Question about GE WBSR3140DW Top Load Washer
GE Washer top load model WDSR4110T
The agitator on my top loadGE washer is only working part of the time. There are times when I here the machine making strange noises and I open the lid and kind of twist the agitator and it gets going full speed again. Now it is gettting worse and it don't move as fast. I have also opened the washer after the cycle is complete and the clothes are completely soaked. The spin cycle didn't happen or didn't work. I then twist the dial completely around back to spin and manually "help" it to start again.
Are these 2 seperate problems? Does anyone have experience with this? I have read some of the posts about replacing agitators, just wondering if this will solve my problem. I just got laid off and would prefer fixing the problem myself.
Thanks,
DK
  • heydave23 Dec 13, 2008
    Thanks for your help. I took the agitator down to my local shop and it looked okay. He suggested I check the belt (take off front cover in front of barrell, the belt is on the bottom) to make sure it wasn't loose. I took the cover off and sure enough the belt was loose. I loosened the four bolts holding the motor and slid the motor forward all of the way. The belt was now taunt and I replaced the bolts. That seems to have fixed all of the problems I had. Thanks for your help.
    DK
  • 71 Answers
The agitator is the spline insert . that you can replace. The spin problem is in the clutch which is a bigger job
Posted on Dec 12, 2008
How do I fix a GE washing machine that doesn't spin or agitate?
aCTUALLY IT MAY BE THE LID SWITCH BUT iM THINKING ITS THE CAM DOGS OR IN G.E MODELS THE AGITATOR COUPLER AT THE BOTTOM IS BAD? ITS ABOUT 7 BUCKS TO REPLACE IT AND EASY
Jun 29, 2015 | GE Profile WPRE6100G Top Load Washer
GE top load Profile washer. Spin cycle not
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 11, 2010 | GE WVSR1060A Top Load Washer
How to remove agitator from GE washer? Model WHDRR418G1WW.
how to remove agitator from GE hydrowave washer machine?
Feb 27, 2010 | GE WBSR3140DW Top Load Washer
Hi, The water comes into the load, but then their
the agitator shaft could be stripped out. does it sound like the motor is working during the wash cycle or is it just idle? This is a common problem with ge washers the agitator strips out on the transmision and needs to be replaced.
Jan 02, 2010 | GE WJSR2070B Top Load Washer
My GE washer won't fill with water; will agitate
The hitachi machine bring an error message C1B1. Please assist
Jul 19, 2009 | GE Profile WPRE6100G Top Load Washer
GE WHDRR418G1WW Washing Machine will not agitate or spin/rinse cycle
Tell me more Is there voltage to motor? The transmission makes it agitate .
May 28, 2009 | GE WBSR3140DW Top Load Washer
GE topload washer Agitator
theres no nut and bolt,,only a cam or bell ..you have to roch agitator back and forth,,until it losens,,and pull up reall hard..or put your belt under agitator and yank up..onthejob
Jan 23, 2009 | GE WBSR3140DW Top Load Washer
Ge top loader washer agitator does not work
To check the agitator. Start the washer into wash cycle. Once started Push down on top of agitator. If it catches some times or all of the time when pushing down, then then doggets are worn, under the agitator. You`ll have to remove the agitator to see these. If by pushing down on the agitator, nothing changes, Then you probably have a transmition problem. Check this and let me know what you find.
Nov 27, 2008 | Kenmore 22422 Top Load Washer
Ge elite 110 23012 100 top load washer
look on the inside your agitator makesure it not strip out cauing your agitator be lose might need to replace agitator
Aug 08, 2017 | GE Washing Machines
Washer will not agitate
A wears out clutch might prevent the washer from agitating well or at all. If the clutch is worn, you need to replace it. Good luck!
Feb 11, 2007 | Kenmore 15864/15862 Top Load Washer
GE WBSR3140DW Top Load Washer Logo
174 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
