Question about Turbo Air 49 cu. ft. / 1388 liter Commercial Freezer MSF-49NM
Msf-49nm evaportor pan and drain iced up
Hello - Upper evaporator housing and drain are frozen solid (since new) with, I presume, dripping during defrost, which drips onto frozen goods and into incandescent light housing, breaking the bulb. Is there a drain heater or pan heater reset? Is this a common thing? I know refrigeration basics, but am looking for wisdom before dropping the evaportor housing for an icy looksie.
Turbo Air, Maximum MSF-49NM
Thanks - Ed
  • Turbo Air Master
  • 1,230 Answers
I deal with MasterBilt which is a private lable made by TurboAir.
I have several units but only one does this icing up thing. Look for a bad seal on the door gasket. These really ice up if that does not seal almost perfectly. Look for premature termination of the defrost cycle. Check that the heater is pulling amps. The wiring diagram at "turboairinc.com" is very poor but it shows 2 heaters for the refrigerator. They list a diagram for the freezer but it's not there. I know for sure that there is a heater for the evap but don't know about the drain. I've seen some have it and some don't. there tech support line has much to be desired but it's worth a shot. Also, the bottom hinge on the door fails fairly regularly. This allows the door to drop just enought to disengage the switch at the top of the door and stop the evap fan from running, thus causing a freeze up.
Good Luck . You got your hands full with this one.
Posted on Mar 07, 2009
Msf-49nm freezer will not go below 34 degrees farenhight
Change the temp control,check to see if it is iced up on the evaporator
Sep 15, 2010 | Turbo Air 49 cu. ft. / 1388 liter...
Water leaks onto floor once a week or so from under freezer
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Nov 21, 2009 | Frigidaire 12 cu. ft. / 340 liter Upright...
I have 16.7 upright Frigidaire Ultrafreeze freezer, Model AFFU1766DW3 & SERIAL #WB51720061, manufactured 04/05 that I purchased new 11/05. Water was on the floor next the the freezer but the light on...
Oct 24, 2009 | Frigidaire Freezer 16.7 Upright Freezer,...
Electrolux premier eco freezer leaking. Water appearing on the floor. Ice building up inside the freezer.
Oct 11, 2009 | Freezers
Ge feezer model fuf14dtarwh upright. i am getting water on the bottom of the freezer which is frozen. what is causing the problem? of course the warranty is over by 9 months and the ge people won't help.
Sep 23, 2009 | GE 13.7 cu. ft. / 388 liter Upright...
Turbo Air 49 cu. ft. / 1388 liter Commercial Freezer MSF-49NM Logo
200 people viewed this question
Top Turbo Air Freezers Experts
Dennis Boxerman
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you a Turbo Air Freezer Expert? Answer questions, earn points and help others
