Question about JBL CREATUREIIWHITE Computer Speakers
Capacitance touch problem on JBL Creature II White
It seems that my capacitance touch volume control just stopped working and I can only control the sound now from the PC. Any suggestions?
Thanks to cagamba for his discovery. I thought for a while I had bought a lemon. Touch the audio plug outlet at the back of the computer with one hand and touch the volume control with the other hand. It really works.
Posted on Feb 11, 2010
  • Groove1950 Sep 09, 2010
    amazing -- just unplugged my mains to the laptop and then got the most beautiful sound and then rehooked by mains.
Hello from Brazil. The solution I found for this problem is not permanent, but will make it work. I figured it has to have a proper ground on you in order to work, so I went about the system looking for a ground I could touch with the other hand. The only one I found easily, although it doesn't have an easy reach, was the audio plug outer contact. Touch it with one hand, with the other touch the control. It will work, but I too wanted a less troublesome, permanent solution. Cheers
Posted on Jun 27, 2007
  • xangoir Oct 26, 2010
    I am very happy to have found this thread. I was about to pitch my speakers into the recycling until I read this. For my setup I have a very exotic arrangement, which explains why I was not grounded. I was able to get the speakers to work again after touching my left hand into the video port of the television while using my right hand to adjust the volume control. Needless to say this is a MAJOR design flaw in the speakers. I wouldn't recommend them to anyone or buy any products from JBL again. I spent a long time troubleshooting this. I am pretty *shocked* (no just kidding) that this solution actually works! plesantly surprised
That does seem to be the case. I had the same problem with the JBL creature speakers on my laptop. When the Laptop was on my laptop it grounded or if on a work surface I have to touch another part of the laptop whilst using the touch control on the speakers. It works fine when the laptop is not plugged in to the mains.
There must be a solution to this problem, but thanks to cagamba who is the only one pointing out the real issue to a problem found by many
Posted on Sep 09, 2009
SOURCE:
One of the jbl creature speakers doesn't work
I had the same problem one time and it was a loose connection in the speaker. I will work on any computer but I stay away from anything else. :-) A buddy opened her up and fixed her for me. If it is new, think about taking it back to the store. Thank goodness the prices have come down so much that I am considering getting Bose instead and blasting myself onto the wall behind me. :-)
May 23, 2012 | JBL CREATURE II Computer Speakers
Creature III brand new faint sound!
Check out here:http://www.fixya.com/support/t3604714-jbl_creature_speakers
Jan 10, 2010 | JBL CREATURE II Computer Speakers
Low volume on creature speakers
Your speaker volume must have reset. You have to touch the dots on the right speaker to turn up the volume to desired volume. I just remembered that on my system. Hope this helps.
Jun 14, 2009 | JBL CREATURE II Computer Speakers
JBL Creature Speakers have very low volume
I had the same problem. Then I read about the volume controls on the right speaker. They are silver buttons for me on the front bottom left and right of the speaker. Now they play really loud!
May 30, 2009 | JBL CREATURE II Computer Speakers
use another device like your i pod to make your jbl sounds louder and then plugged it to your pc without turning it off. after plugging try to test it if works.
Apr 02, 2009 | JBL CREATURE II Computer Speakers
Jbl wiring diagram
OK
See you CPU's backside  you will find  two different speaker input saket (in green ,yellow or pink) fix your speaker pins in their colors   and the speaker will work
Dec 17, 2007 | JBL CREATURE II Computer Speakers
Volume control buttons on Creature II speakers
this problem is bcoz of the buttons only it require servicing see if you can show to service pesonnel he will help you out.
Sep 07, 2007 | JBL CREATURE II Computer Speakers
JBL CREATUREIIWHITE Computer Speakers Logo
1,519 people viewed this question
Top JBL Audio Players & Recorders Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
