Question about Westinghouse Dishwashers
Error code 20 on Westinghouse Dishwasher
Hi,My Westinghouse dishwsher SB916 has just developed a problem. Its 6 months old (still covered by warrantee).It gets partway through the cycle (random amount - but seems to be about 20-30 minutes in) and then stops. An error code of "20" comes up on the display. When I turn the power off and then back on, the dishwasher resumes ... and runs for another few minutes (again up to about 20) before the same thing happens.Any ideas?
huuum
  • 750 Answers
SOURCE: Smeg Dishwasher DI612C
Hello Friend,
Welcome to fixya.
I'm Huuum and happy to assist you,
Try this remedy.
When we have an error code this is the remedy.
This can reset the system.
First turn it off.
Cut power to the washer at the breaker and wait a 5 minutes then restart it.
It's like rebooting your computer when its acting strange!
Usually it corrects some error problems if they are not serious.
Or they are sometimes just a glitch.
Write back right away and let me know that it worked and solved the problem .
Bless You
Please remember to enter a rating here when you finish!
How old is the appliance?
Here is an interesting report I just read.
Repair or replace?
When to pull the plug on your old refrigerator
It nearly always makes sense to undertake simple do-it-yourself repairs,
such as replacing a gasket on a refrigerator or a freezer.
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your refrigerator,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your refrigerator is under warranty or less than four years old (three years for top-freezers),
paying for a repair makes sense.
Note that refrigerators under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your refrigerator is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models are quieter and have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new refrigerator.
Data also shows that it doesn't pay to fix a less-expensive top-freezer refrigerator
six or more years old or a bottom-freezer or side-by-side eight or more years old.
Thanks to better recycling programs, less than 10 percent
of a refrigerator you replace is likely to end up in a landfill.
Thanks for giving me the opportunity to help!
Please do not for get to give a rating before you sign off!
Thank You, HUUUM
Bless You
PLEASE GIVE ME A GOOD RATING HERE AT FIXYA.COM BEFORE YOU SIGN OFF.
Posted on Sep 23, 2008
  • 3230 Answers
SOURCE: Error Code OE
The most common cause of an OE error code on a modern LG dishwasher is:
1. Blocked drain hose
2. Obstruction in the sump area (beneath the filter, which needs to be removed to check for onstruction)
3. Failing drain motor.
else you need to REPLACE THE PCB POWER CONTROL BOARD
Good Luck!!!
Posted on May 06, 2009
  • 7 Answers
SOURCE: Error code 2H
The control panel needs to be replaced (indicated by the "2H" error code displayed at the start of the cycle).
BTW - The number 1 displayed at the end of the cycle indicates the cycle has timed out (i.e., it doesn't mean 1 minute remaining). Hence the continued running of the unit. Until you replace the control panel, you'll have to manually cancel the cycle at this point.
Posted on Jul 29, 2009
  • 69 Answers
SOURCE: F4 error fisher & paykel nautilus dishwasher
F4 is a heating error- dishwasher has not reached temperature in allocated time. If intermittent fault, problem is usually with electronic board, which has temperature sensor attached. Sometimes the wiring to the control board burns out and can give intermittent false readings causing F4 error. Disconnect from power, remove front panel (4 screws down each side). You can now see wiring going to control board- check for burnt wires. Also check temperature sensor (small square with two purple wires) is stuck to inner door panel- if this is not stuck to inner panel, temperature sensor will not work properly. If in any doubt, call in the experts!!
Posted on Mar 09, 2010
SOURCE: LG Dishwasher making grinding noise then blinking E1 code 10 minutes later
Ive got an LG LD1204w1 model dishwasher, the grinding sound started about a week before the E1 error code and incessant dinging began. I found FixYa the best site for LG solutions, the wiring had fused to the lining on the door as suggested, so a bit of electrical tape has done the trick as far as the E1 error and dinging is concerned (thankfully no broken wires)
However I still have the grinding sound during the wash cycle. Drainage and fill hoses are to specifications stated by LG, there is no wear on inspection, the unit isnt losing water during wash so the air/water issue I dont think is relevant to my situation. Is there anything else that could possibly be causing the awful noise its making? The noise seems to be coming from the bottom/underside of the dishwasher.
Posted on Jul 23, 2010
What does h22 mean on my Westinghouse dishwasher screen
Need more information; Model? Malfunction?
Error Code h22 Not found
Error Code 20 is failure to drain STOP, OFF and SHUTDOWN
http://kitchen.manualsonline.com/manuals/mfg/westinghouse/wsf6602.html?p=15
Jun 29, 2014 | Dishwashers
Hi, I have error message 20 on BDW14 Baumatic. Dishwasher won't start. What does it mean? Thank you..
Error 20 is not a listed error in Baumatic dishwasher. They only mention E1 to E7.
There is a reset procedure for random errors which can be viewed at this page.
http://www.ukwhitegoods.co.uk/help/fault-codes/dishwasher-fault-codes/3305-baumatic-bdw-dishwasher-fault-codes.html
Please check if this helps.
Apr 25, 2014 | Baumatic Dishwashers
Westinghouse sb916
check hot water supply. Is the valve open?
Aug 07, 2013 | Dishwashers
Our TV picture works fine then blacks out with audio continuing to work ok.Now after some time picture works ok for about 20 seconds the blacks out with audio continuing on OK.While we bought this in 2008...
I think you chose a Westinghouse Lemon, go this site and read all of the negative reviews of this model;
http://reviews.cnet.com/flat-panel-tvs/westinghouse-sk-32h240s/4852-6482_7-32429419-2.html?tag=userReviews;page
Here's just one of the reviews;"best chunk of aluminum i ever had the fortune to buy"by stevecox25 on June 11, 2009-->
"Horrible customer service on a worse television" by westinghousecrap on March 20, 2009 Pros: Good picture once it is properly adjusted.
Cons: Low quality audio, had the TV for 10.5 months and the picture went out, sent the TV at MY expense to TX, and I've been waiting for 2 months, and customer service can only say that there is a "delay". And they don't send a new TV, it's a rebuild.
Summary: Please don't waste your money on this TV, spend a little more on a different brand and save yourself the headaches I've had. I'll never purchase a Westinghouse product again. Customer service has been no help, and their answers are vague at best. Learn from my nightmare, NCAA march madness on a old 19" TV because my Westinghouse quit working 2 months ago and they still haven't replaced it.
Aug 22, 2010 | Westinghouse SK-32H240S Television
I have Kenmore dishwasher type 575-0 it is leaking
did you pull the bottom cover off and watch it run it could be either thesupply line developed a leak or the drain tube has done the same or in most cases with dishwashers relatively old the pump has cracked in which case the washer is trash
Apr 07, 2009 | Dishwashers
Clean light flashing Quiet Partner V
do the heated dry and hi temp and then hitr cancel. you know what this means?! you have a bad heating element usually. call for service this should be a covered repair if it is only 6 months old
Mar 26, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Leaks
try to use lass soap
May 12, 2008 | Danby 22 in. DDW396 Free-standing...
Westinghouse 47" hd lcd 1080p
It does not need to be a blown speaker to be causing the problem. The issue (unless you have a habit of running the TV at maximum volume) is more then likely in the audio circuit of the TV.
Since it is only 6 months old, I would be straight onto Westinghouse to have it repaired under warranty.
Apr 14, 2008 | Westinghouse LVM-47w1 47 in. HD-Ready LCD...
Dishwashers Logo
2,982 people viewed this question
Top Westinghouse Dishwashers Experts
JonSnell Electronic
JonSnell Electronic
Are you a Westinghouse Dishwasher Expert? Answer questions, earn points and help others
