Question about Garmin Nuvi 350 Car GPS Receiver
Garmin Nuvi 660 dead battery?
My Nuvi 660 will operate only when plugged into the vehicle mount. Other wise it works and tracks fine. Is this an indicator that the battery is dead?
  • 1 more comment
  • cec1013 Dec 15, 2008
    When I unplug it; it goes dead instantly. I suspected the battery. Can I get a new one without a complete rebuild? Otherwise it seems to work great. Thanks for the help.
  • cec1013 Dec 16, 2008
    Response was quick and confirmed my idea of the apparent problem. I intend to ship to the responder for repair. Thanks again for the service.
  • Anonymous Dec 24, 2008
    I just deleted some jpg files to save space and added gpx poi files Now when I turn it on it says 'loading maps' and then the screen goes blank. Battery fully charged.
    sxj@talk21.com
  • 10 Answers
Here's a video demonstrating how to change the Nuvi 660's battery from newpower99. I hope this helps. Peace, Craig
(do not delete)
Posted on Mar 23, 2010
Normal 0 Garmin NUVI 660 instructions
It is pretty easy to open up your nuvi,(but not recommended by Garmin or me)...
looking at your nuvi from the back flip up the antenna. You will see two tiny torx screws on the antenna. Remove them and carefully seperate the antenna housing. Pay attention to how the antenna flex is seated because reassembling the antenna housing can be tricky. On the left bottom side the pin assembly that holds the antenna in is spring loaded. Pull the pin towards the center and you will be able to seperate the antenna housing from the unit. Underneath you will find two more tiny torx screws holding the main housing togather. Remove those two screws and you are almost home. Now you need the special plastic tool that you can get on ebay. The tool is used for opening ipods without mangling them. Gently pry the case apart with this tool. Start where ever it is easiest to get the tool in. Once opened you can figure the rest out for yourself. The battery is flat and rectangular and is seated behind the circuit bourd attached to the back cover.
Posted on Dec 26, 2008
I had a power button problem on my Nuvi 350 and Lance's description of opening the Nuvi was the best I came across.
a few suggestions to add:
#1. When the you remove the antenna, that spring loaded clip will want to fly off into space. Both the plastic clip and the spring behind it are not held in by anything when the antenna is removed. Make sure you put your hand over it to catch it.
#2. Those torx screws are TINY. I have a pretty good security security bit set and not even close to small enough. I found a #2 precision screwdriver (3/64th slotted not phillips head) was able to bite on those screws pretty well without slipping and stripping.
Posted on Jan 08, 2009
  • Garmin Master
  • 2,130 Answers
Do you see a lightning bolt symbol over the battery bar graph? This indicates that its charging. When you disconnect it from the car cradle, what happens? Does it stay on and ask you to select to stay on or shut down or does it go dead? If it goes dead right away, yes your battery is defective and needs to be replaced.
- Jim
SHARCNET-USA
Posted on Dec 12, 2008
  • 502 Answers
You probably need a new battery. Ifthey don't give you a new one under warranty, are third party Garmin repair services that will fix it for cheap. Also, I found an DYI GPS repair guide,so you can do it yourself too, not that difficult. The part is on Ebay.
Posted on Jul 12, 2010
Garmin nuvi 660 battery will not charge from car charger
Make sure the fuse to your DC socket isn't blown. Check the fuse in the tip of the charger. When your Nuvi 660 is plugged into the cradle, you should see a yellow lightning bolt over the battery icon. If you don't see this, then your Nuvi isnt getting voltage from the car charger.
You can also have a bad cradle or charger plug that plugs into the cradle. More info can be found here:
http://www.sharc.net/gps_charger_repair.htm
- Jim
Jan 22, 2011 | Garmin Nuvi 660 GPS Receiver
Nuvi 660 ~5yrs old. With auto charger connected the unit powers off quickly with low battery indication. However if charged overnight on a USB cable the unit operates fine and indicates the battery is...
