KNOCKING ENGINE
Hi. There are two main issues that will cause the engine to knock. The first will be the oil pump. If the oil pump is failing, or damaged, this will produce a low oil pressure state. Low oil pressure will cause the internals to not receive the necessary lubrication needed for optimal performance. This low pressure state will cause the rod bearings to ware, thus, producing this knocking noise. This will be accompanied by a low pressure, or illuminated oil light. The next issue will be worn, or damaged rod bearings. These vital bearings can fail if the bearing clearance is excessive, or worn. They will, also, fail if the oil supply is not sufficient. This inspection will require you to drain all oil and coolant, and the dropping of the oil pan, to expose these bearings.Worn, or excessive bearing clearances will cause a knock.
NOTE_ There is another issue that i should warn of. If There is sufficient sludge build up in this engine, due to not changing the oil regularly, or not administering scheduled engine flushing, this will cause the internal oil ports to clog up, thus, inducing poor oil circulation. This will damage the entire engine. If you have not had this engine flushed, i would recommend to schedule this , asap.
oil milky cap
