Question about Dryers
Broken Belt on Whirlpool Dryer How do you get to the motor
I took the dryer apart and found a broken belt. Now I need to know how to install the new one I can't see the motor. System is sealed well.
  • 1 more comment
  • jlebling Dec 12, 2008
    GEX9868JQ0
  • Jeff Rockwell
    Jeff Rockwell May 11, 2010
    What is the dryer model number?
  • Anonymous Mar 27, 2014
    broken dryer belt
  • 5,911 Answers
Okay...follow these steps:
1. UNPLUG the dryer before servicing.
2. Lift the lint screen door on top if the dryer and remove lint screen.
3. Remove the two screws under the lint screen door.
4. With the screws removed, the top panel will slide towards you, then lift up. Open the panel up and rest against the wall.
5. Carefully disconnect the door switch connector plug (white plastic connector).
6. With the door securely closed, remove the two screws that hold the front panel in place. There should be one screw on the interior cabinet on either side. Position your body to hold the panel in place as you remove the screws in order to prevent the panel from falling.
7. With the door latch disconnected and screws removed, the entire front panel should lift up and off. Set aside.
8. You should have access to the dryer interior now. The drum is designed to be removable. You can replace the belt with the drum in place, or remove it. The choice is yours. NOTE: This is a good time to remove the drum and inspect the dryer interior for lint build up and lubricate the drum roller supports.
9. The following link will explain how to properly route the dryer belt on your dryer:
http://www.repairclinic.com/0079.asp
Scroll down to "Whirlpool". You should be using diagram H.
NOTE: If you removed the drum, make sure it is properly re-installed before installing the belt. This is accomplished by inserting the back of the drum so the rear groove rests on top of the rollers. While holding it in place and supporting the front of the drum, slowly rotate clockwise until you feel the rollers engage into the groove.
10. Re-install front panel by aligning the two small square holes on the back of the front panel bottom with the two small black cleats on the side panel front edges. This may require assistance if you cannot accomplish on your own. Insert panel and hold in place as you reinstall screws.
11. IMPORTANT: Reconnect door switch connector plug or dryer will not run.
12. Lower top panel back in place and re-install the two screws under the lint screen door.
I hope you find this information helpful. If you require further assistance, please let me know.
Posted on Dec 12, 2008
My belt is broken on my tumble dryer.took it apart and don't know how to put the new belt on
The belt goes around the drum, through the idler pulley onto the pulley on the motor. The idler fastens into several holes on the floor of the dryer.
Sep 29, 2011 | Dryers
Tip
Whirlpool Dryer Belt Diagrams and Replacement
Your dryer belt has broken and you have a new belt to install, but you do not know how to route the belt properly. Here are some pictures or diagrams to help you see how the belt needs to go. Of course the belt needs to go around the drum so that is not included.
The important part is the routing around the motor and the tensioner pulley.
For models with non-removable back panels use this diagram:
Style: Flat with ribs
Installation Tips: Ribs against drum
For models with removable back panels use this diagram:
on Mar 06, 2010 | Dryers
Belt broken
how to open a dryer:
http://www.partselect.com/dryer+new-whirlpool-open-cabinet+repair.htm
belt diagram:
http://www.applianceaid.com/images/belt-config.JPG
Jan 10, 2011 | Whirlpool Dryers
Changing dryer belt on kirkland/whirlpool dryer took apart dryer but dont see where belt suppose to mount.
Hello. The belt goes around the tub and the tension pulley. In fact, it is always a good idea to replace both the belt and the idler/tension pulley at the same time. J.
If you want a schematic go to searsdirect.com and enter your model number. J.
Jun 27, 2010 | Whirlpool LER4634J Electric Dryer
Gas dryer doe not rotate
It could be that the motor/drum belt has slipped off the pulley, or has broken.
You can unplug the dryer and pull it out from the wall and remove the rear access panel to see if you can see the belt and whether it has broke or slipped off the motor pulley.
If you need to get a replacement belt, you can get locally or online at several sources. If you want to attempt the repair yourself, you might want to look at how your dryer is put together. Go to searspartsdirect.com and enter in the full model number of your dryer and you'll see what it looks like and see a list of all available parts,
Just so you know, it will take some time to disassemble the dryer in order to get the belt installed and you'll likely need a hand getting the belt onto the drum once you get everything taken apart.
Hope this helps and best regards!
Aug 01, 2009 | Whirlpool Dryers
My Whirlpool dryer belt broke.
You should be able to reuse the idler pulley unless it is physically broken.
The idler pulley fits in the slots on the bottom of the cabinet (in front of the motor) with the wheel or glide facing the left side. Place the belt (grooves inward) around the drum. Pull the belt through the middle of the idler pulley from the left side and loop it around the motor pulley.
Let me know if you need more assistance.
Mar 28, 2009 | Whirlpool LER5636P Electric Dryer
Belt replacement
Take the belt with you to an appliance store and they will match it up. Much like a fan belt on a car. You won't necessarily need the model if you have the belt. Next, it sounds like your assembly is broken. If this assembly looks to be in pieces, you may need a new one.
Feb 03, 2009 | Kenmore 73952 Gas Dryer
Elec. dryer
remove the front panel,find the idler arm wheel,the belt goes under the idler wheel and onto the motor pulley,put back together-mike
May 27, 2008 | Kenmore 65924 Electric Dryer
Help me install belt on electric dryer
need model and brand of drier
Dec 30, 2007 | Dryers
Dryers Logo
136 people viewed this question
Top Dryers Experts
