Question about Craftsman Air Tools & Compressors
Craftsman 25 gallon compressor wont cut off
I got a 25 gallon compressor (oil less unit) it runs fine builds up pressure but it will keep building up pressure in the auto mode and will not cut off unless I turn it off or the relief valve blows the excess pressure. Need help whats needed to fix problem
  • dwashington7 Dec 16, 2008
    ok pressure switch was toast now i got a new pressure switch from grainger just like one on compressor. now wiring on the (sears) pressure switch has line positive and negative terminals and also a motor positive and negative terminals, there is also a ground. the new switch is labled different there are T1 & T2 terminals and then there are L1 and L2 terminals does anyone have any idea how this is wired? do i connect line pos & neg to L1 & L2 and motor pos & neg to T1 & T2 or what?
  • Craftsman Master
  • 1,388 Answers
The pressure switch has snap action contacts that are opened by a diaphragm pushing against a spring mechanism. Unplug the compressor and remove the cover to the switch and look for the contacts. Make sure that they are not welded together from use. Move the on/off lever to see if they open and close. You may have welded contacts or broken mechanism within switch. A factory replacement is expensive, however if you are a tinker-er you can use a lower price generic pressure switch available on ebay. Switches are sold by pressure range, you need a 120#. Fittings may need tweaking. Enjoy
Posted on Dec 12, 2008
Craftsman air compressor model 191.135131 wont build pressure
I can not find a Craftsman compressor with that model number anywhere so here are a couple things to look into. If the compressor fills to 70psi and keeps on running check the valve plate and piston/cylinder assemblies. Check that the valve reeds on the valve plate are not bent, broken or warped from heat. Then check that the wiper (oil less) or pistion rings (oil splash) are not damaged and that the cylinder wall is not scarred up. Any of these will let the compressor fill up to the point where the air pressure leaks past the valves or piston and won't fill any further. If the compressor fills to 70psi then shuts off the problem is in the pressure switch. Some have an adjustment screw or bolt to control when it turns on and shuts off. If you had a drop from 100 to 70 the springs may be weak or broke and you'll have to replace the switch.
May 22, 2012 | Craftsman Air Tools & Compressors
I have a Craftsman 3.5 hp, 25 gallon compressor. The compressor runs fine, but will not build pressure. Tank has pressure from the last cycle so I know it is not leaking. The compressor runs but no...
Hi Jim,
Disconnect your main air supply from the comp head to the receiver/tank and see if their is a reasonable air supply to atmosphere.
If not check that air is being taken in by the head intake filter
Aug 05, 2011 | Craftsman Air Tools & Compressors
Air pressure does not go over 25 psi I have taken the whole unit apart and check, relief valve,regulator,check valve. Pressure switch, Piston & Gasket. everything seem good I have taken the pressure...
Does it shut off at 25 psi or just keep running and never build more pressure than that? Also, did this come on gradually or suddenly? Also, was it being used regularly when it happened or had it been sitting for a while?
Mar 07, 2010 | Craftsman 1 Hp, 4 Gal. Air Compressor
I have a craftsman 30 gallon air compressor which loses air quickly no matter what tool i hook up to it. it just cant keep up with any tool and wondering if antone knew what could be wrong...
The first question is: does it build up pressure in a normal rate of speed? If not....or if it can't keep up with the demand you're putting on may be the piston ring. I owned an oil-less version Campbell Hausfeld compressor that wouldn't get up to operating pressure....turned out to be a torn plastic piston ring. hope this helps.
Dec 13, 2009 | Craftsman Air Tools & Compressors
Craftsman 1 gallon direct drive oil filled wont build air pressure
It sounds like you may have a broken reed on the diaphragm plate. This is located at the block. Remove the cover, and look for a cast metal assembly with fins. It will be attached to the side.
Apr 18, 2009 | Air Tools & Compressors
Craftsman air compressor, oil build up in the air line
worn compressor rings, not a real issue, I assume it is more of a build up over time, say a gram of oil is blown into the lines every year, well one gram would not be noticed nor two but since it soes not evaporate it builds up to the point that you can see it, some oil is blown by brand new compressors and over time gets to be more and more, but as long as you are still getting full pressure you do not have to service the compressor, but since this is being used on water pipes I would install a trap inline to catch the oil
Oct 13, 2008 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Air Tools & Compressors Logo
486 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
