Question about Tascam 2488 Portastudio Multitrack Recorder System
Rename a song file after copying
The manual states that you should rename a file after a copy is made to avoid duplicate names. I have searched everywhere ... and can not find any documentation on HOW to RENAME a file. Please help!
  • musicman19 Dec 16, 2008
    Thank you so much for the solution. The key was "not" to load the song. When I tried to rename the song after being loaded, it would fail.
    Novelist:
  • 189 Answers
I'm a little unclear about what you are trying to do. I'll assume that you have copied a song from one partition to another and now wish to change the song name so as to avoid confusion. To do so you need to call up the 'menu' (press menu button) and under 'song' go to 'load'. There you'll see a list of song names (including the song you have currently loaded and are working on). Just navigate to the song name and press the 'title' button (shift - menu) which will allow you to edit the song name. You don't have to reload the song for the title change to keep and you'll see the new title reflected in the LCD window after you press 'home' to return to the normal view.
Regards,
bd.
Posted on Dec 15, 2008
In my samsung s5200 mobile i have stored abt 50 songs and 20 wall papers into my 2GB memory card from my computer,but i am not able to view all the files from my mobile,and it shows an error message as...
First remove these file off your cell phone's 2Gb memory card then -
You need to rename the files on your computer that have long file names to something much less than 25 characters in length and then copy them to your cell phone's memory card.
Mar 17, 2011 | Cell Phones
Tip
Get crash ID's
To get your crash ID's go to about:crashes in your firefox location bar. Copy and paste ID into post, when support is needed.
If you are unable to do this...
In Linux:
  1. Open up home folder
  2. Click "View"
  3. Click "Show Hidden Files"
  4. Find the folder ".mozilla"
  5. Open the folder up
  6. Look for "Firefox" folder
  7. Open "Firefox" folder
  8. Open Crash Reports folder
  9. Right click on file
  10. Click "Rename"
  11. Copy entire name.
  12. Paste into post.
In Windows Vista
  1. Click "Start" (Windows Orb)
  2. In search box, enter %APPDATA%\Mozilla\Firefox\Crash Reports\
  3. Press enter
  4. Right click on file
  5. Click "Rename'
  6. Copy entire file name
  7. Enter in post
In Windows XP/2000
  1. Click "Start"
  2. Click "Run"
  3. Enter %APPDATA%\Mozilla\Firefox\Crash Reports in "Run" window
  4. Press enter
  5. Right click on file
  6. Click "Rename'
  7. Copy entire file name
  8. Enter in post
on Jun 20, 2009 | Mozilla Firefox
I am connected to internet but get error 651
I am assuming you have purchased a new pc with Windows7 and have a DSL internet connection. If so the following tutorial should prove useful. This is a common problem and known bug within the Windows7 framework that they are working to correct. Keep in mind that this fix is only applicable for the Windows7 operating system.
"The RAS PPPoE driver file "raspppoe.sys" found under c:windowssystem32drivers folder seems to be the root cause of the problem. Fortunately, we can work around the problem simply by renaming the original raspppoe.sys file to something like "raspppoe_orig.sys" copying a working file from a Windows Vista system. If you do not have access to a Windows Vista system click here to download raspppoe.sys file (unzip)."
http://www.windowsreference.com/windows-7/error-651-with-pppoe-connections-in-windows-7/
Once downloaded and unzipped you may rename the old rasppoe file as mentioned above by right clicking the icon and choosing 'rename'. Then copy the new rasppoe file you downloaded into the applicable folder. You will find this file in the following directory C:\WINDOWS\system32\drivers. Bear in mind, when searching for the file inside the drivers folder, the .sys file extension may or may not be included in the actual name. If the original file is named 'rasppoe' without the .sys file extension in the name, leave this file extension off when renaming and copying as well.
Dec 10, 2010 | E-Machines eMachines Desktop PC
Mtp function problem
Samsung MTP function Problem Solution It really worked for me.
1.)first copy umdf.exe from "wmp11-windowsxp-x86-enu.exe" to your Desktop, two methods:
a)unpack wmp11-windowsxp-x86-enu.exe(ex:with TotalCommander->Alt+F9) and copy umdf.exe to your Desktop
b)run the wmp11-windowsxp-x86-enu.exe(if you run it will extract the %TEMP% folder)
Click Start -> Run -> %temp% [ENTER]
Press F3 and search for "umdf.exe"
Copy this file to your Desktop
Cancel the WMP11 Setup
2.)Rename the folowing files, just copy&paste into your Command Prompt:
rename C:\WINDOWS\system32\drivers\wudfrd.sys test_wudfrd.sys
rename C:\WINDOWS\system32\drivers\wudfpf.sys test_wudfpf.sys
rename C:\WINDOWS\system32\wudfhost.exe test_wudfhost.exe
rename C:\WINDOWS\system32\wudfsvc.dll test_wudfsvc.dll
rename C:\WINDOWS\system32\wudfx.dll test_wudfx.dll
rename C:\WINDOWS\system32\wudfplatform.dll test_wudfplatform.dll
rename C:\WINDOWS\system32\wudfcoinstaller.dll test_wudfcoinstaller.dll [ENTER]
3.) Now run the umdf.exe and re-install it. After it's finished connect your phone and your MTP problem is solved.
Oct 24, 2010 | Cell Phones
Samsung YP-K5 MP3 rename tracks
Find the track on your computer hard disk.
