Question about Apex Digital GB5108 51" Rear Projection EDTV-Ready Television
Apex projection tv, model GB5108
This tv is stuck in U Sintl mode, or channel, whichever it is. And of course the original remote is lost, and seeing as how they don't make the remotes anymore I had to order a 'copy' replacement. When I got it, I tried to use it but no luck. Is there anyway I can get the tv out of U Sintl??
SOURCE: Apex Digital GB4308 remote
Programming the Remote Control Remote-control switchover Press VCR/DVD, SAT/CABLE or AUX to select the device you want to control. To program the remote control Press and hold VCR.DVD, SAT/CABLE or AUX for over 2 seconds until the LED on the remote control turns off. Release the button the LED will light again (the remote control enters the PROGRAMMING mode). Enter three-digit code number for your equipment. If the correct code number is entered, the LED blinks three times. If you enter a code not listed below, or you press any other buttons than SEARCH and 100+, the LED turns off. To search codes Press ad hold VCR/DVD,SAT/CABLE or AUX for over 2 seconds unil the LED turns off. Release the button (the LED wil light again) and the remote control enters the PROGRAMMING mode. Press SEARCH. Press CH+/- to search codes downwards or upwards. Each time you press CH+/-, the code number decreases or increases by 1 while the remote control sends the code number for POWER button on your device. If the desired code number is found,press 100+ to program the code for your device until the LED blinks three times.Then the remote control exits from the PROGRAMMING mode and returns to norml operation. Or press any other button to exit from the PROGRAMMING mode after the LED blinks rapidly eight times, and the operation is not active. To check the current code number Press and hold VCR/DVD, SAT/CABLE or AUX for over 2 seconds until the LED turns off. Release the button (the LED will light again) and the remote control enters the PROGRAMMING mode. Press 100+ . You may read the code numder according to the LED display status as follows. * If there is no operation within 20 seconds during the steps mentioned above, the remote control will automatically exit from the appropriate operation. Code Number First - digit 0 1 0 1 Second - digit 0 0 4 5 Third - digit 0 6 3 0 First - digit Blinks rapidly once Blinks once Blinks rapidly once Bliks once Secod - digit Blinks rapidly once Blinks rapidly once Blinks four times Bliks five times Third - digit Blinks rapidly once Blinks six times Blinks three times Bliks rapidly once
Posted on May 01, 2007
SOURCE: NO SOUND FROM MY APEX GB5108 TV
I had the same problem with mine, it turned out to be a fried audio board. I simply used the audio outputs on the back of the tv to drive a new reciever with surround. Sound a heck of a lot better than the speakers built into the tv.
Posted on Sep 11, 2008
SOURCE: Apex GB5108 Convergence and screen issues
TWO INLINE FUSES ON THE POWER SUPPLIE BOARD, ALSO THERE TWO CAP 470@25 AND A 1000@35 THESE WILL LEAK UNDER STRESS. JOHN PATE WITH JOHN'S QUICK REPAIR.
Posted on Oct 05, 2008
LUKIS NEILL
  • 73 Answers
SOURCE: wavy picture vertically
if you have the speakers on top of the television or a phone near it might becaused by this
Posted on Apr 09, 2009
  • 90 Answers
SOURCE: Hello, I have an Apex GB5108 and it has a
I am not familiar with this particular set, but it sounds like you have no vertical deflection, which would mean your vertical output IC may be bad. The # on those ICs usually start with LA and is mounted to a heatsink.
Posted on Jul 30, 2009
Hi, I own a Apex gb 5108 TV, remote control is lost, can you tell me if any brand of "universal" controls will work on my TV? In my country there are not to many options...
universal controls dont work well with this tvs to change channels you have to go up or down you cant select a channel because of the button on the original control it has to be put in how many digits you want the best thing is to order a new one
May 08, 2011 | Apex Digital GB5108 51" Rear Projection...
I have a black line acrossthe center of my apex gb5108 tv. does anyone know if it is worth fixing?
hi
it should be changed just
if any body want to repair, it may be to expand the problem
Jun 02, 2010 | Apex Digital GB5108 51" Rear Projection...
Keeps changing channels on its own
Ur control button channels up/down button might stuck in pannel it self?Or the PCB control pannel itself it defective must be replaced.
Oct 22, 2009 | Apex Digital GB5108 51" Rear Projection...
My apex gb5108 convergence lines wont line up.I'm watching 3d
possibly the convergance ics have failed or convergance module
soldercon or both not a very costly repair
Aug 25, 2009 | Apex Digital GB5108 51" Rear Projection...
Wavy picture vertically
Apr 09, 2009 | Apex Digital GB5108 51" Rear Projection...
Aug 05, 2008 | Apex Digital GB5108 51" Rear Projection...
Apex gb5108
'I to am getting only wavy blue lines, no sound, doesn't even show channel indicators. TV was off for 4 days, came home turned it on and ten minutes later this screen appeared, it wont even show the menu screen, different channels or video inputs no sound either.
Jun 21, 2008 | Apex Digital GB5108 51" Rear Projection...
Apex rear projection tv
3 things to look at
1 did the bulb burn out
2 did a pet get behind tv and pull the video inputs out
3 is the remote input set for the right video settings to run tv
May 03, 2008 | Apex Digital GB5108 51" Rear Projection...
Apex gb5108
Your Convergence is off. Go through the menue to the CONVERGENCE and follow the on screen instructions.
Start with the RED gun and align each cross point starting with the upper left corner.
You will be pulling the red to match the green.
If the television shuts down during this process, it will reset the convergence and you can try again.
After you get the red gun perfectly aligned with the green, start with the blue.
follow the on screen directs and don't forget to store.
Use the remote for these adjustments.
I hope that this helps..
Jan 06, 2008 | Apex Digital GB5108 51" Rear Projection...
Apex Digital GB5108 51" Rear Projection EDTV-Ready Television Logo
Top Apex Digital Televison & Video Experts
Jaime Hernandez
robert landry
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
