Question about HP OfficeJet 7310 All-In-One InkJet Printer
Remove and check color cartridge
I have an HP Officejet 6210. The error message reads remove and check color cartridge. I have cleaned the electrical contacts with distilled water as HP recommends on it's website. I have checked it is properly installed, and I have even replaced the cartridge, but I still get the same message. What else can I try?
    Sergeant:
    Novelist:
  • 327 Answers
The internal circuit of the printer which connects the colour cartridge is gone faulty so this error.that internal circuit needs replaCEMENT.thanks
Posted on Dec 15, 2008
5C00 Error Code as well as yellow and green alternating lights
To fix this error is much easier than it looks. Unplug the printer power. Move the ink cartridge cradle to the left. Over to the right you will see a small pad about 1cm square. This pad and the area around should be covered with ink. Get a cloth and press down on this pad - it's not fixed so should come away with the cloth, otherwise use tweezers gently. Squeeze the pad several times between your thumb and forefinger while inside the microfibre cloth to remove ink build up. Then when not much ink comes out on the cloth, clean the area in the printer around the pad so that looks free from ink too. Then position the pad back in place, move the cradle back into position, plug in and switch on - should work fine now.
Jan 14, 2017 | Office Equipment & Supplies
My MX922 printer worked well this morning. All cartridges have ink but ALL lights under the cartridges are on and print comes out blank. There are no error codes or anything abnormal displayed
This problem is mainly happens to all inkjet printers. If your printer print blank pages then please at least once go to official site of Canon and check whether there is any printer/scanner drivers update is available or not. If yes then download it. Also check your ink cartridges. Because if there is no print on paper that means your ink might be dry.Sometimes it clog the print head. If your ink cartridges get dry change it. Or you should clean your printer's print nozzle by using printer's control panel. I hope all these suggestions helps you. If doesn't then watch Canon MX922 Manual English
Jan 12, 2017 | Canon Pixma MX922
I replaced the K cartridge and i get this caution. I-Unit End Replace K
If "[Color name] Toner Empty. Replace with a new toner cartridge." is displayed and printing stops, replace with a new toner cartridge.
([Color name] indicates one of the following: C or Cyan, M or Magenta, Y or Yellow, K or Black.)
Jan 10, 2017 | The Office Equipment & Supplies
BROTHER P-TOUCH IS not printing
It is obvious it has a failed electronic component, since these are not repaired/exchanged except when they are under warranty best thing to do is just replace it.
Jan 09, 2017 | Brother Office Equipment & Supplies
My sharp color copier Mx 3100n is indicating F2-73 after using 88-1 how do I restore it
Hello Tijjani,
The error code that you are experiencing is as follows;
F2 73 IMPROPER TONER CARTRIDGE DETECTION (YELLOW)
You need to replace the yellow cartridge with the proper part # Item Number: MX 31NTYA, MX31NTYA.
Good Luck!
Rich Lilja
Jan 08, 2017 | SHARP MX-3100N
My Epson WF-3640 is printing with gaps in the text. How do I fix this issue?
Make sure you should remove shipping tape from the ink cartridge. These taps are used to protect printer during shipping but you have to remove it before starting printing. Beacuse these taps prevent the ink to entering in print head. If you will not found shipping tape in your printer then there is terr off strip, remove it. The tear off strip seals the the vent holes on the top of the cartridge to prevent it from drying out on the shelf or during shipping.
After ensuring that the shipping tape has been removed, run the printer's "Head Cleaning" utility to prime the cartridge, then print a test page.
See full detail at- http://guideusermanual.com/product-name-workforce-wf-3640-manual&po=152836&lang=English
Sep 18, 2014 | Epson WorkForce WF-3640 Wireless Color...
How to clean ink absorber for canon mp237
First of all open the ink cartridge of your printer.
When the ink cartridge would move all the way over, then disconnect the power cord of your printer.
Now pull the frame of rubber from the printer and remove ink pads.
To clean ink pads you may place them in a bowl having warm water and start rubbing and squeezing them to clean it from ink.
After removal of ink, keep the pads separate for dry.
When the pads get dry completely, place them back in rubber frame.
Reinstall the rubber frame in your printer.
For deep guide and support refer to-
Canon Pixma Mp237 Manual
Oct 07, 2013 | Canon PIXMA MP230 Multifunction color...
LSU error SAMSUNG SCX 4725FN
Laser Scanner Unit or LSU is what writes to the surface of the drum. The glass above the cartridge in the machine may be dirty. The mirror motor in the LSU could be bad or needs to be cleaned to spin better. The Laser diode may be faulty.
This is not a user-serviceable issue. You will need to contact Samsung for a service. You can do it online via Samsung website or contact the vendor to see who will they appoint to service the printer to, especially if it is still under warranty.
Jan 27, 2011 | Samsung SCX-4725 Laser Printer
Printer won't recognize cartridge
I had the same problem. I'm not sure but I think I replaced the cartridges when the printer was on because I turned the printer off and removed one of the cartridges. When I turned the printer back on it recognized that cartridge but not the others. I turned the printer off again, rmoved all cartiridges and put them back in when the printer was still off. When I turned the printer on again I had no problems. So...try turning off the printer, rmove all cartridges, then put them back in and restart printer. Hope this works for you .
Nov 28, 2007 | Epson Stylus 2200 InkJet Photo Printer
HP OfficeJet 7310 All-In-One InkJet Printer Logo
750 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