You probable have a blown fuse in the cigarette lighter adapter.... Unscrew the silver tip of plug and check fuse..... be careful its spring loaded..
Oct 24, 2010 | Garmin Nuvi 660 GPS Receiver
I've been using after market chargers in car and on ac. They worked fine for a long time. Now, my Garmin NUVI 660 seems to turn off (goes into "charge mode" or something) when I plug my car charger into...
Yes, many aftermarket chargers are not wired the same as a Garmin charger and will cause your Nuvi to think it's connected to a PC. What happened to the original charger that plugged into the cradle (the part your Nuvi snaps into?)
Please see this link:
- Jim
Jul 15, 2010 | Garmin Nuvi 660 GPS Receiver
My 2 yr old Garmin nuvi 200 was working fine...when I got home and turned the car off, it quit working and won't turn back on. I keep it plugged into the lighter, so it's not battery power.
No it's not the battery power: your nuvi has suffered the firmware equivalent of a stroke.
These are the steps to take to update your Nuvi 200:
Download and then run Garmin 200 WebUpdater to replace its firmware / system software.
I hope that helps.
_____________________________
Nuvi 200 Manuals here.
Backup your favorites.
Nuvi 200 Hard Reset.
Apr 18, 2010 | Garmin Nuvi 200w 250w 260w 580 660 670 680...
Batteries will not charge
Your not the Lone Ranger on this problem. After awhile the battery will no longer take a charge. IT is not a replaceable battery by the user. It must be sent back to Garmin for a new battery. If you only use the gps when in a vehicle, it still will work fine when pluged into a 12v source.
Dec 30, 2009 | Garmin Nuvi 660 GPS Receiver
The earplug/headset input on my Garmin Nuvi 660 is broken.
Interesting problem but I have repaired this problem before. This is not going to be something you can fix yourself.....believe me... I have 30 years of experience in Electronics.
The headphone jack either has to be resoldered or replaced. When its loose, in most cases the pins of the jack are broken and/or the printed circuit board tracks have been torn off the board. The jack is a surface mount part.
A new jack must be installed but there is no way to solder in a new jack because the printed circuit board tracks are gone. The new jack must be installed with epoxy to the board and new wires have to be soldered from the printed circuit board to the jack.
There's around 2 hrs worth of work involved in this repair.
- Jim
SHARCNET-USA
Dec 02, 2008 | Garmin Nuvi 660 GPS Receiver
Nuvi 205 dead
Garmin support center----tomtom support center
http://www.gpscentral.ca/contactus.htm
all the gps information for 660 number model
http://gpsinformation.info/nuvi/660/660.html
Nov 17, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 660 shutting off
It sounds like your battery is defective. They can be replaced. The Motorola phone cable is not wired exactly like the Garmin, and your Nuvi thinks it's connected to a PC. Radio Shack carries a charger for the Nuvi. I have one myself.
Let me know if you need additional help with your battery problem.
- Jim
Nov 15, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin NUVI 660 power problem.
To charge a nuvi, use one of the following methods:
  1. Connect the nuvi to the suction cup mount and the vehicle power cable.
  2. Connect the USB cable to the nuvi and the computer. The computer will charge the nuvi as long as the computer is on. However, the unit will be in Mass Storage Mode and normal operation is not possible.
  3. Connect the AC power cable and the nuvi to a wall outlet.
Please note: All of the nuvi series will come with a suction cup mount and vehicle power cable to charge the nuvi. However, only some of the nuvi models will come with an AC power cable and/or USB cable. If they did not come with the nuvi, they would be optional cables and would be a separate purchase. Garmin only recommends using an AC power charge that is purchased from Garmin. Third party power cables may not charge the nuvi. These cables may be purchased from Garmin or Garmin's dealers.
Oct 11, 2008 | Garmin Nuvi 660 GPS Receiver
Screen shuts off within 10 seconds after turnon, if power not connected to car
replaced battery. works fine now. holds charge for some six hours or more.
Oct 07, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 350 Car GPS Receiver Logo
4,826 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
