Question about GE DCSR483EA Electric Dryer
Stripped start knob
The screw which the Start Knob sits on is stripped, how do I replace it and the knob also. What is the name of this part?
  • Allen Neal
    Allen Neal May 11, 2010
    if you turn the shaft itself will it work ?
  • 95 Answers
That would be the timer assy You may need to replace entire assy and knob you could try a strong 2 part epoxy and allow to dry min 24 hrs at room temp.
Posted on Jan 24, 2009
Remove stuck screw
If the screw head is stripped you will have to replace the knob and screw. Try holding the screw head and turn the handle is its a single knob. Otherwise use a hacksaw or dremel tool and cut about 3/8" away from the door surface, once you cut through you can use a small punch to push the screw through the door then pliers to pull it out. Alternately you could use a dremel tool and carefully grind the head of the screw down until you can brake the head off and pull the handle and screw out through the front.
Jun 19, 2014 | Top Knobs Hardware & Accessories
The thread on the screw has gone
Jun 19, 2014 | Amerock 3 Ring Knobs - BP1586
The center (Function) knob has stripped. Where do I get a replacement?
I would just take the old knob to Home Depot or another hardware store and buy a knob with a set screw.
Mar 20, 2011 | Euro-Pro EuroPro 6Slice Toaster Oven with...
Have stripped out faucet knob...how do i replace it
Take the stripped handle to a local hardware or home improvement store.
They may be able to find an after market knob or knobs that will work as a substitute - they usually use set screws to hold the replacement knobs in place.
Dec 12, 2009 | Price Pfister Home
Wash cycle dial wont turn...will still push in and pull to start
We have a GE WJRR4170 washer, with the same problem. At first I thought I might have to unscrew the entire control panel just to replace the knob. However, replacing the knob turns out to be easy.
Right behind the knob, holding it in place, is a nylon/plastic retainer clip. If you pull out the knob (into the "start" position), you will get easier access to the retainer clip. You can use a flathead screwdriver to push the clip out. The knob then will slide easily off the metal stem. A GE replacement knob costs $9 or $10, depending on the source.
Shame on GE, but the knob is designed terribly. The part of it that engages the dial has eight, flimsy plastic teeth. At any time, four of these are supposed to engage four little slots in the dial. However, the way the knob is designed, there will be a lot of wear and tear on these plastic teeth, so they'll wear out on every single machine.
Good luck to the many people who will have this problem!
Jul 26, 2009 | GE WJSR4160DWW Top Load Washer
Broken knob on GE washer
There are four separate parts that make up the knob dial. You can pull off the knob if you use a screwdriver/pliers to remove the clip holding it on. Check if the mounting areas appear stripped or broken. There should also be a compression ring in the mounting hole on the back of the knob. That's what may be broken or stripped. These are all parts that you can get from a local parts store (check the phone book) and you can do it yourself. Any of those parts should cost less than $10. The bad news is if you stripped the pole coming out of the timer assembly. You would need to replace the entire assembly which costs about $130. If you call a GE repairman, you are looking at $89.95 or more just to have them show up. If it is still under warranty, there is no charge. You can call them to verify this:
1-866-383-3933
May 03, 2009 | GE WWSR3090TWW
Dryer won't start when knob is pulled.
If you push the knob to the left and it makes a good contact and starts the machine, then replace the timer switch. Write down the Name and Model Number of the machine (usually on or below the door)
take it to a local appliance shop and order a new part. When you recieve the new part UNPLUG the machine and remove the three screws from of the top of the electrical compartment and gently pull o the front open, there is only one plug attached to the switch, remove it and dislodge the old switch, then snap the new switch in place and replace the plug, close the compartment and replace the three screws, plug in the dryer, and try it.
Mar 15, 2009 | Maytag Atlantis MDE6400AY Electric Dryer
Purchase part
If the threads are not stripped on the knob or shaft, just screw it on clock-wise.
If the threads are stripped on the shaft, it must be replaced, same with knob.
To replace the shaft (if the knob is off) just pull it down in the film compartment. now there is a spring to hold the shaft up or down if the new shaft has a beveled shoulder just turn the shaft while pushing it back up. If no beveled shoulder is on the shaft then with a long needle or pin hold the spring back while pushing the shaft back up. Don't bend the spring. just move it out of the way.
Aug 18, 2008 | Pentax K1000 35mm SLR Camera
GE top load Super Capacity 16 cycle washer (one year old)
We have a GE WJRR4170 washer, with the same problem. At first I thought I might have to unscrew the entire control panel just to replace the knob. However, replacing it turns out to be easy.
Right behind the knob, holding it in place, is a nylon/plastic retainer clip. If you pull out the knob (into the "start" position), you can use a flathead screwdriver to push the clip out. The knob then will slide easily off the metal stem. A GE replacement knob costs $9 or $10, depending on the source.
Dec 18, 2007 | GE WBSR3140DW Top Load Washer
GE DCSR483EA Electric Dryer Logo
137 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
