Question about Linksys Wireless-G WRT54G Router
Ip address hi i did a system restore on my desktop comp, on that im using windows vista, since then my laptop (xp) is connected to the wireless but cnt connect to the internet!! i think its an invalid ip address, can you help?
  • Teis Thomsen
    Teis Thomsen May 11, 2010
    do you get a "propper" IP address from your routers DHCP server?
    - 192.168.x.x?
    /Teis
    Master:
  • 409 Answers
Reboot the laptop a couple of times and it should pick up a new address
Posted on Dec 12, 2008
Our laptop won't connect to our network set up on our desktop home computer. The desktop is running Windows XP Home Edition V2002, and the laptop is running Windows Vista Home Premium V2006. When we try to...
if you have wireless acces point or 802.11 known as wi-fi,
there might be a problem in your laptop internet protocol, you laptop have an ip address already.
you can fix it by using your desktop, open your desktop go to control panel/network connection/status/
details.
copy the details information and put it to your laptop internet protocol. you can found it in network connection properties you can see Internet Protocol (tcp/ip) open it configure it manually. the last number of the ip address must bigger than the desktop. ex, 192.168.1.2 in desktop. the ip address of the laptop must be 192.168.1.3.
Feb 02, 2011 | Acer Computers & Internet
I have a netgear n150 hooked up to my gateway laptop running windows 7, my gateway laptop running windows xp allows an internet connection but my gateway laptop running vista will not allow a wireless...
There might be a problem w/ your IP address or DNS server, try to open LOCAL AREA NETWORK CONNECTION STATUS in your laptop running xp, click support/details, Then copy the DNS server address and alternative dns server address.
open your vista go to Network Connection/LAN properties, then double click Internet Protocol (TCP/IP, mark obtain ip address automatically, then the lower side Mark USE THE FOLLOWING SEVER ADDRESS then paste the dns server address which you copied from xp laptop. same w/ alternate dns server, and then click OK. DONE.
JUST TRY IF ITS HELP FULL.
Jan 15, 2011 | NetGear WIRELESS-N 150 ACCESS POINT WRLS...
How do I hook up your router to make my laptop be wireless........it has to go through a contrend router that is on my desktop computer
Configuring a wired computer to get an IP address automatically will enable it to get an IP address from a DHCP server. Instead of manually entering the IP settings which will consume much time, performing this procedure will ensure that the computer will get the correct TCP/IP settings.
Configuring a computer to get an IP address automatically is useful when:
  • Connecting a computer to a network with a DHCP server. Ensuring that the computer is getting the correct TCP/IP settings.
To configure a computer to automatically get an IP address, you have to check the TCP/IP properties of the Ethernet Adapter installed on the computer. Follow the steps below for instructions.
NOTE: Make sure the wired computer is properly connected to a network with a DHCP server.
Checking if the Computer is Set to DHCP
NOTE: The instructions provided below only apply to Windows 98, ME, XP and Mac operating systems. If you are using Windows Vista, click here for instructions. For Windows 7 users, click here for instructions.
Windows 2000/XP
Windows 98/ME
Mac OS
Sep 10, 2010 | Linksys Wireless-G WRT54G Router
I cannot get my laptop to connect to the internet either wirelessly or hard-wired. I have two other laptops, connected wirelessly, and a desktop connected via hardwire. It recognizes the router but says...
if you are trying through wireless, first unplug the wire from the laptop,
make sure that the wireless switch on your laptop is turned on.
click on start, control panel, network connections/network & internet/ Network and sharing center..
right click on wireless network connection Icon, if it says disable, it means it is enabled already.
then click on status..
from here the steps would differ from OS to OS
then click on Support tab (for XP)
check the address type, it should be "Assigned by DHCP"
and if you see the IP Address starts with 169., it is a bad IP and needs to disable the connection and enable it.
if the connection type is "Assigned Manually, right click on wireless network connection icon and click on properties and click Internet Protocol(TCP/IP) and click on properties, in this window, check the option "Obtain IP Address Automatically from DHCP"
click ok and OK ..
again right click on the wireless network connection icon and click on view available networks... click on your router name and click on connect..
now check the functionality.
if you are using windows 7 or vista,
click on status, click on details for the IP Address..
