Question about Maytag MER5775Q Electric Kitchen Range
How do I find the control board in a Maytag MER5755QAQ range?
While preheating my oven made a horrible noise, started smoking and the digital display stopped working. The bake element blew so I replaced it but I still don't have a display and the keypad doesn't work. My appliance parts store told me to bring the board in but I don't know how to get to it. Please help!
  • 370 Answers
You have to pull the stove out from the wall. There is a plate on the back that you have to take off and it will expose the clock.
Posted on Dec 11, 2008
Maytag Oven model MER5755QAQ has lock on the display and the oven will not operate.
If one of the position switches on the latch assembly is not reading, the control will sometimes lock because it "thinks" a clean cycle has been initiated, if replacing the control did not fix the lock icon, test the switch... Incorrect temp probe and thermostat failures can also make a control "think" it is in a clean cycle. Maytag Range Stove Oven Door Lock Motor and Switch Assembly WP74008702 Maytag Range Stove Oven High Limit Thermostat 74008715
Jul 06, 2016 | Maytag Kitchen Ranges
Maytag electric oven Model MER5755QAQ will not heat past 100
Sorry to say but the erc or eoc has gone bad. The oven control is part # 74009212 at about 200.00. Sorry for the news but it is the problem. Hope this has helped.
Feb 02, 2010 | Maytag MER5775Q Electric Kitchen Range
Oven will not heat up completely
Hi!
Try the following---
1.) When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out.
You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results.
If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component.
2.) When the temperature is consistent but too high or too low, it could be one of several different things. First check to see if the thermostat sensing bulb has come loose from its holder. It could be lying on the floor of the oven or resting on the heating element. This would cause the oven to not heat correctly.
If the thermostat bulb is not dislodged, it's likely that the thermostat or sensor is either mis-calibrated or defective.
Electronic ovens with a digital display use a sensor to monitor oven temperature. To solve temperature problems for these models, you may need to replace the sensor. On some digital-display models, you can calibrate the temperature using the key pad. See your operator's manual for details.
Ovens without a digital display often use a mechanical system for controlling temperature. On many of these units, you can remove the thermostat knob and adjust the knob itself to more accurately represent the actual setting of the thermostat.
If, when you remove the knob, there's a screw on the back of it with a small calibration plate, you can loosen the screw, adjust the plate, then tighten the screw again. If the knob isn't adjustable, and the oven temperature is off by more than 30 to 40 degrees, you need to replace the thermostat to solve the problem.
Thanks
Rylee
Jan 31, 2009 | Maytag MER5870 Electric Kitchen Range
Replacing control board
There are two screews onder the shield. You need to get level with the shield to see them. Remove the two screews and it should come off no problem. Now to get in to the controll panel you have to pull the oven out and there are two screews on the back in both top corners to get in side to the control board. Good luck
Dec 16, 2008 | Maytag MER5775Q Electric Kitchen Range
Too hot
more than likely if it isnt shutting off when it reaches temp. then it probably needs a temp sensor or a EOC (electronic oven control). I have replaced many of these boards in the past , usually there is a relay on the board that is stuck. The relay really isn't replaceable and the whole board needs to be replaced. Does the dispay show the temp that the oven acually is or the temp it is set for?
Nov 05, 2008 | Maytag MER5775Q Electric Kitchen Range
Oven's digital temp display too dim to read
The electronic control board will have to be replaced
Jun 07, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Maytag MER5775Q Electric Kitchen Range Logo
250 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