Right click on the track, click on properties.
At the top you will see the name of the track, copy it. ( outline in blue and hold down control button and press C button to copy )
Click on Summary tab.
Go down to Title, click to the right of title and a box will open. ( place the cursor over the box and hold down Control button then press V button to paste into the box )
Thats what I do...
Aug 21, 2009 | Samsung YP-K5 MP3 Player
Kodak c913, error When using easy share software,
You need to rebuild the picture catalog. Pls. follow the steps below to perform the task:
  1. Right-click the Kodak EasyShare software icon on your desktop, then select Properties.
  2. Select the Compatibility tab.
  3. Clear the check box for "Run this program in compatibility mode for" then clear all the check boxes under Display Settings.
  4. Click OK.
  5. Right-click the Kodak icon in the system tray, then select Shut Down Kodak EasyShare software.
  6. Go to C:\Program Files\Kodak\Kodak EasyShare software\bin.
  7. Right-click the Catalog folder, then select Rename.
  8. Change the folder name to OldCatalog1, then close the window.
    Note: If you cannot rename the folder, go to Part B.
  9. Select Start > Run.
  10. Type %temp% in the Run dialog box, then click OK.
  11. Open the _Retain folder (if there is one).
  12. Double-click the bin folder.
  13. Right-click the Catalog folder, then select Rename.
  14. Change the folder name to OldCatalog2, then close the window.
  15. Delete the backup catalog files ESBK.mb and ESBK.mbb:
    a. Select Start > Search > All files and folders.
    b. Type ESBK in the All or part of the file name box, then click Search.
    c. Delete the two files found (ESBK.mb and ESBK.mbb).
    e. Click Yes to send to the Recycle Bin.
    f. Close the Search Results window.
  16. Delete the EasyShare.mc file.
    b. In the All or part of the file name box, type EasyShare.m
    c. Delete any .mc files found.
  17. Restart EASYSHARE Software.
Jul 03, 2009 | Kodak EasyShare C913 Digital Camera
How to delete, copy and rename obtained output file
write a batchfile .bat.
put all commands inside notepad and save as .bat
this will help.
Rate me Rate me
Mar 24, 2009 | Compaq Visual Fortran Professional Edition...
File/Folder Permission Message in Pinnacle Studio 11 Plus
Hello welcome to FIxya!
Here you can check this procedure on how to open your files again.
"1) Check your Recycle Bin
2) Do a Folder/File Search for each of the Grey Folder Project names. This will display all Folders & Files with that Project Name. You are looking for an .stx File. If it's there, right-Click on Project Name / Open Containing Folder & Copy it to your My Projects Folder. Then you should have both the Grey Folder & .stx File for the same Project name, showing in your My Projects Folder.
If the Search doesn't display a .stx File, you can create a new one, by Opening a New empty Project, which will create a My Movie Grey Folder & a My Movie .stx File, Save to your My Projects Folder. Delete the My Movie Grey Folder & Rename the My Movie .stx File to the same name as your original Grey Folder."
So ...after finding my "lost" movie file, with its file name, under Documents\Pinnacle Studio\My Projects i then went through the following procedures using your great advice Colour;
  1. Make a copy of your found "lost" movie grey film icon file by right mouse clicking on your lost file and choosing "copy". Paste the copy into another folder in Documents where you can find it if need be
  2. Then go back to Documents\Pinnacle Studio\My Projects and right mouse click onto your grey film icon. Choose "rename". Then rename your "lost" grey film icon to a new file name but do not put .stc at the end of the file name, if you are operating VISTA and Pinnacle 12. This is important because Pinnacle 12 won't recognise the file later if you have .stc in the file name
  3. Open Pinnacle and go to the File Menu
  4. Click on New Project
  5. Open File Menu again and click on Save File as
  6. Give the file a name such as "Movie 7" and save it
  7. Close out of Pinnacle
  8. Open up Documents\Pinnacle Studio\My Projects and observe that you now have 2 new files there ...a grey film icon file saying Movie 7 AND a coloured Pinnacle icon file saying Movie 7
  9. Delete the grey icon file with the file name Movie 7
  10. Now give your coloured Pinnacle icon file the exact same rename as your precious "lost" renamed grey movie icon file, using the right mouse click on rename proceedure as explained in No.2 above.
  11. Close out of Documents file
  12. Now open up Pinnacle again
  13. Go to Menu and choose Open Project
  14. There you will see the coloured Pinnacle icon file with the new name of your "lost" movie file.
  15. Click onto its coloured Pinnacle icon, and watch your "lost" movie come into view again
Nov 16, 2008 | Pinnacle Studio Plus Version 11
File copy error.
maybe your drive is already full, if your drive is already full try to delete the temp file or delete your unnecessary files, if not try to check the file that you are trying to copy, maybe there some associate file which have a long file name, try to rename it but copy first the original file name to notepad, and after copying rename again your file that you renamed before, if still not tell us what kind of file you want to copy.
Sep 08, 2008 | Computers & Internet
Samsung YPK5
I assume this is in a PC? Simply right click each title whilst in the PC and click on 'Rename' Or click file/save as/and give the file a name This incidently will leave an un-named copy on the computer
Jun 06, 2007 | Samsung YP-K5 MP3 Player
Tascam 2488 Portastudio Multitrack Recorder System Logo
197 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
John
John
Michial Gueffroy
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