We see DHCP Enabled as YES or NO instead of "Adress type"in XP
if it says no, it means it is assigned manually. to change to DHCP , right click on Wireless Icon, select properties, click on IPV4 IP address and click properties, then select obtain automatic..
then try again..
hope this works,
Narendra Tirunahari
Feb 18, 2010 | Gateway 7330GZ Notebook
Hello sir . I have taken a belkin wireless G PCI card last month.i am using in the institution provided wi-fi net work in the hostel. Card catch the network but detach immediately and also not carry pocket...
well!! I have an answer for you.your comp is loosing the IP address. goto start - programmes - accessories - dos prompt. type ipconfig.you`ll get ip address,subnet mask,default gateway.copy it. goto network and sharing center in vista and network connection under control panel in XP,IN Vista,click on view status,goto properties and double click on internet protocol(tcp/ip) or IPv4In XP,right click wireless network connection and goto properties and double click on internet protocol(tcp/ip).type in the IP address,subnet mask,default gateway.in DNS server address type the default gateway in primary DNS and in secondary 4.2.2.2. your connection won`t drop after this.
Jun 29, 2009 | Belkin - F5D7000 - 54Mbps 802.11g Wireless...
Abit wireless adapter unable to locate wireless network
well!! I have an answer for you.your comp is loosing the IP address.connect your computer through cable then goto start - programmes - accessories - dos prompt. type ipconfig.you`ll get ip address,subnet mask,default gateway.copy it. goto network and sharing center in vista and network connection under control panel in XP,IN Vista,click on view status,goto properties and double click on internet protocol(tcp/ip) or IPv4In XP,right click wireless network connection and goto properties and double click on internet protocol(tcp/ip).type in the IP address,subnet mask,default gateway.in DNS server address type the default gateway in primary DNS and in secondary 4.2.2.2. your connection won`t drop after this.
Jun 26, 2009 | Abit (WLP-01) Wireless Adapter
MN-520 wireless adapter will not connect.
well!! I have an answer for you.your comp is loosing the IP address.first connect your computer via cable then goto start - programmes - accessories - dos prompt. type ipconfig.you`ll get ip address,subnet mask,default gateway.copy it. goto network and sharing center in vista and network connection under control panel in XP,IN Vista,click on view status,goto properties and double click on internet protocol(tcp/ip) or IPv4In XP,right click wireless network connection and goto properties and double click on internet protocol(tcp/ip).type in the IP address,subnet mask,default gateway.in DNS server address type the default gateway in primary DNS and in secondary 4.2.2.2. your connection won`t drop after this.
Jun 26, 2009 | Microsoft Broadband Networking MN-520...
HI running vista, cann't figure out how to set the ip address to see if this will boost a wireless signal?
To boost the wireless signal you will need a longer antenna to connect to your wireless card (if it's a desktop)or buy a USB wireless stick with antennas for laptop.
To view the ip address in vista do the following :
http://www.ehow.com/how_2056398_change-ip-address-windows-vista.html
second problem ,is the sim card correctly inserted into the Orange adapter.
have you entered the pin code before clicking on connect?
May 06, 2009 | Computers & Internet
Vista cannot connect to xp printer
It sounds like your are using your Windows XP computer as the print server, and you are trying to connect your Windows Vista machine to the Windows XP print server. Your Vista machine is trying to download the XP drivers from the Windows XP computer to your Vista machine. This won't work. Windows XP and Vista print drivers are not compatible.
If the printer is truely networked (it has it's own IP address on the network, it has its own ethernet connection). Then instead of trying to map out to this shared printer, add new printer to the Vista machine using Vista drivers for the HP Deskjet 3940. The type of port you would need is a standard TCP/IP port. To get this address, print a settings page from the printer. Look for either a TCP/IP address or IP address on this print out. This is the port address you want to create and then connect to.
May 04, 2009 | HP Computers & Internet
How to connect a laptop having vista home basic with a xp desktop
Be advised that,
it makes not different to connect one PC/Laptop to another one via LAN because when you connect your system in lan networking you system will be automatically detected if LAN has been set up through a server.
And if not you need to do manually by assigning ID address on bot PC/Laptop.
For that,
first assign an IP address in either Laptop or desktop (IP address must be same category)
ex.
192.168.1.231 (first one)
and second one should be
192.168.1.here you can up (instead of 231) any number excep 0 but make sure not confliction between other system. means not duplication IP address on same LAN.
once you ae done with IP assigning
Go to
Star>Run>command and hit enter
once you see command prompt then
type there:
ipconfig and hit enter (it shows your ip address) if you wanna have more info then type ipconfig/all
once you are done with this then
you need to ping to your next PC.
for that
type in
ping 192.168.1.231 (means you need to type another PC's IP address here)
and hit etner
if you see like on image
then you are good to go.
Thank you
and rate all answers.
Jan 02, 2009 | Microsoft Windows Vista Home Premium with...
Linksys Wireless-G WRT54G Router Logo
93 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
