Question about Dell Latitude D630 Notebook
Dell Latitude ATG630 Notebook screen light not working
I have a problem with my Dell Latitude ATG630 Notebook, the computer switches on but the screen is very dark and you can just make out the picture, I presume its something to do with the back light, but any help on getting a fix would be great.
Many Thanks Steve
    Scholar:
  • 149 Answers
If you can see anything even faintly most likely its the backlight....unfortunately it requires you taking off the plastic (bezel) round the screen (approx 4 screws)...then unscrewing the screen from the hinge mountings (approx another 4 screws) then unplugging the video ribbon cable...now you'll have enough room to get at the backlight (like a small flourescent bulb)...backlights themselves aren't that expensive but it is a competant persons job since it is possible to damage the screen by overtightening the screws...if you feel comfortable with doing it yourself you'll need a maintenance manual...if you know your screen size you can order the backlight from the manufacturer or off ebay...if the machine is still under warranty take it straight back to where you bought it and have them fix it
Posted on Dec 11, 2008
Replaced dell latitude d610 screen and now it lights but no picture
Did you remember to plug the video cable back into the motherboard? [round cable with plug on end]
Jul 03, 2012 | Dell Latitude D610 Laptop Computer -...
D600 Dell Latitude is not working properly.
hi,
see !
you only write : D600 Dell Latitude is not
Problem with the Dell Latitude - E5400 Laptop Computer PC Notebook
then you write :
now, how can i guess what is your problem ?
pls explain your notebook problem/problems.
gorbesia
Aug 02, 2011 | Dell Latitude E5400 Laptop
The backlight won't turn on but occasionally will flicker.
Suggest you replace the Inverter. A Backlight goes out all at once.
90% of the time the Inverter is the hardware part at fault.
[ An LCD screen cannot produce enough light by itself.
A Backlight is used to supply the needed extra lighting.
A Backlight is a CCFL.
Cold Cathode Fluorescent Lamp.
Similar to Fluorescent lighting used in homes, and businesses, but on a much smaller scale
An Inverter is used to required power for the LCD screen, and the Backlight.
Boosts power up for the LCD screen, brings it down for the Backlight.
Dell Support > Latitude D600 Notebook PC > Service Manual
http://support.dell.com/support/edocs/systems/latd600/en/sm/index.htm
Replacing an Inverter is a simple job. Replacing a Backlight is not.
The Backlight is located within the LCD screen assembly.
The metal frame of the LCD screen assembly is removed along the edge where the Backlight is located, to access replacing the Backlight.
In the above list for Service Manual, click on > Display Assembly and Display Latch.
This information shows you where the Inverter is located on a Dell Latitude D620 Notebook PC.
The Latitude D620 is part of the Latitude D600 series of Notebook PC's.
http://www.insidemylaptop.com/remove-replace-lcd-screen-dell-latitude-d620-laptop/
Just one place from a quick search, that sells Inverters for a Latitude D600 series Notebook PC,
http://www.parts-people.com/index.php?action=item&id=2895
MATCH the part number listed that they have, to the part number on your Inverter.
You have to have THE correct Inverter.
Regards,
joecoolvette
Nov 05, 2010 | Dell Latitude D600 Notebook
Display works but there is no light.when i turn on the notebook light turns on few seconds and then turn off.dell latitude 110 l.
connect an external laptop screen to inverter leaving the display nap on the laptops original screen.if the external screen lights up and off then replace the inverter.if not then the bulb in the dell laptop screen needs to be replaced.contact me for more info tel.75376764
Jun 22, 2010 | Dell Latitude 110L Notebook
My Dell Latitude D620 Screen is Black and the keyboard dosent work when I turn on the computer. The only LED light that shows is the power light, the wifi or the little cylinder light dosent work. I can...
remove all attached devices like printers or flash drives. remove battery and power on using ac adapter only. if it still wont work, try another good ac adapter. make sure ac adapter light is on. if it still shows the power light on and nothing else, replace motherboard.
May 15, 2010 | Dell Latitude D620 Notebook
Dell latitude 100l power light and battery light blinking on/off
I found out that the power adapter was the culprit here, planning to purchase one, it seemed it could not deliver enough juice to power up the laptop, i borrowed a charged battery from a inspiron , and voila it booted...oh well....
Apr 14, 2009 | Dell Latitude 100L Notebook
Dell latitude d600-vga
The flickering may not be caused by a corrupt driver, it could be the impending failure of the fluorescent back light of the display or its high voltage supply.
Trying driver replacement though is the first thing to try.
If the original driver is corrupt, you can try the following;
- Right-click on My Computer
- Left-click on Properties
- Click on Hardware tab
- Click on Device Manager
- Locate and open Display Adaptors
- Locate the video listing for your
- Highlight and delete this
- Reboot the computer
If Windows does what it should (no guarantee on this!), it will 'find' a 'new device' and install the driver for it.
Aug 23, 2008 | Dell Latitude D600 Notebook
Display not working properly
You should be able to plug in an external (Desktop type) monitor . Look for a connector on the side or back of the laptop. If the external monitor works, you have pretty much diagnosed that you have a LCD problem.
Ron-
Mar 07, 2008 | Dell Latitude D600 Notebook
Backlight of LCD turns off
For latitude systems they have this ambient light sensor. it basically adjusts the brightness of the screen depening on room lighting. try to go to bios by hitting F2 on the dell logo. go to video and try to look for ambient light sensor. however, im not sure if your computer has that feature I have a second option for you though. based on the troubleshooting you've done, it seems that the video back lighting is affected by movement. it would be a good try to reseat the LCD cable. you can use this link to guide you in fixing the computer : http://support.dell.com/support/edocs/systems/latd505/sm/keyboard.htm
all you need to do is to take out the keyboard with 2 screw holding it in place. the LCD cable should then be accessible. it a thick cable that coming out of the Left hinge.
Hope this helps.
thanks.
Dec 24, 2007 | Dell Latitude D505 Notebook
Dell Latitude D630 Notebook Logo
127 people viewed this question
Alun Cox
