Error code e-1 for Ricoh FT 4522
Just got coper and checked paper and it was full. I dont know what the error code E-1 stands for.
  • Anonymous Mar 29, 2014
    code u2
    President:
  • Office Equip... Master
  • 990 Answers
We don't have e-1 code but we do have e101,if my one is correct,there have few steps to follow;
1,press "clear modes"
2, press 107
3, press and hold down'clear/stop" key
4, enter 5 press start
5,enter810 press start
6, turn power off and on
Posted on Dec 12, 2008
Ricoh ft 4022 photocopy machine displaying error code E-3.
cleaning requird clean properly with any quality cleaner then rty
May 17, 2012 | Pyle Office Equipment & Supplies
ERROR CODE E-5 HELP RICOH 4522
If you press the "." key you will get the last 2 digits to complete the error message. For example: "E542".
Whatever the result, 'E5xx' is always related to a fuser error; That means, you have a blown fuse, lamp, or thermistor, and the problem, and the service code can only be reset by a technician in service mode after the fault is fixed.
Nov 25, 2011 | Ricoh Aficio 450 Copier
I'm getting error E-5 on - Ricoh FT 4027 which makes it malfuntion. What i should do?
tell me full number press */. and tell me full code like example 542 544 ok
Apr 11, 2011 | Ricoh Aficio 1035 Copier
My machine is ricoh FT 4220. error 11 or E1
E101: Exposure lamp error
1- check the Exposure lamp if it damage replace it .
2- check the Exposure lamp fuse ( located in scanner )
3- check the Exposure harness .
and after you solve your problem you must
Enter SP5-810 (SC code reset) and press the Enter key to reset the code
Jan 04, 2011 | Ricoh FT3713 Copier
We have a Ricoh FT 7650 copier, it has 4 drawers and only 1-3 are working. 4 is set for 11x17, but it shows up blank on the screen and if I select it I receive an error message. I'm not sure why it's...
take the tray out there is probably a paper behind it remove then off on
or there are small connectors on the back of a tray and copier make sure they dont have any paper stuck in them
Oct 25, 2010 | Ricoh Office Equipment & Supplies
Displays c-1 on front panel and front switch is good. Rocoh FT 4522
Hello sir; On the front door there have a door actuactor may be it broken. or door switch loose.
May 18, 2009 | Ricoh Office Equipment & Supplies
Ricoh FT4022 error E-1
E1 Exposure Lamp problem. (sensor, lamp, lamp stabilizer)Either the lamp is blown, the board is bad or the sensor is bad.
Feb 12, 2009 | Ricoh Aficio 1035 Copier
Ricohh 450. Error code E544 or E-5 comes up. What can I do to fix
This is a fuser error code. Sometimes it is caused by a mis-reading. Use the procedure below to reset this machine.
Press the yellow "clear modes" key then pres 1, 0, 7, then press AND HOLD the red "clear stop" key until the screen changes. After the screen changes, turn the machine off at the red switch on the front of the machine. Turn it back on.
If the code comes back you will have to call a service tech to troubleshoot and replace parts.
Nov 25, 2008 | Ricoh Aficio 450 Copier
Ricoh ft 4522
check the fuser first, it should be clean and shiny otherwise it's coming from drum area
Sep 12, 2008 | Ricoh FT5832 Copier
Ricoh Aficio MP C1500SP - functional error SC202
call ricoh serviceman he/she can fix it.
Defective tank full sensor
• Tank full lever bent or broken
• Incorrect ink suction
1. Check the harness of the tank full sensor.
2. Replace the GJ engine.
3. Replace the maintenance unit.
• The position of the tank full lever
does not stay at the tank full position
after ink initialization or air releasing.
• The position of the tank full lever is
not detected at ink suction.
Aug 19, 2007 | Ricoh Aficio 1515 All-In-One Laser Printer
303 people viewed this question
jasbo
jasbo
