Question about Ruud UAKA042 Air Conditioner
High side low side pressures don not respond to freon levels
I have a new 2stage Ruud heat pump. It runs well in cooling mode but makes a rumbling noise in heat mode. The rummbling noise is in sync with vibrations felt in the suction line. The freon pressures suggest a little low in freon. The addition or removal of several pounds of 410A have no effect on the highside or low side pressures. Current draw of the compressor is 6.5 amps on stage 1 heating and 10 amps on stage two heating. I would not have looked at it if it were not for the noisy operating when heating. What is going on here? Why does it not respond to freon additions with pressure changes or current draw? I have added as much as 6 pounds in this 3 ton unit.
  • 334 Answers
Chances are you have a TXV already installed. Thats why simply adding refridgerant is not effecting the pressures.
All you are doing by adding refridgerant is overcharging the unit, and possibly forcing the compressor to try to pump liquid instead of vapor. Not god for the compressor.
If the vibration noise is your only problem, I would try emilinating the vibration.
Find where the lineset is touching other parts of the house and install vibration dampening opads there. If the airahndler is mounted to the structure of the house, install vibration reduxction pads there too. If it is suspended from the floor joists you may have to change that mounitng method.
You can suspend the drain overflow pan and then set the unit in that on dampening pads, or set it on blocks from the floor/crawlspace.
Check your data sticker to find out how many pounds of refridgerant the unit takes.
By now, you are probably way overcharged.
Posted on Dec 24, 2008
  • 85 Answers
Have you tried to add a txv to the indoor coil? It sounds like there is restriction... Obviously if it's also a new indoor unit it allready has a txv, and if thats the case sorry, just wanted to make sure..
Posted on Dec 11, 2008
My inside and outside unit turn on fine, out side fan and compressor running good,inside blowing cool air, about four minutes after that, out side unit shutoff, no humming, nothing.
Are you heating or cooling? When the outdoor unit shuts off how does it come back on. Or are you saying that the outdoor unit is short cycling off and on
Jan 17, 2018 | Ruud Heating & Cooling
Bryant furnace model FX4C, FY4A with heat pump and a/c will not switch from a/c to heat pump. Only have heat with emergency heat on.
WELL this could be a couple of problems the reversing valve could be stuck either from not enough pressure which would be a leal and low on freon or the unit is off on low pressure switch/high pressure switch from either being low on freon or something restricting it and caused unit to shut down, ive been a servicer for many years and if it gets below 30 degrees outside i would recommend running the e-heat anyway it does cost more money minute for minute. but you will find it will heat alot faster in those colder nights than the heat pump therefore cost is about the same.
as far as not switching over could be low on freon or a stuck reversing valve... is the outside even running in cool mode if not the you may have a tripped pressure switch...good luck
Jan 04, 2011 | Bryant Heating & Cooling
Air conditioner compressor runs - freon is up to proper level....not cooling??
BOTH High and low readings should be checked to have a better idea of what is going on with an AC system but based on the limited information… the compressor is not engaged or is not pumping. Below are some things I would check;
1. Check the high and low gauge readings with the AC on & set on MAX/Recirculate, middle vents with the engine at 2,000 RPM’s, blower speed on high.
2. Check the vent temperatures with a thermometer from the middle vents, far right & far left vents?
3. What is the outside temperature at the time the readings were taken?
4. Check to see if the condenser fan blowing strong?
5. Notice if compressor clutch is cylcling excessively.
Could be overcharged, not enough air going across condenser fins, compressor not pumping sufficiently… BOTH gauge readings are really needed to get a better idea.
Below are normal car AC pressure readings with 134A.
Normal readings on high and low side with AC OFF (static pressure) – Depends on outside temperature, but normally is between 80-105 PSI
Normal low side reading with AC on high speed and MAX & engine at 800-1000 RPM’s – Ranges from 25-35 PSI
Normal high side reading ranges from 200-350 PSI
Don’t assume that if adding little Freon is good that adding a lot is better! Overcharging just a little can decrease the performance of the system and possibly damage the compressor
Thank you for using fixya and good luck, keep me posted. Be glad to help you get your A/C running again soon.
Jun 12, 2010 | 1999 Chevrolet Silverado 1500
I have to reset the pressure switch continously when I turn on the heat. The temp never reaches what is set on the themostat.
I take it that this is a heat pump. Check your coils and your filter, make sure they are clean. It could be a dirty eveperater coild or dirty filter. It could also be a freon issue (to much freon). Heat pumps are touchy when it comes to Freon pressure. When in cooling mode, it's not that cretical but when in the heat mode, it has to be real close or you will have problems. Normally, the pressure switch is set off due to one of two reasons.
  1. The unit can't get rid of the heat causing the pressure to build to high.
  2. To much Freon pressure.
Nov 12, 2009 | Ruud UBHC Air Conditioner
Two lennox heatpump 71/2 tons
check the true psi with the line psi to see if same if psi is good in cooling 225 hi and 70 low on 80'day then compressor is fine and i would start checking for temp difference on the reversing valve sometimes this will cause high suction or high discharge psi shift it manually with by energising it be cooling or heating then pull wire and see how it shifts if shifts good then txv on out door unit could be bad what is the psi in heating on the discharge line going to the indoor unit? most prv's are set at about 350 psi r22 as for suction line size its only hot gas in hp mode os no problem their shows in cooling mode as low suction psi ..hope this helps some also make sure indoor coil is clean!....thanks & rate me
Apr 19, 2009 | Ruud UBHC Air Conditioner
Ruud 5-ton 10 SEER heat pump compressor turns off after 20 minut
First turn it to cool and see how cold the big cooper line is if it is not real cold you could be low on freon but if it is cold your compressor is bad
Nov 12, 2008 | Heating & Cooling
Compressor will not start.
Usually short cycling means that High side pressure is getting to high (due to not working condenser fan, or dirty condenser coil), or low side pressure is getting too low (might have low level of freon or restriction in sealed system). low side would drop dramatically if indoor blower is not running, so if air is not circulating thru evaporator coil, coil will freeze up and low side would be much lower then normal. Here is video how I found issue with package AC not coming on. Thermostat call for cool, but condenser would not come on, indoor blower runs ok.
Nov 02, 2008 | Ruud UAMB Air Conditioner
Ruud heat pump high pressure cut off problem
That's going to be in your installer configuration. Check and make sure the G terminal has a wire connected to it at the tstat , and that connection it tight. In the configuration menu, make sure it is set for a heat pump, elected heat. It seems to me that the tstat doesn't know its connected to a heat pump. Should be able to locate aodel # for tstat on the back of it. And ask Mr. Google for a manual, if you don't have 1. Hope this helps!
Mar 18, 2017 | Heating & Cooling
Ruud UAKA042 Air Conditioner Logo
606 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
