Question about Gateway nVidia RIVA TNT2 M64, (32 MB) Graphic Card
Four vertical lines form on screen. Unable to view full screen.
My EV 700 gateway monitor does a self test which says that monitor is working properly. check monitor power cord.
When i substitute cords I have the same problem.
  • 72 Answers
Hey there, It sounds like you're Graphics card is shot. If your system is under warranty please contact manufacture for repairs, if not you can purchase a new graphics card at most stores that carry electronics and also online. good luck and feel free to contact me if you need any help.
Posted on Jan 22, 2009
My crt acer ac512 monitar only centre line view,c"not full view why?
there are several reasons why picture of crt monitors did not display good picture. if your monitor had horizontal line at the center of the screen?...the faulty is in the vertical deflection, check the vertical oscillator also the fusible resistors & capacitors around that section. if there had vertical line at the center of the screen?..check the horizontal deflection, horizontal output transistor also check the YOKE.
Jul 31, 2014 | Acer Computers & Internet
Can I increase the screen resolution on my EV700B monitor higher than 800x600? How?
Open Control Panel - Display - Settings tab - Screen Resolution move the slider to the right to increase the screen resolution.
If you cannot increase the screen resolution, it means the correct video driver was not installed generic VGA driver was installed.
In this case install the video driver for your graphics card and change the screen resolution.
Apr 14, 2011 | Gateway EV 700 17" CRT Monitor
Bad colors on an exteral screen ev700
this problem generally occurs with old monitorsyour picture tube has probably been damaged.
Feb 09, 2010 | Gateway EV 700 17" CRT Monitor
My EV 500 monitor shows only 1/3 of the screen. A
update the latest driver to your graphics card with the latest it will remove bugs and, or give the proper data to make it function the way you want
Nov 19, 2009 | Gateway Computers & Internet
My EV 700 screen picture is condenced has one bright clear line in middle screen and two more lines faded,space in between lines
Sounds like a CRT problem but to be sure, hook up another monitor to the computer and if you get the same exact lines then you know its a problem with the video card, if the lines go away then you know its a problem with the monitor.
Jun 09, 2009 | Gateway EV 700 17" CRT Monitor
On turn on of the EV 700 Monitor only a horizontal line is seen across the screen. Seems as if the vertical scan or oscillator has stopped working ??
check the pins on the connector cable. make sure that not one of them is bent. If it is, it could cause the problem as on of the signals is not there. You can get some needle nose pliers (thin ones) and carefully bend (form) the pin back straight. Once straight, carefully insert the connector back in. Then, pull it out to make sure it did go in and not get bent again.
If the cable is good on both ends, (you can ohm them out with an ohm meter), make sure all is ok on the computer end. (drivers, video card, software). If it is, then pitch it and get an LCD. You don't know what you are missing. Better yet, don't break a sweat. Go and buy an in expensive LCD screen. you'll be glad you did. Besides, the EV700 is now old, full of dust, lint, cooties, etc.
May 08, 2009 | Gateway EV 700 17" CRT Monitor
Ev 700
you must attatch agp(accelareted graphics port) card in pci slot it is specially for 3d games and excellent video output fast motion responce but if you want to see normal ordinary display then no need of agp card
Oct 27, 2008 | Gateway EV 700 17" CRT Monitor
EV 700
my gateway monitor makes a sqreeching noises when you turn it on. after that it starts making that noise like it does when its fixing to come on then it starts smelling like its burning then we turn it off. please help
Oct 18, 2006 | Gateway EV 700 17" CRT Monitor
Wavy Vertical Line
you have AC ripple getting into your horizontal output. you have a power supply problem in the monitor. take it to get it fixed.
Jun 26, 2006 | Gateway EV 700 17" CRT Monitor
Gateway nVidia RIVA TNT2 M64, (32 MB) Graphic Card Logo
118 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
