Question about Whirlpool GEW9250 Electric Dryer
I HAVE A WHIRLPOOL DUET GAS DRYER MODEL NO. GGW9250PL0 THAT KEEPS BEEPING EVERY FEW SECONDS AND THE DIGITAL MINUTE DISPLAY IS ERRATICALLY CHANGING THE NUMBER OF MINUTES WHEN TRYING TO SELECT DRYER SETTING. DRYER CONTINUES TO WORK THOUGH. IT DOES SEEM TO TAKE A LONG TIME TO DRY TOWELS, BUT I MAY NEED TO CLEAR VENT THAT GOES UP WALL. ANY IDEAS? THANKS!
  • geoffbrunet Dec 19, 2008
    I have the same problem, called the local tech, he seems to think that there is a problem with the electronic board. Mine also beeps eratically once in a while and we now have some settings that we cannot select (normal, bulky items)
We had the same problem. Sometimes unplugging it for a few days, it would work when plugged back in. We replaced the user interface which is part #19 on the Whirlpool parts list, the front circuit board. The part alone was $160 at the cheapest place we found. http://www.appliancepartspros.com/
Posted on Feb 11, 2009
WHIRLPOOL DUET GAS DRYER WGD87HEDW1
Unplug for 1 minute. Plug back in. Check status
Apr 17, 2016 | Whirlpool WGD87HEDW Duet WGD87HEDW 7.4 cu....
Whirlpool Duet Gas Dryer, runs about 2 seconds then shuts down. Time remaining display flashes
raoul answered just now
come fare il reset della scheda della lavastoviglie whirlpool ADP 5555 per cancellare un errore dovuto a sensore sporco? non vorrei chiamare l assistenza solo per questo.
Grazie
Feb 06, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Duet dryer wont unlock from the lock mode, even after holding the control lock for 3 seconds
Here's a video prem mathew suggested as a solution to your problem from YouTube:
Whirlpool Duet Dryer
Apr 19, 2013 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
How do I stop my washing machine door alarm beeping?
do this and fix it. God bless you
However read the instr. manual section troubleshooting /
if doesnot have download from www.fitness.manualsonline.com
The processes below will get most controls unlocked.
Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 15 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 15 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 15 seconds.
Some Models- Press and hold the control lock button for 15 seconds.
If none of these work try unplugging for 5 minutes
Sep 28, 2012 | Hotpoint WMA74 Front Load Washer
go to instru.manual section troubleshooting and fix it. God bless you
if doesnot have it download from www.fitness.manualsonline.com
However try this.
Sep 28, 2012 | Hotpoint Ultima WF860 Front Load Washer
Whirlpool duet dryer stuck on control lock mode
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 27, 2010 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
1989 Magic Chef gas range digital display keeps beeping and says
This is a common failure in the control board. Here is an article that discusses the details.
http://www.fixyourboard.com/techzone/ovens/f1_error/f1_error.html
We repair a lot of these at www.fixyourboard.com, so you don't have to scrap out your oven.
Jun 26, 2010 | Magic Chef Kitchen Ranges
Whirlpool gas dryer heat goes on then off then on again
should have electronic igniter that light gas after turned on.
Jan 03, 2009 | Kenmore 73952 Gas Dryer
Whirlpool Duet Dryer WED9600 Beeping during drying
Dear Customer
Please perform the following
please rate this,thank u
Dec 16, 2008 | Whirlpool GEW9250 Electric Dryer
MY CONTROLS ARE LOCKED
Press and hold the End of Cycle button for 3 seconds.
Jun 05, 2008 | Whirlpool GEW9200L Electric Dryer
Whirlpool GEW9250 Electric Dryer Logo
477 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
