I want instructions on replacing the C4557-4009 carriage drive belt in a HP OfficeJet R80xi all-in-one printer
  • wrbow02 Dec 14, 2008
    > Dear Fixya.com
    You did not provide any information that was useful in solving my problem with the HP printer. I wanted a step-by-step procedure for gaining access to the carriage drive to replace the drive belt. There is no obvious screws or pins that I can remove to do this. I do not believe that there is an assembly manual that is available tho they were prompt in shipping the drive belt for $47. Please credit my charge card account. I have bookmarked your site for future reference. Thank you for your prompt reply.
    William Bowman
  • 4,806 Answers
Hi there
Paste this web address in the address bar or click on it, it will take you through to the assembly diagrams of all the parts in the printer, just click on the "View a parts diagram" tab
http://www.partsurfer.hp.com/cgi-bin/spi/main?sel_flg=modinfo&HP_model=C6689A
best of luck and thanks for using Fixya!!!
Posted on Dec 14, 2008
  • Lee Hodgson
    Lee Hodgson Dec 14, 2008
    just in case you think i have the model number wrong theis is the actual #
    OfficeJet R80xi (C6689A)
    kind regards
    Master:
  • 479 Answers
Its not at all hard to replace the carriage belt.you will just have to open the printer first and then after opening the front and sides of the printer then you will have to remove the side clips that are attached to the printer with a round clips just will have to pull that round clips to open them.then after opening the round clips the steel rod on which the carriage moves will come out and then you can also slide the carriage on that rod and remove the carriage from the 1 side of the rod.then in the back its made a mark to fit the belt.its exactly ---C shaped or u can say S shaped.also it looks like a small speed breaker which u see on the roads.there you can just fit that belt in the C and rearrange all the parts again as they were.it will work properly after that.
  • 275 Answers
There is a HP OfficeJet/Color Copier Service Manual here : http://www.fixyourownprinter.com/specials/manuals/all/S32
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, I was made to understand that Torx bits are needed to install (4 screws for T20 and 3 screws for T10, depending on the regional version). A pictorial for a closely related chassis that may serve as guide/reference.
Good luck and Thank you for using FixYa. Happy Holidays.
Posted on Dec 11, 2008
  • Louie  Role
    Louie Role Dec 12, 2008
    Hi again,
    Any updates or developments so far?
  • 19,396 Answers
    Master:
  • 474 Answers
Well, those compact all in one HP printers arent meant to be repaired as much as there meant to last till warranty is up and **** out. The use flimsy plastic parts that break easily when trying to open it up, but, if you want, I can try, but im more familiar with the big bulk printer for offieces rather than the small ones.
You will of course have to take it apart my removing any removable treys and ink cartdridges, The drive belt is usually located in the back on the big ones but that one may have it more in the center.
You would remove the top and should have access to the belt, it may be attached to the fuser, which gets very hot and melts the ink to the paper.
The belt is usually attached to the fuser because its rolls the paper through and out and drives several gears.
Now this isnt really a solution as much as it is advice as i havent done one of that model.
You will have to learn as you go, but never force anything plastic. When plastic starts breaking, you might as well chunk it as these parts are hard to get.
HP may provide you with an actual repaire manual if you call them.
Good luck
How to clear carriage jam on a hp officejet all in one printer?
Lubricate the carriage, check if carriage belt is damaged, replace.
Jan 15, 2015 | HP Office Equipment & Supplies
THE CARRIAGE DRIVE BELT ON MY HP OFFICEJET 6110 ALL IN ONE IS BROKEN, HOW DO I FIX THIS?
Once belt is broken, you'd better check with A/S center.
Personally, I was trying to fix my printer by myself..... well was not easy it is.....
Apr 26, 2011 | HP OfficeJet 6110 All-In-One InkJet...
Need instructions to replace carriage belt for hp designjet 500, specifically how to remove and replace on the carriage assembly
When you order the belt from hp it will come with the instructions, if not email me and I will send it to you.
Jul 12, 2010 | HP DesignJet 500 InkJet Printer
Replacement instructions for ink cartridge carriage assembly
Please follow the link below to HP Web site. This will take you to the HP 7410 Setup Chart. The cartridge instructions you need begin in frame 10.
http://h10032.www1.hp.com/ctg/Manual/c00236206.pdf
Don
Oct 22, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Message says carriage is stalled
Please Click Here and follow the instructions on the document to resolve this issue.
May 26, 2009 | HP DeskJet F380 All-In-One Printer
When i turn on the printer, i get a "Cartridge carriage blocked" message on the LCD screen
Remove the cartridge and reinstall it. The problem generally arises for not placing the cartridge properly inside the printer
Mar 15, 2009 | HP OfficeJet R80xi All-In-One InkJet...
HP 170 Color Copier Carriage Belt Replacement
My carriage belt has broke is there anyone who can repair it, or how can I fix it. H P Copier Model 170
Feb 04, 2009 | HP 180 Color Copier
Carriage belt replacement for HP 430
http://www.fixyourownprinter.com/forums/inkjet/36780
Fifth post down.
I changed the carriage belt using these instructions.
Hope that helps
Jan 08, 2009 | HP DesignJet 430 InkJet Printer
Black ink Catridge
Sorry but I did not fix the problem. I will attempt to fill the gap at the bottom of the cartidge maybe with a piece of cardboard. Otherwise I will have to do something else since I do not own a credit card and I am from far in Malta in Europe. Thanks for your care.
Aug 26, 2008 | HP OfficeJet R80xi All-In-One InkJet...
Black ink carriage broken
with most laser printers nowadays, it would be easier to junk the one you have and go buy one from wal-mart or someplace of the like than to have it fixed. most printer manufacturers dont even sell replacement mechanical parts through their sites anymore... its just not cost effective to either the producer or consumer.
22 people viewed this question
jasbo
jasbo
