"I need a part number for the switch housing cover for a hunter whisperwind 2000 model 79174"
Fan is 5 months old. Removed the governor because light was flickering. Now the pull chain for light switch doesn't work after ONE pull. So we tried to replace the switch but couldn't get it out...
If this looks like your switch then yes, it's a generic part available pretty much anywhere ceiling fans/parts are sold (I've seen them in Wal-Mart). You will probably need small wirenuts or a line splice to replace with this part, but as it it a SPST which wire goes where does not really matter.
Sep 25, 2011 | Heating & Cooling
I just installed a new hunter ceiling fan (model #27301) and it will not work at all
I'm going to have to ask you the same question(s) that Hunter tech service will ask, if you called them.
1. Are you certain you have it wired correctly? Hunter's color coding & installation instructions are one of the worst in the business.
2. Is the wall switch ON? In addition, is the circuit breaker for the wall switch ON?
Jul 29, 2011 | Hunter Heating & Cooling
I bought a house 5 years ago with a Hunter fan installed with a remote control. It has model 84757 on back of fan and it stopped working so I just changed the wall on/off switch which was broken. Now the...
Replacing the batteries (2) should solve the problem. There batteries in the handheld remote and batteries in the receiver inside the fan's cowling. When installing the batteries, be sure they are facing the proper direction. If they aren't the remote will not work. Also, keep in mind, the wall switch must be ON when using the remote control.
Hope this helped you.
Jul 19, 2011 | Hunter Heating & Cooling
I have a hunter ceiling fan model number 25357-380 and recently when we have had a power glitch the fan's lights flash and the remote wont work. Can you explain what we need to do to resolve these...
The receiver located in the fan has failed. (This was a fairly common occurrence when I
worked for a major improvement store). Here is the technical/parts number for Hunter fan
(901) 248-2259 The website is www.hunterfan.com I hope this helps.
May 08, 2011 | Hunter Heating & Cooling
I moved into a house with 2 hunter ceiling fans with remote control. Both are set to the same frequency. Where is the transmitter located on the fan to change remote frequency setting?
Typically it is directly under the very top cover. it is slide under the hanger on the ceiling. Just remove the 4 screws and drop the cover and it should be there.
Apr 27, 2011 | Hunter Heating & Cooling
Need installation instructions for a Hunter Regalia ceiling fan, model 28642, item 183013, as the fan came without any. Am ready to install now!
Robin - Here's a link to the Owners Manual for the Model Number Hunter Ceiling Fan, you listed.
You may download and print it for future reference.
http://www.hunterfan.com/uploadedFiles/Support/Downloads/45065.pdf
Please don't forget to leave me a rating for helping you. Thanks!
Apr 14, 2011 | Hunter Heating & Cooling
I need a manual for my air purifier Hunter #37785
Are you certain that # 37785 is the correct model number? Hunter Air Purifier Model Numbers start with 30 - - - - . Once you have the correct model number, go to the following link and you can search for it there.
http://www.hunterair.com/hunter-air-purifiers
Apr 04, 2011 | Heating & Cooling
I HAVE CHANGED MY BATTERIES ON MY HUNTER THERMOSTAT AND RESTET IT BUT IT STILL GOES BACK TO DFAULT AND AND E STILL REAPPEARS AND MY AIR WILL NOT KICK ON
http://hunter-thermostats.com/hunter_manuals.html - This site has the owners manuals for a list of Hunter thermostats. You will need your Model Number.
Apr 03, 2011 | Heating & Cooling
Thermostat control
I would like some help programing the thermostat in my house. Hunter, Model 44300A
Thanks,
May 05, 2008 | Hunter 30124 Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Cris Sparks
Cris Sparks
