Question about Car Audio & Video
I have a kicker 12 xpl that wont play mabey blow how do your determan and can it be fixed I checked the connection the lead directly to speacker and the terminals ?
  • 85 Answers
Here is one quick little way to test the speaker.
Disconnect the wires from the amp that go to the speaker and touch them to a 9 volt battery.
If the speaker moves and you hear a sound then it is NOT blown and if you hear nothing and it does not move then chances are you have a blown woofer.
There are of course other more technical ways to test it with a digital millimeter but the simple 9volt battery quick test is easiest.
If t he voice coil is shorted and blown then there is usually no way to fix that and you would have to replace the speaker. (Some speakers like JL Audio W7 series have removable voice coils that can be replaced but most speakers do not.)
Posted on Dec 11, 2008
There no sound i thought it was the speaker but the red lights on i think its in protect mod
protect is a thing where if ur speacker wires touch it doesnt blow the amp . it could be just inside the amp
Jun 13, 2011 | Kicker Car Audio & Video
I have a Kenwood 720 amp powering 2 12 inch kicker cvrs..the amp will work fine for a few second then the bass starts skipping out and the amp shuts off..
check speakers impedance are matching amps. example: if you drive a 4 ohm amp with lower imp you are close to blow your amp or it goes to protect itself from you. anyway your amp provides 140watts maximum on 4ohm in bridged mode, so if you connect two 12" kickers with 4ohm, they will have 2ohm in parallel connection. solution would be to connect them in row (serial) but impedance will go up to 8ohms then.
Thanks for using FixYa - a 4 THUMBS UP rating is appreciated for answering your FREE question.
Feb 26, 2011 | Kenwood Car Audio & Video
I have a kicker 750.1 amplifier. I was playing it one day pretty loud and it cut out once the bass hit and started smoking.The gain was up about 1/4 and the bass boost was about half way. what could of...
I would say that your subwoofer Or speaker leads have shorted out...when the bass hits as you say it drives the amp hard but if it is trying to dump power onto a shorted speaker or speaker wires it will blow the output power transistors not to mention other vital components of the power amp...i suggest you test your speaker leads with a Multimeter on the ohm setting before connecting a repaires or another amp.. to make sure there is no short on the leads and that the resistance is around 4 ohms or so depending on how you have your drivers wired...but anything lower than 2 ohms will cook an amp! you can normally pick up a meter from anywhere for around $10..
Jan 14, 2010 | Kicker (ZX750.1) Car Audio Amplifier
Kicker 07DCVR122 Dual 12
get a 2 channel with as much watts as you can affored. you wont blow them its better to have to many watts then not enought the subs work harrded with less watts i know that sounds crazy but trust me je
Nov 13, 2009 | Kicker DCVR122 -- 2 Ohm Dual 12in CompVR...
I think ma kicker kx1200.1 amp is blown or ma kicker L7 are gone
that would be the amp. sorry to say. when a wire crosses over, it sends a shock through the amp, there are a few things to try just to see if you fried the amp. the first thing to try is to move your ground to a different location. second thing to look at would be the fuses. alot of times the fuses will blow at the slightest shock. the amp will still turn on if you have an amp with 2 fuses, it just wont be getting all the power it needs, which could be causing your problem. also, it is worth the hour and a half to mount everything down in your vehicle. you might check the kicker website, because i have herd rumors that kicker offers a lifetime warranty on almost all of their products. best of luck, and i hope you didnt fry your amp.
Apr 09, 2009 | Kicker KX1200.1 Car Audio Amplifier
Need help with my Kicker Amp
Some amplifiers don't work well if the signal source has no connection to chassis ground, This could have caused instability in the amplifier and caused it to fail.
It's also possible that the amplifier had a manufacturing defect.
Aug 12, 2008 | Kicker ZX350.2 110W x 2 Car Amplifier Car...
Kicker 750.1 Amp wont play music
it is probably the rca inputs on the amp may have fried. was your cd decked turned up loudly before the power went out? did any wires accidently touch each other? If had worked fine and then suddenly stopped, than either a wire came loose or the inputs fried. try using different cables and I also suggest disconnecting power for 24 hours and then reconnect. If the green light is on then it is getting power and the problem is in the rca cables or the inputs
Jun 03, 2008 | Kicker 06ZX750.1 Car Audio Amplifier
Goes into protection mode for no reason
if the amp is powering on the sub and playing and then turns in to protect mode it could be the amp is getting hot and its kicking into protect so you wont fry the amp
May 06, 2008 | Kicker 06ZX750.1 Car Audio Amplifier
Car Audio & Video Logo
129 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
