Question about Kenmore Dishwashers
Cloudy water. Vinegar doesn't help after several times.
Water tasted funny, so realized it is small powdery stuff in water from glasses. Put about a half cup vinegar in there and ran, then added more vinegar, and still didn't help. Removed white plastic drain vent thing and cleaned it and repeated (it had large clumps and small clumps of old detergent underneath that couldn't be seen on top, but when took off saw it). Still didn't help at all. We have been using the new gel and detergent little cube pack things of detergent (on third bag) and wondering if this is it. We have hard water too. When ran dishwasher and pryed open lock with screwdriver to watch water action. Water looked slightly sudsy and definitely cloudy coming out of thing in middle of bottom. Doesn't look like there is any way to unscrew parts to clean anything from inside. Don't know if running it more will help (bet we have ran 3-5 times so far with no detergent and still a problem just as much as first time). We put vinegar in the jetdry thing and it is still in there-some of it, from running it before. Also we put vinegar in the dishwasher freely.
  • Anonymous Jan 28, 2009
    I had the same problem. I too have very hard water. We found the liquid soap was the worst. The best soap we found has the Power ball in the little packs. And also jet dry ~ get the ones that are the dry stuff in the basket and not the liquid. Wash all your glasses by hand once to get rid of the clouds( In vinager). And then use you dishwasher as usual. You should find a big difference.
  • 41 Answers
You have an issue ? you have a soap & hard water build up you need to first break down the lime build up you need to purchace a commercial grade descaler buy it from your local rest. supply co. pour 1qt. into and run a cycle then you need to break down the soap build up this is the fun part boil water add to unit this will help soften the soap and run a cycle you may have to do this several times. buy a liquid soap after . if this does not help ypu will have to tear the unit down and clean by hand good luck
Posted on Dec 12, 2008
Bosch SHZ46B does not seem to heat water properly - only to 120F. Glasses and dishes are left with whitish film.
If you have hard water, glasses can look spotted and cloudy even after cleaning. Sometimes changing the dishwasher detergent can help. The easiest solution to clearing up glasses that start to look cloudy is to add some vinegar to the bottom of the dishwasher before you start a cycle. Simply add 1 cup of white vinegar and it will clear up your glasses very well.
You should see marked improvement after the first time you do this. If they are not crystal clear then simply repeat the process until all of the cloudiness is gone. In fact I recommend to using a little vinegar in each cycle to maintain the clarity of the glass.
Note: you can pre-test this by rubbing some vinegar on an individual glass with a cloth. If you cannot remove the cloudiness by soaking it and rubbing vinegar on it then it is possible that the glass is etched due to harsh or cheap dishwasher detergent and vinegar will not solve the problem.
Feb 15, 2011 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
White film over glasses . still water in bottom, not cleanign dishes.
If you have hard water, glasses can look spotted and cloudy even after cleaning. Sometimes changing the dishwasher detergent can help. The easiest solution to clearing up glasses that start to look cloudy is toadd some vinegar to the bottom of the dishwasher before you start a cycle. Simply add 1 cup of white vinegar and it will clear up your glasses very well.
Dec 18, 2010 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
I have sediment depositing on all my glasses. Also I have a white film on the bottom of all the glasses. We have a soft water system and the white film has gotten a little better but the sediment is...
If you have still have some hard water present, glasses can look spotted and cloudy even after cleaning. Sometimes changing the dishwasher detergent can help. The easiest solution to clearing up glasses that start to look cloudy is to add some vinegar to the bottom of the dishwasher before you start a cycle. Simply add 1/4 of white vinegar and it will clear up your glasses very well.
Dec 03, 2010 | KitchenAid 34 in. KUDV24SE Built-in...
Is our dishwasher no good? We have hard H20 and practically rinse clean our dishes, untensils & glasses before we load it. We never use it for pots & pans. There's a sort of soap scum on the...
If you have hard water, glasses can look spotted and cloudy even after cleaning. Sometimes changing the dishwasher detergent can help. The easiest solution to clearing up glasses that start to look cloudy is to add some vinegar to the bottom of the dishwasher before you start a cycle. Simply add 1/4 of white vinegar and it will clear up your glasses very well.
Nov 28, 2010 | Maytag Dishwasher
Some of our dishes in the top and bottom rack are showing a white film, especially on plasticware and the outside of pots, pans, ceramic or regular glasses. Also some glasses on top rack , but not all,...
Nov 19, 2010 | Amana 24 in. ADB1500AW Built-in Dishwasher
DISHES KEEP COMING OUT DIRTY GLASSES HAVE A FILM ON BOTH CABINITS CHECKED FOR BLOCKAGE IN BOTH UNITS,CLEANED NOTHING WORKS, WATER IS HOT TRIED LOTS OF DIFFERNT SOAPS NO HELP
Oct 31, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
The machine does not seem to rinse properly. We have checked the water fill level, water temperature, spray arms are not clogged, have determined it is not a hard water problem and have tried Glass Magic...
Sep 23, 2010 | Whirlpool GU2700XTSS / GU2700XTSY Built-in...
Cycle timer displays very different times for cycle, cleaning is not particularly good. Problems related? glasses appear filmy, even when rinse agent is used.
your dishwasher uses an optical sensor to constantly monitor the water turbidity or cleanliness if it detects the water is cloudy it will extend the wash time and vice versa there are several reasons for cloudy glasses check to see if they taste salty,or if the cloudiness washes off,this usually happens when the baskets are loaded badly and the detergents/temps are not set correctly.
Nov 08, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Funny tasting coffee
Vinegar/water cleaning is a good idea, but it won't necessarilly solve funny-tasting coffee. First, replace your charcoal water filter - you can get the Cuisinart brand-name replacements at Lowe's, Bed/Bath/Beyond, or Williams-Sonoma in most areas.
To do the vinegar/water cleaning, just pour 1/3 caraffe distilled white vinegar and 2/3 caraffe water into the water reservoir and brew it like it was regular coffee - I would simply bypass the self-clean function if your Cuisinart has one. Repeat up to 3 times, using a fresh batch of vinegar each time.
(if you have the caraffe-less DCC-2000, then just pour in 4 cups vinegar and 6 cups water).
Then run a full cycle of water. Then run a combo of 12 tsp lemon juice and 12 cups water (or 10 tsp and 10 cups water) to improve the taste.
On your next batch of coffee, use bottled water just to rule out any possibility that your local water supply may be contributing to funny-tasting coffee.
Now your coffee should be tasting fine again.
-Tha Mp3 Doctor
Apr 03, 2009 | Cuisinart Coffee Makers & Espresso...
Coffee pot
durabrand has no contacts outside china this is a unit made for and imported for walmart only walmart is the only contact ...... your problem is not anything you or walmart can do anything about the problem is the cheap plastic that is used , when it gets hot some people can taste and smell it and others cant . .. its getting more common in everthing that heats water .. personaly i would not drink anything from an appliance that puts a plastic taste in my water ..... if you move up in price the problem is reduced , better plastics are used , but your not going to get one for 10.00 ! "you get what you pay for " more now than ever .... good luck Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob
Mar 18, 2008 | RoadPro 12-Volt Coffee Maker
Dishwashers Logo
121 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
