Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Door opener moves foward about 10 inches then returns
Checked sensors they are working properly if I stand in front of sensor door stops and lights blink also increased up and down force the the yellow indicator light blinks 5 times after opener returns
  • 1 more comment
  • mailray Dec 15, 2008
    Fixed it
    the interupter cup assembly was off the motor
    the interupter cup assembly was off of motor's shaft
  • 504 Answers
UNPLUG THE UNIT FOR ABOUT 5 MIN. TO RESET TRY TO OPERATE IF IT STILL MOVES 6-8 INCHES AND FLASHES 5 TIMES THE RPM SENSOR IS YOUR PROBLEM - COULD JUST BE THE CUP HAS MOVED ON THE SHAFT. IF IT IS IN PLACE AND STILL NOT WORKING REPLACE THE PICKUP.
Posted on May 30, 2010
I have two craftsman door openers. They work great with pushbutton on wall, open and close ok. The door opens fine with remotes ( one handheld other homelink in car ) but will not close with remote. It...
If the main light flashes 10 times and the door reverses to the open position it is a door sensor problem. Make sure the lights on the sensors are both on and not flickering. Tweak them if necessary. If you cannot get both lights to come on you have bad sensors or the wiring to them.
Dec 27, 2010 | Sears Craftsman LiftMaster Chamberlain...
My opener is a 1/2 horse lift master professional chain drive . The door will not close unless you hold the closer button in. From the remote it will only move a few inches and then reverse. The door works...
If the main light flashes 10 times when the door reverses it is a door sensor problem. If not, you probably have a bad RPM sensor board which is a small printed circuit board just in front of the motor.
Jun 28, 2010 | Sears Craftsman LiftMaster Chamberlain...
Have 1/2hp garage door opener that will not open the door. If the remote pad battery is dead will the opener stop working? if I press the remote opener the door move about an inch stops and the light...
Dead batteries will not cause your problem. If it is the main light flashing 10 times when you try to close the door it is a door sensor problem. Make sure the small light on each sensor is lit and not flickering. Tweak them a bit to make sure.
Jun 07, 2010 | Sears Craftsman LiftMaster Chamberlain...
Garagedoor intermittantly will not close. moves one or two inches, stops, then backs up. other times it works fine. when it fails to close, I unhook, manually close the door, rehook by pressing the power...
If the main light is flashing 10 times when the door reverses to the open position it is a door sensor problem. Make sure the small light on each sensor is not flickering ever so slightly. This will cause an intermittent problem like you have. Tweak the sensors just a bit.
If the main light is not flashing 10 times you may just need to increase the 'down force' just a tad. This control is on the rear of the motor unit near where all those white wires go.
Mar 23, 2010 | Sears Craftsman LiftMaster Chamberlain...
When i try to close garage with transmitter or keypad it moves a few inches and stops or goes back up
If the main light flashes 10 times when the door reverses it is a door sensor problem. Make sure the small light on each sensor is lit and not blinking. The sensors must be pointed at one another to work properly. If you cannot get both lights to come on you have a bad sensor.
Oct 08, 2009 | Sears Craftsman LiftMaster Chamberlain...
When we push the button for door to close it moves an inch and the light blinks several times. if we hold the button the door will close all the way. there is nothing blocking the floor sensors and the...
Most likely one of your door sensors has been bumped and is misaligned. Check to see that the small light on each sensor is lit. The only thing that will cause the main light to flash 10 times when the door reverses is the sensors or the wiring to them. They must be pointed at one another for both lights to be on.
Jul 12, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door won't shut, light blinks 10 times.
If the light blinks 10 times it is a sensor problem. Nothing else will cause this. Tweak the sensor a bit and check it out.
Jun 28, 2009 | Sears Craftsman LiftMaster Chamberlain...
Motor moves 5 in" and reverses and light blinks 5 times
In the manual it says if you can hold the wall button down & door closes. You have a short in the wiring to the reciever eye. Try substituting some new bell wire in its place, or test the wires for continuity.
Jan 23, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door won't close.
After replacing the worm gear and main drive gear on my Craftsman 1/2 HP garage door opener I found that my door moved about 4 inches stopped and reversed the same distance. I checked all the settings and everything seems OK. What fixed the problem was I released the two allen set screws on the end of the motor shaft and pulled tha motor shaft toward me. When I replaced the black plastic cap that looks like a pill cap top on the end of the shaft this corrected the depth setting that cap rotated through the RPM sensor. I set the limit settings (up and down) on the side of the opener and reset the force pots marked (KC) to mid range.
the door now works. I hope this helps. I also checked and eliminated the door sensors by putting a box in the beem this inhibited any movemnet at all, so I knew it wasn't the door sensors as there was at least 4 incheds of movement prior to the box and nothing with the box.
Oct 27, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
581 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
