Question about Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive
Hi i have a WD mybook both the lights on the power cord and the device itself are flashing rapidly and i am unable to acess the external drive. i have tried using a different computer, tried a different USB cord and different outlets in the house any idea why i can't acess the drive?? thx
Hi I have the Essential Edition WD My Book 1TB/To, it was working well and then for no reason my computer does not recognise that it is connecte, now I can't access this drive was the g/ drive. Any clue as to what I should do?
Thanks
Posted on Dec 15, 2008
Mybook WD25001032-001 keeps on flashing and won't work...what is wrong with it. I need help. Thanks
Try plugging the usb cable on a different port on the computer. If the light flashing is red, then there is a hardware problem on your WD. If this is still under warranty, then its best to have it checked from where you bought it or to any authorized WD service center. If its no longer under warranty, then you can open the WD and check for any disconnection. The inside contains a harddisk; you may want to disconnect the two connectors from the harddisk and reconnect them again.
Mar 25, 2011 | Western Digital 250GB MyBook External USB...
I have a WD MyBook Essential 1TB external hard drive installed with my Mac OSX 10.5.8. The drive is only being used for Time Machine and my iTunes backup. The drive will randomly unmount itself and I get...
I would suspect that either the USB cable or port is the problem. Change the USB port (On the Mac or on the WD MyBook (I don't know if it has more than one USB port) that the cable is connected to and see if that improves the situation, if it still happens change the USB cable. Hope this helps.
Mar 22, 2011 | Western Digital My Book Essential 1TB...
Mybook doesn't show up under windows explorer and the light is constatnly on
Right click the mybook in the device manager, and look for an 'enable' or 'mount' option.
Dec 31, 2009 | Western Digital Elements powered by WD 320...
Vista 64 - slow boot with WD MyBook attached
This is caused if there are any system files on your external drives OR if you have set the bios to be able to boot from usb devices
One or the other is where you need to look.
Aug 17, 2009 | Western Digital 320GB MyBook External USB...
WD Mybook I TB hard drive won't power up
It could be the power adapter but you'll need to verify that the wall outlet or power strip you have it plugged into actually has power. If it's a power strip make sure that it is turned on and has power and also plug the adapter into a different outlet on the strip as individual outlets can go bad or have a bad connection.
Jul 31, 2009 | Western Digital My Book Essential Edition...
I have a WD external hard drive and need a new power cord. model # wd2200h1u-00 where can I find one?
for those, you can use a generic power cable as long as the voltage and amperage matches the original one. Take the old one with you and head to a radioshack.
Jun 10, 2009 | Western Digital 320GB MyBook External USB...
Connecting my external 320 to my laptop but its just flashes
Try a replacement USB cable first, and test the MyBook on a different computer, to ensure the fault is on the external storage unit.
There are two possibilities:
The Mybook USB/ATA controller board is faulty.
In this case you can simply take apart the enclosure and mount the disk into a new enclosure. WD Mybooks are SATA, but double check the hard disk connector to ensure.
The hard disk inside is faulty.
In this case repair may be expensive. You need to locate a data recovery facility with a 'clean room' , the cost is usually more than $800.
If this happened after a power surge, then the problem is most likely a faulty controller board.
If instead you have dropped the hard disk it is possible an hard drive failure, in that case repair will be expensive.
A replacement enclosure will stfrom art about $20 on Ebay or Amazon, and must not necessarily be WD .
Check if your disk is Sata or PATA (IDE) before buying the enclosure.
May 13, 2009 | Western Digital 320GB MyBook External USB...
Wd mybook lights flash and cannot acess drive
Allright!!
I dont know if this will work for everyone.
Regarding my previous post i had taken the hard disk out of the enclosure and plugged it directly into the motherboard via sata to no avail.
I then decided to put it back in for enclosure and thought i will try it again.
In device manager i realised the hard disk kept trying to refresh inself and would cut off before it got recognised....playing with the enable/disable option i managed to (somehow) get the drive working(cant explain how yet)
But it worked long enough for me to make my backups.
So i would recomment trying to play around with device manager....might get it to work.
Also its intresting to know that if you try to claim on the warrenty using the serial number on the enclousure you get only one year warrenty but if you open it and enter the serial number printed on the hard disk itself you get a longer warrenty.....
Hope this helps
Good Luck
Dec 11, 2008 | Western Digital My Book Essential Edition...
External HD not starting properly
my 500 gig mybook is clicking and not showing up at all, I am going to serioulsy lose my mind WTF!!!!
Sep 13, 2008 | Western Digital 320GB MyBook External USB...
My Book, Need upgrade to make it compatible with Mac Leopard OS X. Article #1716.
1) Go to support.wdc.com 2) Click Downloads 3) Select MyBook, then your MyBook model (I selected MyBook Home, as it was appropriate to my hardware) 4) Download and install the WD Drive Manager (Mac)
Note that this software only updates the utilities that control the power button, drive lights, and capacity gauge. If the drive is otherwise not functioning properly, you'll probably need to seek alternate support: the hardware itself functions just fine for me as an external drive without installing any additional software or drivers.
May 06, 2008 | Western Digital 500GB My Book World...
Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive Logo
618 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
