Question about Pioneer Audio Players & Recorders
When playing cd player , cd rotates angle of 5 degrees clockwise
& then 5 degrrees ccw , & so on .there is no actual rotation
  • 1,512 Answers
Hi there
It is probable that you will have a faulty spindle motor if the disc wont spin up to speed. Have you been able to give the disc a kick start to get it to read. The disk also has to spin the fastest when reading the table of contents after the disc is first loaded. Sometimes when the suspension rubbers to the laser fail, the disc may also be catching on parts of the mechanism preventing it from spinning up to speed. Can you give me a little more about how the problem is occurring, particularly what noises you hear, and whether you can kick start the disc to spin. I have plenty of experience repairing these players, and am happy to answer any questions you may have about it. Cheers
regards
robotek
Posted on Dec 12, 2008
Rotation for 1992 ford 4.9 I 6
DO you mean which direction does the engine rotate... - clockwise or counterclockwise??
98% rotate clockwise IF YOU ARE STANDING IN FRONT OF THE VEHICLE.(at the front bumper)..
...honda made some years ago that rotated CCW..
Jul 30, 2017 | Ford Cars & Trucks
ALL DISKS SKIP ON MY SONY CDP - CX53...SOLUTION?
If you have access to the lased head, gently wipe the lens with a stick with cotton moistened with isopropyl alcohol, or regular sanitary alcohol. Use circular movement. Then, gently shine the lens with dry cotton. DO NOT PRESS THE LENS !!!! If the issue persists, it's more complicated. You need to have access to the tiny trimmer below or near the laser head. Using a plastic screwdriver, rotate the trimmer clockwise about 2-3 degrees. Test playing. If track doesn't skip, hit the CD player's case with the finger, to check if track skips because of shock. If skips, rotate trimmer again 1-2 degr. Check again. If it doesn't work, try rotating counterclockwise. You need patience. Hope it is useful.
Mar 11, 2015 | Sony Audio Players & Recorders
Diagram spark plug wiring
my guess, is you removed them and didnt mark them?
the firing order?
what engine, there are 5.
to do this , one need to know 5 things.
2.5L, 2.8L, 4.0L and 5.2/5.9L engine displacements.
the distributor rotation direction CCW, or CW
and last the firing order, sometimes marked clearly on the intake manifold.
you must now where #1 cylinder is (always most front)
1989-98 2.5L Engine firing order: 1-3-4-2 Distributor rotation: Clockwise
2.8L Engine firing order: 1-2-3-4-5-6 Distributor rotation: Clockwise
4.0L Engine firing order: 1-5-3-6-2-4 Distributor rotation: Clockwise
5.2L and 5.9L Engine firing order: 1-8-4-3-6-5-7-2 Distributor rotation: Clockwise
on a v6/v8 one cylinder is more forward. this is #1, look carefully.
Nov 26, 2013 | 1997 Jeep Grand Cherokee
REPLACING CYLINDERHEAD-TORQU SPEXS NEEDED
For the 12 Pointed Head Bearing Cap Sub-Assembly Bolts
Start from center bolts and tighten in a clockwise rotation working out
Step 1 all bolts 22 Nm or 16 ft lb
Step 2 all bolts 44 Nm or 32 ft lb
Step 3 all bolts 45 degrees additional clockwise rotation using an angle indicator.
Step 4 all bolts 45 degrees additional clockwise rotation using an angle indicator.
Hexagon Head Bearing Cap Sub-Assembly Bolts
1ZZ-FE Engine 18.5 Nm (14 ft.lb)
2ZZ-GE Engine 18 Nm (13 ft.lb)
Connecting rod:
1. Apply a light coat of engine oil on the threads and under the heads of theconnecting rod cap bolts.
2. Install and alternately tighten the 2 connecting rod cap bolts in several passes. Torque: 1ZZ-FE: 20 Nm (204 kgf-cm, 15 ft. lbs.) 2ZZ-GE: 30 Nm (306 kgf-cm, 22 ft. lbs.) If any of the connecting rod cap bolts does not meet the torque specification, replace the connecting rod cap bolts.
3. Retighten the cap bolts by 90 more
4. Check that the crankshaft turns smoothly.
Sep 11, 2012 | Cars & Trucks
How do you change out water filter?
Hi and welcome to FixYa, I am Kelly
Press in hard.. rotate it 90 degrees Counter clockwise and wiggle / pull it out. When you re-install a new filter align the filter with the internal locking tabs and press in hard and rotate 90 degrees clockwise.
Some times the filter can br really fussy to remove you just have to keep wiggling and pulling to get it out of the recepticle once you have rotated it 90 Deg CCW.
Thanks for choosing FixYa,
Kelly
Feb 14, 2011 | Maytag MFI2568AES Stainless Steel Bottom...
Spin both directions theb display show table error
Usually CD rotates in the clockwise direction. Whenever you are using CD which your CD player cannot detect then CD is rejected and suddenly CD rotates in anticlockwise direction.
Also, If your player is older and your CD players laser head worn out then CD's which were played good previously cannot be played properly and then stop in middle, when this happens you can see CD rotating in anti direction.
Clean the laser head, with CD cleaner and do not use scratched CD's
Aug 26, 2010 | Sony CDP-CX300 CD Player
Need torque for a 2000 Toyota Celicia GT 1.8L
Crank Main caps Tightening Torque
Connecting rod:
1. Apply a light coat of engine oil on the threads and under the heads of the connecting rod cap bolts.
3. Retighten the cap bolts by 90° more
Mar 18, 2010 | 2000 Toyota Celica
Replacement of a head gasket on 2.5 liter nissan altima 2002
frajogag: First off, be aware that these bolts are "torque to yield" bolts (streach bolts). What this means is that instead of torqueing the head bolts to a specific torque specification, they are torqued down to a set spec and then tightened by rotating the bolts a certain angle, like 90 degrees. and all of them are turned the same amount.
This means that the shanks of the bolts must be checked to make sure they are not too thin (or the bolt has already stretched beyond limits and is prone to snap if used)
Here is how you check the bolts. Measure the bolt using a micrometer, at the base, or within the first 13mm from the end where it threads in. Then go to about 10mm before the threads end heading toward the top of the bolt. There should not be more than a 0.23mm (.0091 inch) or less difference or the bolt should be discarded.
Torque the bolts down to 98.1Nm ( 72.ft lb)
Looking at the head from the side, so you are looking at the full length from side to side, I will number the head bolts in this fashion.
#1 & 2 are directly in front of you and in the center of the cylinder head crossing it width wise.
#3&4 are to the left of #1&2, / #5&6 are to the right of #1&2
#7&8 are to the left of #3&4 / #9$10 are to the right of #5&6
Now, you have the sequence.
After the initial pull, back off all the bolts in the same sequence and then retorque them to 36 Nm ( 28 ft lb)
Using a torque angle wrench or having the ability to accurately judge turning angles. Rotate (clockwise) to a 75 degree angle. do this to all the bolts using the sequence I had provided.
Rotate the bolts (clockwise) 75 degrees again on all bolts in the same sequence. The proceedure is complete!
Mar 10, 2009 | 2002 Nissan Altima
Rotate Video 90 degrees
use VirtualDub... open your video, in the menu Video... Filters... click on Add, select the filter : rotate2, on the Rotation Angle, write : 270, you can test the angle with the preview button. You can alors enter : -90 instead of 270. Check the 'Expand frame to fit'. You can preview all the option, before converting the videos. Click ok...ok until you have the main windows.... Make sure you selected : Full Processing mode in the menu Video.
Aug 07, 2007 | SanDisk Sansa e260 MP3 Player
111 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
