Question about Minolta Maxxum 50 QD 35mm SLR Camera
Mirror lockup for minolta XG-1
The shutter will not close on the minolta, the term that comes to mind is a mirror lock I believe? It happened while someone else was loading some film into the camera I do not know how they did it, but when I went to take a picture the shutter opened, but now it won't close. I am about to take the thing apart, I can't find anyone within two hours reach that can help me, any info would be awesome, thanks.
  • 44 Answers
Sounds like the shutter lubrication has dried out causing the closing curtain to stick. DO NOT try spraying an oil into the camera to try and fix this, it will cause more problems and could destroy the circuit board. I would recommend sending the camera to a shop specializing in the overhaul of older cameras. You might try They have been repairing cameras since the fifties and still repair the XG series cameras
Posted on Dec 12, 2008
Nikon em mirror lockup solution
There is no dedicated mirror lock-up button, the self-timer does move the mirror out of the way when you press the shutter release and the shutter fires ten seconds later.
Jan 31, 2013 | Nikon EM 35mm SLR Camera
Canon lens locks when taking a picture.
Mirror lockup is probably enabled. You can disable it by going into Menu and then Custom Functions. Select Mirror lockup and disable it.
Jul 14, 2010 | Canon EOS Rebel XSi Digital Camera
Zmy Minolta Maxxum 35mm camera mirror is locked up
Sounds like the shutter or mirror assemble is damaged and needs repair. This is a major repair that a technician will need to preform.
Nov 20, 2009 | Photography
Shutter stays closed on bronica 645 etr medium format
Have the electronic shutter checked by a repair shop. Sounds like your Seiko electronic shutter has died or there's a short somewhere between shutter and lens. Hope this helps.
Jan 15, 2009 | Bronica ETR-Si Medium Format Camera
Mirror locked up and camera is showing help in the lcd display
Did you ever find out how to fix for your mirror lockup problem?
Sep 17, 2008 | Minolta Photography
Won't take pictures
symptom 1: referred to as FFB (Firts Frame Black). this is when you do not use the camera for a while and when you attempt to take the first snap shot, the Shutter is either stuck, or takes a blank/black picture (some cases the picture came out bluish). Sometimes the camera would freeze and you would need to remove the battery and re-insert it in order to reset the camera. Usually the camera comes back to life and and is usuable for a while until you store it. Sony will fix this free as they identified it as a design flaw in which the remedied (incorrect gear size for the Shutter charge assembly). Contact Sony support as they own all Minolta camera assets and tell them you have the FFB or First Frame Black problem and they will set up a ticket and instructions on where and how to send it.
symptom 2: Camera does not respond at all to the shutter release. Focus is fine, menu works, every function works no problem except for the most important - taking a picture (releasing the shutter). When you first turn on the camera, you hear the Antishift module attempt to center the CCD with a series of clicking noise for 5 or so seconds (not a good sign, also called the death rattle). All 5 AS bars in the view finder are blinking. In this case, the Tebure Assembly (AS Module) has failed and will need replacing. This is not cheap - sending it in to Precision Camera will run you around $250-$280. You can do it yourself if you order the assembly from Sony: Item - ( TEBURE ASSY ), U3008233U, $118.22 ea. via 1-800-488-7669 (will take 3-4 weeks). And follow the service manual to install and calibrate it (via the service manual download at
Aug 07, 2008 | Konica Minolta Maxxum 7D / Dynax 7D...
Shutter Lockups on Canon EOS 30 SLR Film camera
Detach the lens and try
Or Shoot at infinite focus, If the camera works then the problem is with your reflex mirror
Jan 27, 2008 | Canon EOS Rebel G 35mm SLR Camera
Mirror problems
Could be 1 of two things: 1. Mirror linkage failed. 2. Something is holding the mirror; sticky foam or the lubrication has dried out. Remove the lens, use slow shutter speed to release the shutter. While mirror is stuck in the up position, very gently pull down on the front edge of the mirror. If it frees up immediately it was stuck on the foam. Might be able to see a mark on edge of mirror from the foam. Hope this helps.
Apr 18, 2007 | Minolta XG-A 35mm SLR Camera
Mirror Lock Up
I haven't heard of any firmware to fix this but you're not alone. A number of people suffer the problem. Rather than me just copying and pasting try googling "Nikon D50 mirror Lockup problem. There's plenty to read up on. You should find a solution, good luck.
Jun 30, 2006 | Nikon D50 Digital Camera
Minolta Maxxum 50 QD 35mm SLR Camera Logo
348 people viewed this question
Top Minolta Photography Experts
Greg Cann
Greg Cann
Are you a Minolta Photography Expert? Answer questions, earn points and help others
