Eva-Dry EDV300 Dehumidifier
Problem for Eva-Dry EDV300 Dehumidifier
How do I know what setting to use?
By Rogers - usenet poster
Solution #1
posted on Aug 08, 2005
Somewhat Helpful)
LiZzIe
Rank: Apprentice
Rating: 0%, 0 votes
We suggest that you buy a separate, good-quality hygrometer to determine the actual moisture content of the air in the room you want to control. Then, with a bit of experimentation, you can set the humidistat on the dehumidifier so that it cycles off when it reaches the humidity level you want to maintain.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Jan 08, 2007
Not Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
My dehumidifier does not shut off even after the lowest setting on the humidistat. No water in the bucket.
Solution #3
posted on Feb 07, 2008
Very Helpful)
LMLC
Rank: Guide
Rating: 90%, 3 votes
Below 50 per cent is usually recommended. Below 50 helps control mildew problems.
Was this helpful?
Yes
No
Popular Solutions for Eva-Dry EDV300 Dehumidifier
Questions and Unsolved Problems for Eva-Dry EDV300 Dehumidifier
Do you recommend Eva-Dry EDV300 Dehumidifier?
Answer
Answer
Doesn't shut off when RH reaches pre-set value; shows "P1" in the LED readout.
Answer
i need instructions on how to operate a 25 pint dehumidifer
Answer
I have a Kemmore Dehumidifier model 580.53650 and when you plug in the power cord it trips the surge... (More)
Answer
does not ice up at back anymore humidex 4
Answer
no problem just an inquiry...perhaps I should ask at what degree should I keep my lower level... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Eva-Dry EDV300 Dehumidifier:
Top Dehumidifier Experts
Rank: Guru Guru
Solutions: 1204
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Dehumidifier Experts
Top Air Conditioner Repair
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
