Question about E-Machines eMachines Monitor E15T4
Monitor won't display background
It works great when turned on, but after password is typed, screen goes black and stays like...i've realized that the image is there and computer and monitor is working cause i can get on the net when i use certain keys on the keyboard(ctrl-alt-delete, then to task manager, and then theres a link there that goes to the internet), a guess that i have made is that the system is working great, but the screen has been illuminated or blocked by something(virus maybe) that i just don't know how to fix..
  • Sam Vaina
    Sam Vaina Dec 14, 2008
    even if its on safe mode, the screen still does'nt show....please man,,i really need help with this problem...if i don't fix it, my parents will be so pissed with me....
    however, if you cannot, i appreciate the help you've offered...
    Scholar:
  • 86 Answers
The only thing about your solution mookid is that when you are in safe mode it uses a safe resolution and refresh rate so if you are experiencing problems like too high of a resolution then you will not be able to change the settings by simply trying to change them in safe mode... The only fix this is to un-install the Video Adapter in safe mode and then boot back into Normal mode and install the driver. This will reset the settings completely.
Posted on Dec 18, 2008
  • 148 Answers
Reboot, and hold down F8. Select safe mode. Once it has finished loading and you have logged on, right click on the desktop and select properties. Are there any settings here that are wrong?
Posted on Dec 11, 2008
Latitude B130 screen works great then cuts out to complete black, works with external monitor
Are you sure that the display is not set for external monitor only? Also take bright flashlight and shine on the display. If you can see the images then the problem is with the back light and usually caused by a bad inverter. Some times you can get the back light or inverter bu most times it is easier and cheaper to replace the entire display.
Aug 20, 2012 | Dell LATITUDE Computers & Internet
Green horizontal
I believe that you must reset the colors of the screen by the buttons on it or try to set colors by the software that the product came with it if any. There should be a setting to configure the 4 basic colours like red green black etc. Try to adjust green. If nothing helpes go the monitor back to test it by the store you bought it if there is warranty. Hope that helped!
Mar 23, 2010 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
Gateway FPD1750 monitor's keep go black screen, no picture at al
tgordon60, If you know how those NEW "CURLIE-Q" energy efficient CFL light bulbs produce WHITE LIGHT, then you will know what makes an LCD display panel produce all the pretty colors and the WHITE BACKGROUND of the FIXYA web page!!! Only difference is that your "cold-cathode-fluorescent-lamps" are thinner and straight, and hung on rear of LCD glass panel and have a DC to AC electronic ballast called an "INVERTER" circuit to produce 600 to 1000vac to light them up. Get to my FIXYA profile and read my responses to other BLACK screen lcd owners to learn about all your options for repair. Follow any of the links to other web pages you find there. Your monitor not any different than ACER, DELL, VIEWSONIC, BENQ, SONY, AOC!!!!! 12fixlouie aka louie12fix
Dec 30, 2009 | Gateway Computers & Internet
Computer Turn then a flash of white type with a black background
connect your machine in an external monitor to check if the display is okay on the external monitor. if yes, the problem would the the LCD screen from your laptop. you might need to replace it. also, check if the video driver is correctly installed. if not, re-insatall your video driver. if there's no display on both panel i suspected it's a motherboard faulty.
May 25, 2009 | Computers & Internet
Monitor flashes on then goes black.
I think you have the display shut off. the button on the bottom left will shut screen off. It will come on for a few seconds if you touch the screen, but will shut off again. just push the display button again and it should stay on.
Apr 02, 2009 | ViewSonic OptiQuest Monitor
HP 15 in. Flat panel Problem
plug in a different monitor temporarily, check your display settings (right click background, settings, advanced, monitor) and set refresh rate to 60hz. plug in this monitor again and see if that helps some monitors (lcd's especially) cannot handle beyond 60hz
Aug 14, 2007 | HP vs15 15"LCD Flat Panel Monitor
PC starts fine, then the montor blinks and no display. light stays green
This is most probably cause by one or more Faulty Electrolytic Capacitors, I find these are the MOST commonest form of "Fault" in these LCD's TFT's units. I ususally simply replace "On Spec" all High Value Electros, in fact ALL Electro's are suspect and often I just "Shotgun" and replace 'em all. Usually fixes all problems. Always use High Temperature Caps. Try this as it is a common problem I find a lot. Good Luck.
May 24, 2007 | ViewSonic VX900 19" LCD Monitor
Monitor sleeps after one second
Try connecting the wires properly. try changing the VGA cable. i had the same problem my screen goes black some times and pink i changed the VGA cable it was absolutely fine!!!
What is VGA cable
VGA Cables Adapters Converters and Devices C2G
visit a computer mechanic for further trobleshooting
Mar 17, 2017 | AcerView F51 15 in. Flat Panel LCD Monitor
E-Machines eMachines Monitor E15T4 Logo
57 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
