Question about Epson Stylus Photo R1800 InkJet Printer
Printer keeps saying paper jam
My printer keeps saying the paper is jammed but its not it will print a test sheet or nozzel check fine then when i set it up for a job it says paper jam again all paper settings are fine please help someone
  • mommasan37 Dec 12, 2008
    when it says paper jamed i pull out paper and put it back still say paper jamed no paper in it
We had the same problem at the college where i work. the print queue had somehow clogged up to such a point where the printer was doing this. the constant paper jam light & the printer taking paper when printing test sheets etc. we solved it by deleting the printer & then re-installing the drivers. may not work for everyone, but it certainly worked for us.
Posted on Mar 11, 2009
Auto paper load & paper jammed
Posted on Mar 08, 2009
Error code 3528 keeps coming up,telling me to remove back cover and remove paper jam then replace back cover.there is no paper jam,checked printer heads no paper anywhere?
I have this printed and if you read (carefully) through the manual it tells you it doesn't like single sheets of paper. If ever my paper feeder tray runs below say 3 sheets then this error will crop up so keep it topped up with paper. The same goes for photo paper too.
Sep 13, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Says Paper Jam but ther is no paper jam
It appear from here that the exit sensor may be dirty and you can use canned air and blow it out.
You may also be missing the paper out sensor that is located at the bottom of the printer oposite of the paper tray when you pull it out. When the flag arm has fallin out, it will give a false paper jam error when the last sheet has printed from the tray, not knowing or detecting that the tray is now empty.
Jul 02, 2009 | HP LaserJet 4 plus Printer
My laserjet 1020 develops a paper jam after printing the first page of a multipage print instruction .I have deleted the printer and re-installed it including all drivers but problem still...
Reinstalling the printer is related the Software.
If the paper gets physically jammed than its the driver setting issue or hardware issue.
Check if two sheets get jammed or only one sheet.
If it is two sheets than printer is picking up multiple sheets and paper gets jammed.
If the printer is jamming a single sheet than remove the Tray and look there is rubber roller inside if there are marks or lines on that rubber roller or if the roller roller is worn out than that rubber roller called as paper pickup roller need to be replaced.
If that looks fine than try to priny using manual feed and if the problem persists from manual feed too than try another toner cartridge
If the problem is not from Manual feed Tray that Replace the main Tray with known good Tray and check if the issue resolved.
Jul 01, 2009 | HP LaserJet 1010 Printer
Paper Jam/Stall - no paper jam
Well what you need to do is do a rest on the printer.That should solve the problem.If you want any further support, an online technician from techbuddies can help you for free.For this log on to http://tinyurl.com/m7ghqz
Jun 18, 2009 | HP Photosmart C4580 All-in-One InkJet...
Will not print
i think some **** of paper might be stuck inside the printer mechanism, carefully check it. if no, try the following :
* unload the cartridges and reload it back
* keep the printer offline (disconnect from the pc) and try copying something
* realign the cartridges with a former printed alignment sheet (i think u may have known how to align it)
May 15, 2009 | HP PSC 1315xi All-in-One Printer
Paper wont load and print
Open the rear of the printer...this is easy...as there is an access door....check to see if you have paper jam...
if there is remove and retry
keep me posted
Cheers!
Nov 13, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Printer Jam - when i put a sheet of Avery labels, printer jams
When you say TOP TRAY, do you mean a paper drawer, or the BYPASS TRAY? If the labels won't feed into the bypass but bond paper does, check to see if your labels are made for inkjet printers. Go to www.avery.com and contact Avery customer support to see what product they recommend for your MFC. Labels made for plain paper printers sometimes do not work for inkjets, and vice-a-versa.
Aug 29, 2008 | Brother MFC-5840CN All-In-One InkJet...
Cannot print anything. Paper goes in halfway and then says 'paper jam'. Checked back - no jammed paper. Keeps on doing this. Have been in to cancel print but keeps saying paper jam. Have tried a print test...
Dear Customer,
you ahve to use batter quility papers for prints,
cause when paper fixed up your printer says its jammed but as realesed its says printing but when ALL THINGS DOIN VERY FAST JAMMING & PRINTING ITS SEEMS LIKE PAPER JAMED ALSO SAW YOU AS PAPER JAMED,
so try to check your inner cartrige,ink & paper rolls,batter quility papers you ahve to use,
THNX
May 18, 2008 | HP Computers & Internet
Paper Jam on
most printers are pretty cheap now so replacement is always an option....on the other hand, I will spend countless hours trying to figure out what is wrong first. Remove all paper first, open printer and check for pieces of torn paper or debris, if you have a can of air you can blow out the insides to clean. Put 3 or 4 sheets of paper in, print a test page and watch carefully how paper advances...is it straight or crooked when being loaded? Is printer trying to pull more than 1 sheet at a time? Good luck
May 14, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Epson Stylus Photo R1800 InkJet Printer Logo
1,011 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
