Question about Sanyo PLV 70 Multimedia Projector
SANYO PLV-70 - powers up for approx 5 secounds and then turns of
Projector says lamp is ready and green light indactes ready, upon pressing power lamp lights up and then system shuts down
  • 1 more comment
  • jaytaylor Dec 11, 2008
    I have 2 projectors that are exhibiting the same symptoms.
  • Anonymous Apr 10, 2009
    Lamp light red (this is normal), Ready light green (normal also), upon pushing on/off the fan speeds up then it shuts down again. After about 30 sec the Ready light is good again.
  • jayjones6101 May 15, 2009
    With green "Ready" light on and red "Lamp" light on pushing the "On-Off" button the fan comes on the lamp starts to glow, but then, after 5 seconds or so the lamp goes out the fan stops and the green "Ready" light goes out. Unplugging/Replugging the power cord recycles the green "ready" light but pushing the on button results in the same thing --on for a few seconds then shut off.
    I had the projector since it was first released back in 2002 with no problems, only lamp replacement and the occasional bust cleaning (compressed air).
    On behave of myself and others with this problem, thanks for your help.
    Jay
We had this problem and it ended up being that one of the fans under the lens assembly was not working, causing the system to shut down when it tested it at startup
Posted on Sep 22, 2009
Projector not turning on
seems that the lamp is defective, pls test it
Have a good day! any question ,contact me,Please
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry Lampdeng Limited
Mobile: 0086-13178867858
Wechat ID: 008613178867858
Whatapp ID: 008613178867858
Skype: lampdeng@hotmail.com
http://www.lampdeng.com
Feb 25, 2014 | Optoma EP739 Multimedia Projector
Sanyo pro xtrax projector
Lamp LED should be lit when the projector is in Standby. However, the problem you are describing sounds like one of two issues. Either the lamp is bad and needs replaced, or there is a power supply fault. If you have tried replacing the lamp already, make sure you reset the lamp counter or the projector may still not function properly.
does the temp warning light come on when the projector shuts off? if so you may also try cleaning the air vent filters and ensure there is proper air flow around the projector. if that checks out then have the projector serviced as the power supply is likely suspect.
Dec 09, 2013 | Sanyo Office Equipment & Supplies
I have a model PLC-XT11 and when I turn the power on the temp light and green ready light begin to flash. The red lamp light is on steady. I replace the lamp but no luck.
one or more of the fans may not be working right. also, the temp sensor may be shot. if the last time you used it it wasn't shut down properly, it may still be in cool-down mode.
Nov 06, 2009 | Sanyo PLC-XT11 Multimedia Projector
My PLV-Z2,globe will not light up,power up to
ballast and/or lamp is bad and needs to be replaced. the ringing sound is high voltage issue.
Oct 04, 2009 | Sanyo PLV-Z2 Multimedia Projector
Sanyo PLV 70 Multimedia Projector Logo
579 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
