Question about Sega Dreamcast Console
I have a sega dreamcast but i can't change the date. what can i do. do i need f1 fuse.
At first mine would do the same thing, so I thought. What you should try doing is go to "settings" and change the date, then go down on the list and change the memory card date settings. If that doesn't work then I'm really sorry I wasted your time.
Posted on Dec 14, 2008
I was given a sega dreamcast everything works but when it says install disc i put the disc on the wheel close the door and the cd wont stay on the wheel
If I recall the Sega Dreamcast wheel is a clasp type wheel. You need to push the disk down onto the wheel and you will hear it secure itself onto the wheel. Then close the wheel and you should be good to go. Don't just place it on the wheel... push it down until you here that little clicking sound and it should stay on the wheel.
Aug 10, 2011 | Sega Dreamcast Console
I just bought a dreamcast off ebay. The console powers on and then goes to the set time/date screen. I plug in both controllers and neither will change the settings...Are both controllers broke or is it a...
controller circuit board problem,,internal battery needs to be replaced, it blue and looks like a watch batt,,it is marked in the controller board as BT1.
Also on the controller board is a resistor or transistor marked F1 that needs to be replaced. You will need to do some soldering but it's not that difficult. They are colour coated so make sure you get the right one. They are very cheap and the battery can be picked up at walmart for under 10$
Feb 27, 2010 | Sega Dreamcast Console
My control wont work
did you tested another dreamcast control...you had the same problem...so you have to check the protection Fusistor inside your dreamcast conector controller board....it seems like a blue or green normal resistor...marked as F1 on the board..change it with a simple fuse or an smd fusistor...Good Luck!
Nov 23, 2009 | Sega Dreamcast Console
When i am in the middle of playing a game on my Sega Dreamcast it will cut out on me sometimes and go to the Dreamcast menu,with the controller and music stuff in background and then it tries to reload the...
Your Dreamcast sounds like it's overheating.
I had the same thing, and the cooling fan was worn out and needed to be replaced. I did this, and now it works like a charm.
Apr 14, 2009 | Sega Dreamcast Console
Dreamcast freezes.
take apart your dreamcast and look at the controller input circuit board, there should be a big resistor on near one of the boards corners, make a note of the coloured bands and buy a new resistor with the same pattern and replace the one already on the board with the new one.
Mar 09, 2008 | Sega Dreamcast Console
Date screen
If you unplug you Dreamcast for extended periods of time the battery in your Dreamcast that saves that info will die (its suppose to last a month but over time they will wear out and not last at all). After 1 hour of gameplay (assuming the battery is still working, as Li's wear out) the battery will be fully charged and last a month.
Jan 17, 2008 | Sega Dreamcast Console
PROTEO25967
I need you to explain more about your problem. Explain how your Sega Dreamcast is behaving. I'll be more than glad to help you.
Oct 26, 2007 | Sega Dreamcast Console
Sega Dreamcast Console Logo
158 people viewed this question
Top Sega Video Game Consoles & Games Experts
DROPNDEAL
DROPNDEAL
Josh Whitehead
Josh Whitehead
Reggie brown
Are you a Sega Video Game Console and Game Expert? Answer questions, earn points and help others
