dehumidifier:
Top Dehumidifier Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Dehumidifier Experts
Top Air Conditioner Repair
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
