Question about ViewSonic N3251w 32 in. LCD HDTV
Viewsonic n3251w will no longer display Closed Captions
Right after I got it a while back, the unit would not respond to any remote control funtion other than on off and volume. I could not change inputs I could not change screen size none of the buttons on the panel worked either except the same ones that worked on the remote. It got sent to the factory repair center down in Southern Cal and they fixed it. Now out of warranty, it suddenly stopped displaying closed captions. I can select the closed caption funtion from the remote and the menu but it does not show anything. Every other function seems fine. I tried to reset the unit by unplugging for days and also powering off then on with the various panel buttons pressed. No Luck Got any ideas?
You can reset your viewsonic remote control by removing the batteries, and holding the power button down for 10 seconds. Just 10 minutes ago I repaired my remote, which was doing absolutely nothing, not even turning the set off and on, Called Viewsonic, they told me this, and it worked ! Yay !
Posted on Apr 28, 2009
Zenith SL2773W problem
The dark rectangle appears because you have the closed captions on and set to TEXT. Closed captions set to CC1 puts the words on the screen and TEXT puts a black box on the screen. Go into the menu, navigate to the page with closed captions and set your captions to OFF.
Aug 12, 2007 | Zenith C27A24T 27" TV
Need to find the remote control for my ViewSonic N3235W3M HDMI TV
I can't find a Viewsonic N3235W3M. However the N3235W and the N3235W-M use the RC00136P remote. This remote is available from several sites: http://www.electronicadventure.us/Merchant2/merchant.mvc?Screen=PROD&Product_Code=A-00008148&Category_Code=VRC2 and http://www.remotecontrolscenter.com/viewsonic/a-00008148.html . A replacement remote is available from remotes.com here: http://remotes.com/store/viewsonic/n3235w.html .
I hope this helps.
Oct 30, 2011 | ViewSonic N3251w 32 in. LCD HDTV
How to turn closed caption off?
If the cc button on your Sharp remote control isn't turning them off then the captions may be coming from your cable box. The hidden menu to access closed captioning on the cable box is usually found by turning it off and then (yes I did say turn the cable box off) then press the menu button on the front of it immediately after turning it off. Then you navigate down to captions and disable them. When you turn the cable box back on the captions should no longer be there.
Feb 01, 2011 | Sharp LC-26DV24U 26 in. LCD HDTV/DVD Combo
How do I enable closed captioning on my Zenith PIP System 3? Thanks.
Hello
To enable close cationing on your TV follow this:-
[1] Press "Menu" button on the remote control to appear "Setup" menu on the screen.
[2] Use "Up and Down" arrows on the remote contol to select "Captions/Text" on your screen.
[3] Press "Right or Left " arrows to select any one of the following options. Caption-1, Caption-2, Caption-3, Caption-4 Text-1, Text-2, Text-3, Text-4.
[4] Press enter to return TV viewing.
To turn the caption feature to "On" or "Off'
[1] Press menu key on the remote control to display "Setup" menu.
[2] Using "UP/DOWN" buttons to select captions on your screen.
[3] Press "Right or Left" arrow to switch the captions feature 'ON" or "OFF" or "EZ Mute"
[4] Press enter to continue.
Ok.
Oct 22, 2010 | Zenith C27A24T 27" TV
Cannot get closed caption
To view captions or text:
1. Select the desired program. Closed captioned programs are
usually marked in your local TV listing as “CC.”
2. Press CAP/TEXT on the remote repeatedly to select caption or text mode.
3. Press 1/2 on remote to select the caption or text channel.
4. To turn off the closed caption feature, press CAP/TEXT
repeatedly until captions or text no longer display on-screen. I hope this helps. Thanks for using Fixya. Good luck
Nov 04, 2009 | Toshiba 20AF45 20" TV
Remote for N3251W will not work.
Many of the so called universal remotes are not universal at all. Many people ending up having to use one remote for the TV, another for the cable etc.
Recently, remotes have come on the market that truly are universal. Go to any electronics box store with a list of the electronic items in your home that you want to control with one remote and they will be able to assist you. Be sure to have model numbers, brand names, and IF you have them, all of the owner manuals.
These new all inclusive remotes are a little more expensive but they do control all of your electronics.
May 31, 2009 | ViewSonic N3251w 32 in. LCD HDTV
ViewSonic N3251w 32 in. LCD HDTV Logo
544 people viewed this question
Top ViewSonic Televison & Video Experts
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
