Question about Maytag Neptune MAH5500B Front Load Washer
Getting nf code on final spin cycle
My neptune front loader gives me a nf code on its display during the final spin cycle and it shuts off
  • iamgambit Dec 13, 2008
    I have the same problem.  It just started within the last couple of days.  Have had the washer for about 3 years and never had this problem before.
The "nf" code is a "no-fill" fault. This indicates that your washing is not getting water supplied to it, or the pressure isn't substantial enough to complete a fill. You need to, first, make sure the water supply is turned on. Second, if the water IS turned on, and you're still not getting anything to your washer, you may have a fill valve problem. The fill valve is what both your hoses connect to on the back of the machine. It can become clogged with sediment over time (especially, if you have hard water or well water). Turn the water supply off and remove both hoses from the back of the washer. Check both these hose connections for clogs in the filter screens. If they are clear, then more than likely the fill valve has gone bad. I hope this helps you.
Posted on Dec 13, 2008
Neptune washer mah55lbww - during final spin cycle we have noticed thet it is getting louder as if a bearing otherwise normal operation
well the final spin does go faster than the other cycles pending on the age you may want to tilt it over check under it to see if you see any grease on the floor if so your transmission could be getting ready to go out. and make sure your not over loading the washer
Mar 06, 2011 | Maytag Neptune MAH5500B Front Load Washer
It stops about 13 minutes from the end of the cycle, right before it spins. It displays NF.
""It stops about 13 minutes from the end of the cycle, right before it spins. ""
NF is no fill for the FAV6800A and FAV9800A are you still having the issue.
To me it sounds like you have two issues
""It stops about 13 minutes from the end of the cycle, right before it spins. "" with no additional info this could be a issue with the Clutch Pulley. Did you take any error codes like DC or UC?
Are you going to DIY the fix or call in a repair service?
Jan 26, 2011 | Maytag Neptune FAV6800AW Top Load Washer
I am getting an error NF during the washer cycle run. The cycle will not complete and has to be restarted. What does this error message mean?
Hello
NF error in your Maytag is displayed due to no fill condition, when the washer tries to fill but is unable to nf is displayed. Please check the water inlet valve for any clogs and obstructions, you can also clean the inlet to solve the issue. Please get back to me if you have any other questions.
Kevin
Nov 07, 2010 | Maytag Neptune MAH5500B Front Load Washer
My Maytag Neptune will not go into the spin cycle, instead the letters "nf " come on the display. What can I do to prevent this and to have the cycle completed?
Bonnie,
NF = No Fill the control board receives signaling for the washer during the water fill cycle. With most cycles the depth of water is around 3.5 inches in the wash basket. I know a Bulky Wash cycle selection will fill the wash tub to a high fill which is about 7.5 inches of water in the wash basket.
Is the washer filling the machine with any water? Do you hear water entering the machine? If you are doing a cold water fill and there is no or very little water in the wash basket with the NF error code. Try a Warm or Hot fill and see if the machine will fill and start the wash cycle.
Assuming you are doing cold water wash loads. You could have a water line block at the inlet screen or a failed cold water inlet valve which will not open. Try the above and let me know the results..........Rich
Sep 13, 2010 | Maytag Neptune FAV6800AW Top Load Washer
My washer stops during the wash cycle and nf appears on the display screen
NF code is Washer does not turn on water valves to fill washer with water. You may need to replace your water valves, but I would first try removing your hot and cold water hoses to see if the screen on your valves is clogged. If they are corroded beyond repair, just pick up another set at the hardware store. Either that or you will need to do the valve replacement.
Mar 24, 2010 | Maytag Neptune MAH5500B Front Load Washer
Front lader washer maytag neptune
check the drain pump for a foreign object that maybe stopping the impellar wheel from turning.to remove the water use a shop vac attached to the drain hose to get all the water out
Sep 16, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Maytag neptune TL
The machine needs to cut you a break;
“”i have a maytag neptune TL and there are several things wrong with it...1. I can't wash small loads it will stop at the spin cycle and flash dc””
This issue is a clutch issue see this post to DIY the repair.
“”it will wash fine on regular loads until it comes to spin cycle again and it will stop and flash nf””
This one is a little confusing the “nf” error is a No water fill error code. Check these two post for support regarding water inlet restriction or valve not opening properly.
nf post nf post 2
“”my fabric softener dispenser will not let the softener out neither will the bleach dispenser””
See this fabric softer post for support. The fabric softener dispenser may be clogged or the water dispenser valves feeding both dispensers may not be operating properly. The Service Manual on page 16 “Board Output Test” will give you support to turn on the Fabric Softener Valve and Bleach valve. See if you hear the valves operate in Service Mode”
My method may seem a little confusion for viewing water flow to the dispensers. This issue could be associated to the nf error you are receiving, restricted water flow (inlet screen clog) or cold water valve not working properly.
Post back for any questions or possible support I can offer. I’m an owner like you not a repair person but I’m very comfortable working on this machine. Rich
Jun 17, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Water leaks from the bottem of Maytag Neptune front loader
Your sewer drain may be backing up.
Check the drain during a final spin.
Feb 26, 2009 | Maytag MAH8700AWM Neptune Front Load...
Frigidaire front loader wont final spin timer stops at 7 min.
its_me_ac You probably have a faulty timer switch.
You can buy parts at this site , v
Please give me a good rating
Dec 05, 2008 | Frigidaire ATF6000ES Front Load Washer
Very loud final spin cycle with burning rubber smell
Hi Mcbride2
It could be one of 2 things. 1 the belt. or 2 the main seal and bearing. i recomnd to get a tech just to make suer.
brent
Sep 06, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
490 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
