Question about Coffee Makers & Espresso Machines
Astoria Argenta AEP/JUN Semi Automatic Espresso Coffee Machine
I need a copy of the owners manual and the cleanning and maiance of this unit. The church I attend has one of these and I want to clean/ care for it. Can anyone help me out Please!
  • 24 Answers
You can email me and I will send you a copy of their manual.
Posted on Dec 17, 2008
  • Matt Oct 11, 2010
    hi, could you send a copy of the manual as well please, i have also been looking for one for a while now.
    regards
    matt
  • sdnyslng Dec 23, 2010
    please email me a copy of the manual.
    thank you very much in advance.
    sdnyslng@gmail.com
Water pressure is too low. How to adjust?
If water/pump pressure is below 9 bar, then you will have to adjust the pump. Remove the right side panel, pump is usually located there, find the big brass head with 2 water lines coming to it, on the side of it is an adjustment nut and or screw depending on pump model. Adjust tighter gives more pressure.
Apr 03, 2011 | Astoria Argenta AEP/JUN Coffee Maker,...
Astoria sae 2n machine tank is full but not heating, any ideas
Check to see if your machine has a reset thermostat on the left side of the boiler, on new models it is located on the top, second some machines have a 2 position switch make sure it is on 2.
Aug 20, 2010 | Astoria Argenta AEP-2 Coffee Maker,...
I have a Astoria espresso machine Model AEP12N we have 208 Volts
The machine will use 200 -240 volts, if your voltage is lower than 200 then you will need a booster.
Jul 14, 2010 | Astoria Argenta AEP-2 Coffee Maker,...
Need manual/schematics for espresso machine.
Your coffee supplier will be able to provide you with one.
www.kaldi.com
May 28, 2009 | Astoria Argenta SAE/JUN Espresso Machine
Just set up a recently purchased used Astoria argenta single and can't get a thick Espresso
Try adjusting the grind on the grinder to a finer setting, and make sure that the machine ins producing about 9 bars of pressure on the water pump(check bottom gauge on manometer).
Feb 19, 2009 | Astoria Argenta AEP-2 Coffee Maker,...
I need a new pressure guage for an Astoria A2 - coffee machine
here is the site where you can get your presure gauge and other parts for your machine.http://www.espressoparts.com/results.cgis?catalog=&select=NAME&keywords=astoria+pressure+gauge&image.x=15&image.y=14
Jan 19, 2009 | Astoria Argenta AEP-2 Coffee Maker,...
Pressurestat defect ?
Yes, your pressure stat should turn off once in the "green" area. In most cases a pressure stat works or it doesn't. A lot of times carbon build up on the contacts is the issue. They are sensitive and can break off easily when your cleaning them so be careful. Also make sure the machine is turned off before doing any work (220v = ouch!).
www.kaldi.com
Nov 18, 2008 | Astoria Argenta AEP-2 Coffee Maker,...
Older machine needs repair
When you press the dispense button does the needle on the dispensing pressure gauge move up to the green area? If so, most likely your group head solenoid valve is bad. It's located behind the back splash. It's a small black box connected to a metal tube just behind the group head. They cost around $70.
If the needle doesn't move it could either be your pump or motor. Now you're in the $200 range.
Jul 06, 2008 | Astoria Argenta AEP/JUN Coffee Maker,...
Coffee Makers & Espresso Machines Logo
144 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
